    [Recalbox 9] Theme Next Pixel
    Themes & Interface
    theme recalbox 9
    148
    783
    1181358
    • lhari84
      lhari84 last edited by
      Hi @mYSt
      Great new version! After a long break, I'm currently updating to a RasPi 4 and RB 8, of course including Next Pixel v2 🙂
      There seems to be a small bug in v2:
      When selecting system Coleco, no specific music of the loaded game theme is played (no matter which one is currently loaded) -> It always plays the default music of Recalbox system instead.
      Thanks for your work and support!
      Pi 4:
      Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
      Pi Zero 2W:
      GPi Case 2W, Recalbox 9.0
      lhari84 1 Reply Last reply Reply Quote 0
      • lhari84
        lhari84 @lhari84 last edited by
        @lhari84 said in Next Pixel theme:
        Hi @mYSt
        @mYSt Sorry, just found out that more systems are affected, in my case Atari 2600, Atari 7800 and Coleco. Looked in the ES-logs and found some warnings related to missing audio files and actually, the file was missing.
        -> So some game themes just don't include a music file (yet), right?
        No problem for me so far, I will just exclude those few affected ones from being loaded.
        Pi 4:
        Pi Zero 2W:
        mYSt 1 Reply Last reply Reply Quote 0
        • mYSt
          mYSt Theme moderator @lhari84 last edited by
          @lhari84 Hello and happy new year !
          Indeed some system have no music as i couldn't find one for the game in question
          • Madmeggo
            Madmeggo last edited by
            Would it be possible to use the 1080p version of the theme on a Raspberry Pi 4 with more than 1GB RAM? For example on a Pi 4 with 2GB? Or would I still have to use the 720p version? If this would work, I would think about buying the 2GB Version! I love the next pixel theme and since I want to emulate PSP, forcing the Pi to run in 720p isn't an option for me.
            • mYSt
              mYSt Theme moderator @Madmeggo last edited by
              @madmeggo said in Next Pixel theme:
              Hello and thx for your feedback
              Unfortunatly 1080p won't work with PI4 no matter which ram version you use. As far as i know setting 720p for emulationstation won't set your emulator version so you can still run psp emulator with a different resolution.
              Madmeggo lhari84 3 Replies Last reply Reply Quote 0
              • Madmeggo
                Madmeggo @mYSt last edited by
                This post is deleted!
                • Madmeggo
                  @myst Thank you for your answer!
                  When I force Emulationstation to run in 720p, will I still be able to switch to CRT mode via my RGB-Pi cable or the RGBDual? Or does the "forced resolution" interfere with this?
                  • lhari84
                    lhari84 @mYSt last edited by
                    @myst Is there any known reason why even Pi 4 has issues with 1080p theme? Just have scraped everything for 1080p and having major issues, especially:
                    • Backgrounds in system overview (both wheel and horizontal view, does not matter) aren't sometimes loaded or loaded very slowly (black background in the meanwhile).
                    • Glitches when switching between systems/gamelists.
                    I thought the problem is be gone with Pi 4 (4 GB), so I have implemented it without too much reading before. Unfortunately it's not. Very disappointing 😥
                    Hope ES will be further optimized, I can't imagine Pi 4 isn't powerful enough to display that kind of content without issues. The cause can't be the amount of memory...
                    Pi 4:
                    Pi Zero 2W:
                    mYSt Bkg2k 2 Replies Last reply Reply Quote 0
                    • Glascoyote 0
                      Glascoyote 0 last edited by
                      Hello
                      I installed Next Pixel Theme on my Recalbox 8.0 Electron, but it does not save my Configuration changes. Only the Design "1A" is displayed in every Sub Menu, after a performed new start of the box.
                      My scraped Images are displayed to big to fit in the square in the middle. The square is overlayed but you can see a thin black line in every picture.
                      Can you tell me how I can fix this?
                      Thank you!
