    [Recalbox 9] Theme Next Pixel
    Themes & Interface
    theme recalbox 9
    148
    783
    1181211
    • mYSt
      mYSt Theme moderator @ismanu last edited by mYSt
      @ismanu Hello
      5/4 format (1280*1024) is not supported by this theme. This theme supports 16/9 et 4/3 formats only (with different resolutions)
      ismanu 1 Reply Last reply Reply Quote 0
      • ismanu
        ismanu @mYSt last edited by ismanu
        @myst oohh that explain a lot! Thanks, i will try to buy another screen...
        • ismanu
          hi,
          so... no second hand's 720p monitor near my place... so i ve two choices...
          • buy an expensive new one 😞 gloops my bartop will be very expensive at the end, bad WAF lol
          • fix the theme, i m software developer so ...
          ...so i decide to fixed the theme for VGA screen of 1280x1024 size.
          i've create a new gamelistview called :
          4A-1280x1024 with next pixel mix
          alt text
          and i ve fix the video size, improve a lot of changes :
          • reduce and move the photo mix
          • reduce the fontsize of description and increase the textarea
          • move the item description of the game
          alt text
          alt text
          i ll improve the render, that was just a raw test
          mYSt 1 Reply Last reply Reply Quote 0
          • mYSt
            @ismanu Nice try!
            The mix looks a bit small and the list selection background is cutoff (should go under the the left part)
            To go further i would like to make it compatible to 5/4 as i think this is the most used ratio after 16/9 and 4/3. Problem is adding a ratio is a huge work behind the scene, not to make it works but each time a new game theme is added this is a pain. So i have no plan for now adding it.
            Which ratio have you download for your first try?
            If you tried with 16/9, you should give it a try with 4/3, without making any change it may be ok, worth a try.
            • ismanu
              hmm i ve just read quickly the theming doc, i m not an expert lol
              "The mix looks a bit small and the list selection background is cutoff (should go under the the left part)"
              i never see the real layout... but i just saw your original screenshoot in the first post, i ve a base for play with, i ll made a best portage.
              "Which ratio have you download for your first try?"
              not sure of your question lol, i ll try to answer that : your 720p theme (?)
              or that: <resolution>1280 1024</resolution>
              or that: i ve use the "1b-standard with other mixes" as base and duplicate (by security) [common/common_description/common_info]_1280_1024.xml for isolate my tests
              "Problem is adding a ratio is a huge work behind the scene, not to make it works but each time a new game theme is added this is a pain. So i have no plan for now adding it."
              yeah, i saw all the directories, not sure to understand actually the complete structure and heritage but yeah a huge work!
              A layout editor with drag n drop can be a solution... but, you know that, time is time ...
              i ll polish the 5/4 and submit you the changes if you want
              • mYSt
                @ismanu said in Next Pixel theme:
                You seems to have download the 720p (16/9) version for your 5/4 ratio, before going any further you should give a try to the CRT version (4/3) which is a closer match to 5/4, this will certainly not be perfect bu maybe good enough without having much to adjust.
                Also note using 16/9 you end up with image characters being cutt off like sonic from your screnshot, this will be less a pb with 4/3 version
                • mYSt
                  mYSt Theme moderator last edited by mYSt
                  [ENGLISH]
                  Hey Shall we have an update along with Recalbox 8.0 beta?
                  You've been waiting for it... for a long time...
                  Here it is Next Pixel v2 available in beta as well for Recalbox 8+ only!
                  New features for this release :
                  • more game theme with original artworks
                  • game theme are now random at each Recalbox start
                  • all text are now translated
                  Enjoy, I'm waiting for your feedback!
                  [FRANCAIS]
                  Hey il n'y aurait pas une mise à jour du thème avec la beta 8.0 de Recalbox?
                  Vous l'avez attendu... longtemps...
                  Voici enfin Next Pixel v2 disponible en version beta également.
                  Les points clé de cette nouvelles version :
                  • encore plus de theme de jeux uniquement avec des artworks officiel d'époque
                  • les theme de jeux sont aléatoire et changent à chaque démarrage de Recalbox
                  • les textes sont maintenant traduit dans différentes langues
                  Enjoy, j'attend vos retours sur cette nouvelle version!
