    Push button (ON/OFF) script problems?
    push button onoff script
    13
    34
    21903
      paradadf Staff last edited by
      Hello everyone!
      I installed a momentary switch as described on the wiki and it works great. The only issue I'm having is that sometimes, when I plug/unplug an usb controller or usb stick, Recalbox turns off (or on) out of the blue. Has someone else experience this behavior?
        I've had such weird behaviours when playing around with the HDMI cable without using the power script ... D**n, what an unuseful comment I just wrote lol
        • supernature2k
          supernature2k last edited by
          Some switches are very sensitive (especially old ones) and it can trigger some events when slightly moved.
          I have the same problem with my NES power switch.
          You can easily edit the script and change the function so that the button must be pressed x seconds to trigger the shutdown. it should solve this kind of problem.
          D**n, THAT IS a useful comment 😛
            😆 thanks! I'll try it and report back!
            • lackyluuk
              I have this behaviour as well. But I am not using any start / stop scripts. I just start recalbox and sometimes it reboots when I plug in a USB controller. I do not know what to do 😞
              The only scripts I use are two selfmade scripts for changing the system volume via gpio and a fan control. But I do not think this has an impact.
              PenPen dh04000 2 Replies Last reply Reply Quote 0
              • PenPen
                PenPen @lackyluuk last edited by PenPen
                @lackyluuk said in Push button (ON/OFF) script problems?:
                Hi,
                Coud you explain your fan control script ? Thx
                Raspberry Pi 3 > NeoGeo piX
                Recalbox 4.1 OC@1375Mhz
                https://forum.recalbox.com/topic/4006/wip-neogeo-pix
                  I've looked into
                  https://github.com/recalbox/recalbox-buildroot/blob/rb-4.1.X/board/recalbox/fsoverlay/recalbox/scripts/powerswitch.sh
                  and
                  https://github.com/recalbox/recalbox-buildroot/blob/rb-4.1.X/board/recalbox/fsoverlay/recalbox/scripts/rpi-pin56-power.py
                  but I still can't find which value I should change. Any hints, please?
                  supernature2k 1 Reply Last reply Reply Quote 0
                  • supernature2k
                    supernature2k @paradadf last edited by
                    @paradadf
                    I'm working on a super script, I think it will help you.
                    paradadf 1 Reply Last reply Reply Quote 1
                      paradadf Staff @supernature2k last edited by
                      @supernature2k the word SUPER before any other is always nice to read! Looking forward!
                      • lackyluuk
                        lackyluuk Translator last edited by lackyluuk
                        @PenPen: I am sorry for this way too late answer. Not sure if you need an answer anymore
                        Here is an example with GPIO pin 14 for controlling the fan. The indents might not be correct 😉 I had a little trouble with copy/paste the code 😄
                        Hope I can help you with this
                        #!/usr/bin/env python
                        import os
                        import time
                        import RPi.GPIO as GPIO
                        GPIO.setwarnings(False)
                        GPIO.setmode(GPIO.BCM)
                        #Set max. temperature of CPU
                        TEMP_MAX = 67
                        ON_TIME = 200
                        #Set pin 14 as transistor gate
                        GATE = 14
                        #Set pin 14 as an output and shut down
                        GPIO.setup(GATE, GPIO.OUT)
                        GPIO.output(GATE, False)
                        def getCPUtemperature():
                        	 res = os.popen('vcgencmd measure_temp').readline()
                        	return(res.replace("temp=","").replace("'C\n",""))
                        while True:
                        		temp_float = float(getCPUtemperature())
                        	try:
                        		if (temp_float > TEMP_MAX):
                        			# ein
                        			GPIO.output(GATE, True)
                        			time.sleep(ON_TIME)
                        			# aus
                        		else:
                        except KeyboardInterrupt:
                        	print float(getCPUtemperature())
                        	print "power off fan..."
                        	print "cancelling..."
                        Forgot to attach a short drawing. I used the official RaspberryPI 5V DC fan.
                        PenPen 1 Reply Last reply Reply Quote 1
                        • supernature2k
                          Awesome!!!!!
                          But I'm not sure 'bout the infinite loop.
                          Maybe add a time.sleep somewhere for less CPU?
                          whatcha think @subs ?
                          • PenPen
                            Thanks ! I'll buy composants tomorrow.
                            • lackyluuk
                              @supernature2k yes, this could be a good idea. Would it be useful to have a time.sleep in the while loop? So it checks the temp only every 2 seconds for example.
                              • supernature2k
                                Yes I think so, at the end of the while.
                                1 or 0.5 seconds would be ok too I guess.
                                • dh04000
                                  dh04000 @lackyluuk last edited by
                                  How do you do this? The gpio volume control? Could you post this script?
                                  Also, I have OP's problem with crashing after installing the gpio on/off button with usb controller unpluging, as well as sometimes random.
                                  @supernature2k said in Push button (ON/OFF) script problems?:
                                  How do I change the time to be longer? I think my gpio momentary switch might be picking up some signal from my speakers, wifi, light system, something....
                                  • lackyluuk
                                    @dh04000 Here is a wiki article that I wrote. This should help you. I used the Hifiberry Shield to access the ALSA controls.
                                    https://github.com/recalbox/recalbox-os/wiki/Audio-HiFiBerry-(EN)
                                    • Tardigrada
                                      Tardigrada last edited by
                                      Hello, I'm completley new to this stuff so just to make shure I don't damage my Raspberry can someone confirm that following these steps will make the fan-control script work?
                                      1. On my Linux Desktop I create an empty textfile in which I paste the fan-script posted here.
                                      2. I rename the file into fancontrol.py and move it into /recalbox/share/system/ on the sd-card.
                                      3. On Recalbox i quit emulationstation, open the terminal and navigate to the share/system directory and make my script executable with chmod +x fancontrol.py so it is ran at boot
                                      And last question (for now:) - where in the script should i paste the time.sleep(1) so it only checks every second for the temp?
                                      Thanks in advance!
                                      • miserytom
                                        miserytom last edited by
                                        Where the hell do I paste the fan script ????
                                        • lackyluuk
                                          calm down @miserytom 😄
                                          I suggest you to put it into /recalbox/scripts and then in /etc/init.d (where all startup scripts are located) you could place another script which is starting your fan script in a background process
                                          azvarel Pedro Vieira 2 Replies Last reply Reply Quote 0
                                          • azvarel
                                            azvarel @lackyluuk last edited by
                                            @paradadf
                                            I'm having a similar problem, I noticed two situations that happened with version 4.0 final the first was that in recalbox.conf the system.power.switch=PIN56ONOFF command duplicated several times, and the second that if I do screenscrapper of a very large romset example GBA simply out of nothing Rpi is turned off.
                                            There is a third option, the wifi in the recalbox shows that it is not connected, however I get access with your ip (this for me is very strange)
                                            Zodian Theme | #SNESProject
