    [Recalbox 9] Theme Next Pixel
    Themes & Interface
    theme recalbox 9
    148
    783
    1181462
    • Bkg2k
      Bkg2k Staff @lhari84 last edited by
      @lhari84 Could you please send us the result of the following command in an SSH console? :
      cat /proc/cmdline
      Thank you.
      lhari84 1 Reply Last reply Reply Quote 0
      • lhari84
        lhari84 @Bkg2k last edited by
        @bkg2k Of course:
        coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1280x720M@60 smsc95xx.macaddr=E4:5F:01:75:FE:29 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 dwc_otg.fiq_fix_enable=1 sdhci-bcm2708.sync_after_dma=0 dwc_otg.lpm_enable=0 console=tty3 consoleblank=0 loglevel=3 elevator=deadline vt.global_cursor_default=0 logo.nologo splash label=RECALBOX rootwait fastboot noswap video=HDMI-A-1:D video=HDMI-A-2:D
        Pi 4:
        Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
        Pi Zero 2W:
        GPi Case 2W, Recalbox 9.0
        • Bkg2k
          Bkg2k Staff @lhari84 last edited by Bkg2k
          @lhari84 Ok, could you now test the following:
          • mount -o remount,rw /boot
          • nano /boot/cmdline.txt
          • Remove the latest options: video=HDMI-A-1:D video=HDMI-A-2:D
          • Save & exit (CTRL+S, CTRL+X)
          • reboot
          lhari84 maaamish 2 Replies Last reply Reply Quote 0
          • lhari84
            @bkg2k Great, this works, thank you very much!
            Pi 4:
            Pi Zero 2W:
            • Bkg2k
              @lhari84 Great ^^'
              Anyway the video=HDMI-A-1:D video=HDMI-A-2:D has been suggested by the Raspberry foundation developpers to address an issue with their latest firmware 😞
              Seems like it just changed the issue...
              • lhari84
                @bkg2k That's too bad, hope you will not have to many issues because of that... 😞
                May I ask about another thing in this occasion, I'm still having issue with safe shutdown, please see my latest message in following topic:
                https://forum.recalbox.com/topic/25776/safe-shutdown-not-working-nespi-4-case/7
                Pi 4:
                Pi Zero 2W:
                • maaamish
                  maaamish @Bkg2k last edited by
                  @bkg2k Un grand merci, problème résolu.
                  • lhari84
                    Hi @mYSt
                    I'm just fighting with enabling only specific games for each system:
                    I've changed affected games.sh files and wondered why still other games would be shown up. Afterwards I've checked the readme and found out that I have to run (all) the games.sh files.
                    If I do that, I receive errors:
                    What am I doing wrong?
                    Thanks in advance!
                    P.S.:
                    To be honest, I really like the artwork of v1.x more. I guess you have replaced a lot in v2.0 to provide more authentic pictures for each game version, that's understandable, though.
                    No problem at all, fortunately I can replace the background files in new version with old ones 😉
                    Pi 4:
                    Pi Zero 2W:
                    samui 1 Reply Last reply Reply Quote 0
                    • lhari84
                      Add. info regarding my last post:
                      In my case, executing the games.sh destroys the background in system view:
                      All 3 systems I've tested show up only a black background after reboot. Backgrounds in gamelist view are ok but still show up game themes I have disabled.
                      Pi 4:
                      Pi Zero 2W:
                      • alonsocr23
                        alonsocr23 last edited by
                        Is there any way to use this theme in Emuelec? I've tried it and it has several bugs. Thanks.
                        • Anklum
                          Anklum last edited by
                          Lorsque j'utilise le fichier next_pixel_screenshot_title.xml dans Skraper pour obtenir des images mix, tout est OK à l'exception du système naomigd qui utilise l'image par défaut computer_flat.png (le système naomi lui est correctement affiché avec arcade.png.
                          Ci-dessous le contenu du fichier next_pixel_screenshot_title.xml lignes 85 et 86 :
                          <!-- ARCADE arcade,atomiswave,daphne,fba,fbneo,mame,model3,naomi -->
                          <Item IfSystem="IsInTheList:53,49,75,55,56">
                          Quel numéro faudrait-il ajouter pour que naomigd soit reconnu en tant que système arcade?
