    Solved Game Reset
    reset
    16729
    • lackyluuk
      @supernature2k hey mate πŸ™‚ not sure if I should open a new thread.
      I am using the RESET script you posted in this thread for a long time. But since I have updated to 4.1 stable, the script is somehow messing up retroarch.
      As soon as I press my Reset button on the console it works exactly 1 time. After this no retroarch special commands work anymore, not even on the controller (No Hotkey+Start to exit the game, reset, rewind, save, load etc.). I can still enter the RetroArch settings with Hotkey+A but then it freezes there and I have to turn off the Raspi by pull out the plug.
      I think it's a script problem because the Hotkey commands work flawlessly on the controller. But once I used the Hardware Reset button with this script, all is bad. Any idea on that? πŸ™‚
      • lackyluuk
        @Substring hey pal πŸ™‚ is @supernature2k not available these days? πŸ™‚ Maybe you have an idea on the topic above?
        Substring supernature2k 2 Replies Last reply Reply Quote 0
          Substring @lackyluuk last edited by
          @lackyluuk I'd also ask @OyyoDams who's been working on a much more global python script to handle any kind of "known" event (which would fit with the volume change for alsa you wrote in your wiki for example).
          Ex dev - Merci de me rΓ©pondre en utilisant @substring pour que je sois notifΓ©
          • supernature2k
            supernature2k @lackyluuk last edited by
            @lackyluuk
            Hi bro, I tested my script and it works fine, I can do several RESET, exit,re-enter the game and do it again.
            could you please try this:
            import RPi.GPIO as GPIO
            import time
            import socket
            # addressing information of target
            IPADDR = "127.0.0.1"
            PORTNUM = 55355
            # enter the data content of the UDP packet
            COMMAND = "RESET"
            def retroarch(nwcommand):
            	try:
            		s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
            	except socket.error:
            		print 'Failed to create socket'
            		sys.exit()
            	s.sendto(nwcommand, (IPADDR, PORTNUM))
            GPIO.setmode(GPIO.BCM)
            GPIO.setup(3, GPIO.IN, pull_up_down=GPIO.PUD_UP)
            def netcmd(channel):
            GPIO.add_event_detect(3, GPIO.BOTH, callback=netcmd, bouncetime=500)
            while True:
                time.sleep(0.2)
            • lackyluuk
              lackyluuk Translator last edited by lackyluuk
              @supernature2k Thanks for your help. I tried as you proposed but it still doesn't work πŸ˜•
              I replaced
              with
                    retroarch(COMMAND)
              I can use this script only once. Really no idea why it stucks..
              I also tried to close the socket with s.close
                OyyoDams Staff @supernature2k last edited by OyyoDams
                @supernature2k Hi,
                I do have the same issue. Even with the simple echo -n "RESET" | nc -u -w1 192.168.1.172 55355 command from my computer, retroarch only responds to one kind of each event. I can't send the same command twice...
                • supernature2k
                  supernature2k @OyyoDams last edited by
                  @oyyodams Hi
                  I really can't say where the issue is. If you say this cmd doesn't work, it looks like a RA problem.
                  But I tested my script on my 17.10.2 recalbox and I can send multiple RESET, exit game re-enter game and it still works O_o
                  What if you send the cmd to localhost (127.0.0.1) ?
                  • supernature2k
                    @oyyodams
                    Ok so I did more tests and got strange behaviors. With the command you provided or via a simple script, RESET works 1 time only but... if you throw a QUIT, it works O_o
                    then I did the following:
                    ~$ echo -n "LOAD_STATE" | nc -u -w1 192.168.1.30 55355
                    ~$ echo -n "RESET" | nc -u -w1 192.168.1.30 55355
                    1st command: success
                    2nd command: success
                    3rd command: fail
                    O_o
                    This is definitely a strange behavior from RA.
                    I tested this on my X86_64 recalbox, I'll do more test tonite on the rpi3 one.
                    • lackyluuk
                      @supernature2k thanks for your effort.
                      for me it's also still the same. I use ocal host 127.0.0.1.
                      With the controller everything works fine.
                      supernature2k 1 Reply Last reply Reply Quote 0
                      • supernature2k
                        @lackyluuk more to come tonite as I'm 100% sure it works on my 17.11.10.2 rpi3. Maybe smthg in the retroarch.cfg?
                          @supernature2k same thing with localhost. Even with a simple python script. Like with your last example, I can send several commands if they are different, but I cannot send the same command more than one time. RA doesn't accept the same command more than once. We can talk on IRC if you want πŸ™‚
                          My retroarchcustom.cfg is simple, I've juste added network_cmd_enable = true. Maybe there is something else to add, but I can't find what. I tried stdin_cmd_enable = true but it doesn't change anything.
                          • lackyluuk
                            @OyyoDams @supernature2k
                            Many thanks to the recalbox developer team. The commands are working great again with the new release πŸ™‚
                            supernature2k OyyoDams 2 Replies Last reply Reply Quote 0
                            • supernature2k
                              @lackyluuk thanks to RA team that accepted our merge request with the fix very quickly and included it in their last release πŸ™‚
                                OyyoDams Staff @lackyluuk last edited by
                                @lackyluuk thanks to @supernature2k who found the bug, and to the RA team for the quick fix πŸ™‚
                                100.3k
                                Copyright Β© 2021 recalbox.com