                      • mYSt
                        @madmeggo I can't tell sorry maybe @Bkg2k or @digitaLumberjack may be helpful
                        • mYSt
                          @lhari84 Indeed the problem is not memory quantity but how ES is build so 2,4 or 8 go memory is the same and it's still recomanded to use 720p/480p for pi user
                          A new optimized version is on its way but need to be patient 😉
                          • mYSt
                            mYSt Theme moderator @Glascoyote 0 last edited by
                            @glascoyote-0 Hello, check this part of documentation https://github.com/SamYStudiO/es-theme-next-pixel#scraping--next-pixel-mix and espcially the last phrase if you don't want to use next pixel mix
                            • Bkg2k
                              Bkg2k Staff @lhari84 last edited by
                              @lhari84 ES issues regarding picture resolutions are related to the GPU memory which is limited to less than 512Mb whether you have 1, 2, 4 or even 8Gb on the board. That's why we say that running Recalbox on more than 2Gb is useless.
                              Nevertheless, we're already working on the FrontEnd to rewrite all the picture management code, but it's a long and hard task, don't expect changes in the next weeks.
                              lhari84 1 Reply Last reply Reply Quote 2
                              • lhari84
                                lhari84 @Bkg2k last edited by lhari84
                                @bkg2k @mYSt
                                Thanks for info, great to read that there is a chance for future optimization! 👍
                                In the meanwhile I realized the issue regarding graphics memory vs. general memory. Tried to increase graphics memory to more then 512 MB in boot.txt and the system did not boot anymore 😳 So I have set it to 512 MB now. Too bad that the Pis are limited in this way.
                                Pi 4:
                                Pi Zero 2W:
                                Eternity57 1 Reply Last reply Reply Quote 0
                                • Eternity57
                                  Eternity57 @lhari84 last edited by
                                  @mYSt I confirm I've currently setting up an arcade cabinet based on Pi 4 8Go & NVMe high speed 480go disk (on argon one v2 case) with Recalbox and Next Pixel theme in 1080 and I've got :
                                  • Screen loading issue with white blinking page during few seconds before loading screen on each gaming console with 512 gpu memory
                                  • Having more than 512 on gpu memory and the system didn't load anything
                                  Side intels, I have render all jpeg image of the theme with jpegmini pro tool to get image with same quality but even lighter (gain 33% in this particular case which means they are already well coded) to ease memory consumption or even loading time but it didn't change anything.
                                  Waiting on all further improvements from Recalbox or Next Pixel team to get this awesome theme working well on Pi4 🙂
                                  Keep up your impressive work ! I will looking forward to it 🙂
                                  • mYSt
                                    mYSt Theme moderator @Eternity57 last edited by mYSt
                                    @eternity57 Thx for your feedback
                                    Indeed changing image weight has no impact, if you want to have an impact you need to change image size/resolution, GPU doesn't care about weight but about pixels count
                                    That's why i have different resolutions available for the theme, PI user should use 720p or 480p as mentionned from the documentation
                                    Eternity57 lhari84 2 Replies Last reply Reply Quote 1
                                    • Eternity57
                                      Eternity57 @mYSt last edited by
                                      @myst Make sens !
                                      By the way when blinking, I see the background image loaded 3 to 6 times but always blinking to white in the first seconds then after 3-5 seconds of white page then it comes to the image...
                                      Would it be possible, it is a script loop issue ? because from a user point of view the image load immediatly on the first second... blink to the white then redo this 3 to 6 times fade to white and after 3 to 5 seconds load and stay at screen.
                                      To investigate, hoping it could help you 🙂
                                      • mYSt
                                        @eternity57 I can do nothing from theme side unfortunately, recalbox team is working on it but will take time
                                        Eternity57 1 Reply Last reply Reply Quote 1
                                        • Eternity57
                                          @myst No problem it work perfectly on 720p and we almost even notice any difference from 1080. Your theme is really a game changer on an arcade cabinet ! Thank again.
                                          • lhari84
                                            @myst @Bkg2k
                                            It seems with the update to 8.0.1, switching whole system to 720p will not work anymore.
                                            As usual, I use following parameters:
                                            hdmi_group=1
                                            hdmi_mode=4
                                            in /boot/config.txt
                                            But Recalbox boots up in 2160p at 30Hz since the update to 8.0.1, no matter if parameters in config.txt exist, or not.
                                            That's strange in a second way, I thought default configuration for Pi(4) should make it boot up with 1080p, but never ever with 2160p - even when the connected display supports it.
                                            My current screen configuration is nothing special, a 27'' 2160p LCD monitor, connected by HDMI.
                                            Pi 4:
                                            Pi Zero 2W:
                                            100.8k