                  text alternatif
                  text alternatif
                  text alternatif
                  text alternatif
                  text alternatif
                  16/9 1080p
                  https://www.dropbox.com/s/mhmsazmsnexz0am/es-theme-next-pixel-v2.0-SNAPSHOT-16x9-1080p.zip?dl=0
                  16/9 720p
                  https://www.dropbox.com/s/9f17cg5w5xqccjq/es-theme-next-pixel-v2.0-SNAPSHOT-16x9-720p.zip?dl=0
                  16/9 480p
                  https://www.dropbox.com/s/crawwmv31v2fguc/es-theme-next-pixel-v2.0-SNAPSHOT-16x9-480p.zip?dl=0
                  4/3 768p (écran CRT)
                  https://www.dropbox.com/s/zcu4y11ym8l94qm/es-theme-next-pixel-v2.0-SNAPSHOT-4x3-768p.zip?dl=0
                  4/3 240p (GPICase et autres petits formats 4/3)
                  https://www.dropbox.com/s/1kqlslziakrthf4/es-theme-next-pixel-v2.0-SNAPSHOT-4x3-240p.zip?dl=0
                  CHANGELOG
                  • Add bbcmicro support
                  • Add trs80coco support
                  • Add ti-994a support
                  • Add lowresnx support (but no game theme)
                  • Add videopacplus support
                  • Add bk support
                  • Add vic20 support
                  • Add supervision support
                  • Add auto-lightgun support
                  • Add pcv2 (pocket challenge v2) support (but no game theme)
                  • Add pico8 support
                  • Add scv (super cassete vision) support
                  • Add model3 support
                  • Add auto-board game themes
                  • Add auto-casino game themes
                  • Change most game themes to better match game box/artwork/music at the time game was released
                  • Normalize images with a light drawing styling
                  • System game themes are now randomly displayed when Recalbox start
                  • System info now use Recalbox language setting to display info in your language (only if translation is available, otherwise fallback to english translation)
                  • Remove random system support as it is not maintained anymore by its creator
                  • Musics are now using mp3 format instead of ogg
                  • Rework project structure
                  • Behind the scene :
                    • Rearrange theme files structure to better handle random game themes display
                    • Rearrange all PSD files to make it easier adding new game theme
                  Butch Games 1 Reply Last reply Reply Quote 5
                  • KoCinsKy
                    KoCinsKy last edited by KoCinsKy
                    I have installed the new version and the background screenshots of the theme cannot be seen, it is all black. What could be the problem?
                    I use 16/9 1080p
                    Akkeoss 1 Reply Last reply Reply Quote 0
                    • Akkeoss
                      Akkeoss Staff @KoCinsKy last edited by
                      @kocinsky Hello, for the moment we advise to use the 720p version. There are some issues with the 1080p one. The problem will be corrected in the next UI. Play Again 😉
                      Site web : https://www.recalbox.com
                      Discord : https://discord.gg/NbQFbGM
                      Twitch : https://twitch.tv/recalbox
                      KoCinsKy 1 Reply Last reply Reply Quote 0
                      • KoCinsKy
                        KoCinsKy @Akkeoss last edited by
                        @akkeoss Thx but i have same problem with 720p version. 😲
                        • mYSt
                          mYSt Theme moderator @KoCinsKy last edited by mYSt
                          @kocinsky Hello, are yoy using recalbox 8? Have you installed it in the right folder (check you haven't install in theme/nextpixel/nextpixel/...)
                          • KoCinsKy
                            KoCinsKy @mYSt last edited by
                            @myst Recalbox 7.2.2, is this the problem?
                            • mYSt
                              @kocinsky yes only for 8+
                              • marwin91
                                marwin91 last edited by
                                Pour une TV CRT en 240p il faut prendre la version "4/3 240p (GPICase et autres petits formats 4/3)" ?
                                Raspberry pi4 4go/Argon One M2 v2/Recalbox RGB DUAL/8bitdo SN30 Pro/Recalbox 8.1.1 CRT/B&O MX7000 1.0
                                • Akkeoss
                                  Akkeoss Staff @marwin91 last edited by
                                  @marwin91 j’aurais tendance à dire oui 🙂
                                  marwin91 1 Reply Last reply Reply Quote 0
                                  • KoCinsKy
                                    @myst ok thx! I Will wait for 8.0.
                                    • marwin91
                                      marwin91 @Akkeoss last edited by
                                      @akkeoss J'aurais aussi tendance à croire cela mais la mention "et autres petit format" me fait douter 😉
                                      • Akkeoss
                                        @marwin91 Pour moi, je ferai le test 🙂
                                        • mYSt
                                          Hello and welcome Recalbox 8.0!
                                          Next Pixel v2 for recalbox 8.0 is available right now, check initial post for all informations.
                                          Enjoy!
                                          Hello and bienvenu à Recalbox 8.0!
                                          Next Pixel v2 est disponible dès maintenant pour Recalbox 8.0, le post initial est à jour avec toute sles infos nécessaires.
                                          Amusez vous bien!
                                          Hola y bienvenido Recalbox 8.0!
                                          Next Pixel v2 esta disponible ahora mismo para Recalbox 8.0, todas las informaciones estan disponibles en el primero mensaje.
                                          Disfruta!
                                          1 Reply Last reply Reply Quote 3
                                          • Run
                                            Run last edited by
                                            Salut à tous,
                                            Tellement heureux que cette v2 soit enfin sortie! Un IMMENSE merci pour ton travail!! Bravo
                                            Et maintenant voici venu le moment du SAV...
                                            J'ai fait la mise à jour de la 7.2.2 vers la 8.0 sans aucun problème, tout fonctionne parfaitement... sauf le thème qui ne sort ni les images ni les musiques. L'OS se lance en version dégeulasse genre "mode sans échec" sans image ni son, il n'y a que le texte en noir et blanc.
                                            J'ai du rater quelquechose...
                                            Est-ce que quelqu'un rencontre le même problème?
                                            Pour info, je suis sur PC (Nuc) et j'essaye d'installer la v2 (la vraie, pas la béta sortie ces derniers jours) en version 720p.
                                            Merci pour vos retours
                                            Rémi mYSt 2 Replies Last reply Reply Quote 0
                                            100.8k