                          Numéro qu'il faudra ensuite ajouter également ici j'imagine (lignes 10 et 11):
                          <!-- DEFAULT COMPUTERS FLAT SCREEN -->
                          <Item IfSystem="IsNotInTheList:26,40,41,80,48,106,115,2,3,104,67,109,29,122,130,23,13,87,27,1,14,142,70,31,114,72,58,57,107,22,19,20,4,108,105,59,16,18,64,111,65,43,42,37,93,66,91,113,116,117,118,131,135,213,123,218,205,141,144,73,79,77,76,53,49,75,55,56,17,129,86,217,21,9,12,10,52,28,146,15,25,82,219,221,208,237,211,61,207,102,11,45,46,220">
                          mYSt 1 Reply Last reply Reply Quote 0
                          • mYSt
                            mYSt Theme moderator @Anklum last edited by
                            @anklum Hello et dsl pour le délai, je n'ai malheureusement pas de dispo en ce moment! l'id de naomigd est 227
                            marwin91 1 Reply Last reply Reply Quote 0
                            • marwin91
                              marwin91 @mYSt last edited by
                              @myst Bonjour, des news avec la sortie de
                              8.1 ou rien de spécial par rapport à ton thème ?
                              Raspberry pi4 4go/Argon One M2 v2/Recalbox RGB DUAL/8bitdo SN30 Pro/Recalbox 8.1.1 CRT/B&O MX7000 1.0
                              • The Blob
                                The Blob last edited by
                                Bien le bonjour à tous!
                                Désolé si la question a été posée 1000 fois....;-)
                                Pas simple de tout relire ci!
                                J'adore ce thème, comme beaucoup d'entre nous. Simplement j'ai une vraie et nette préférence pour sa V1. J'accroche moins sur les musiques et les nouvelles images lissées de la V2.
                                Ma question est : La V1 est t'elle parfaitement compatible avec la dernière version de RECALBOX (8.02) ? Ou bien s'expose t'on à quelques bugs et autres soucis de compatibilités?
                                Et quid de la 8.1 qui arrive tout bientôt!✌
                                D'avance, merci de vos réponses.
                                • mYSt
                                  mYSt Theme moderator @marwin91 last edited by
                                  @marwin91 Hello version 2.1 du thème arrive bientôt !
                                  • mYSt
                                    mYSt Theme moderator @The Blob last edited by
                                    @the-blob Hello j'imagine compatible mais je ne maintient plus cette version
                                    • mYSt
                                      mYSt Theme moderator last edited by
                                      Big news i'm back and new release will be available soon with lastest added systems and a few bug fixes ! Stay tuned !
                                      • nayok
                                        nayok last edited by
                                        Hello
                                        J'aime bcp ton travail, merci pour le theme.
                                        Y'a un moyen de paramétrer recalbox.conf pour scraper proprement avec ton thème @mYSt ?
                                        Je pense à ces lignes :
                                        ### Choose the media to download among:
                                        ### screenshot: game screenshot
                                        ### title     : game title screenshot
                                        ### box2d     : Front case
                                        ### box3d     : 3D rendered case
                                        ### mixv1     : Recalbox special mix image V1 (default)
                                        ### mixv2     : Recalbox special mix image V2
                                        ;scraper.screenscraper.media=mixv1
                                        Rpi 3 B+
                                        Recalbox 9.1
                                        Usb Storage
                                        USB Xin-Mo controller
                                        • mYSt
                                          mYSt Theme moderator @nayok last edited by mYSt
                                          @nayok Hello merci pour ton retour! Je ne crois pas que c'est possible, j'avais fais la demande à la team mais à priori compliqué pour le moment. @Bkg2k tu confirmes?
                                          Il faut utiliser Skraper pour le moment, regardes la doc du thème
                                          nayok 1 Reply Last reply Reply Quote 1
                                          • nayok
                                            nayok @mYSt last edited by
                                            @myst je connais la doc, j’avais utilisé une bidouille pour faire tourner skraper sur mon Mac, il y a un bon moment mais il faut emuler un windows 😕
                                            Comme j’ai vu ces lignes dans le .conf, je me suis dit que un pont était peut être possible
                                            Je crois les doigts
                                            Rpi 3 B+
                                            Recalbox 9.1
                                            Usb Storage
                                            100.8k
