    [Recalbox 9] Theme Next Pixel
    Themes & Interface
    theme recalbox 9
    148
    783
    1180150
    • mYSt
      mYSt Theme moderator last edited by
      Let's celebrate Recalbox 6.0, Next Pixel 1.0 is out today!
      It's been a long way to get here, didn't thought i 'll do that much work with this theme but here we are it's time to release 1.0 with all systems now supported. This release was focused on fine tuning, i modified some existing game themes as well (imageviewer now have its own image, atari5200/lynx have a new game theme, ...). I moved some files from system folders so it's now easier to move a game theme to another system (check documentation).
      For Raspberry users i added a new 480p package that should work well if you're using a lot of systems to avoid memory issues (of course images will look less sharp but i'm using a 4K screen monitor and i can tell you it's still ok for me with 480p images).
      Enyoy!
      Changelog
      • Add channelf support
      • Add oric support
      • Add to8 support
      • Add lots of custom rating icons matching system game theme (some already done may have changed as well)
      • Change atari5200 game theme
      • Change lynx game theme (old one still available as alternative)
      • Change imageviewer (screenshots) theme so it has now a different one from favorites
      • Change a bit favorites image
      • Fix some us/jp logos/controllers position from gamelist view
      • Merge several changes from recalbox next theme logos and game/consolegame images
      • Move rating icons to system root folder to make it easier to move game theme to another system (see doc to get more info)
      • Add 480p (16:9) package for raspberry users using lots of systems and having memory issues.
      Scavy lhari84 abunille 4 Replies Last reply Reply Quote 8
        Scavy Global moderator @mYSt last edited by
        @myst great job ! thanx 4 all the job i'll try it this evening ! 🐵
        • Bloodsurfer
          Bloodsurfer last edited by
          Thanks again for your amazing work!
          I'll install it tomorrow as soon as 6.0 is released. I'm still very happy with your theme, really loving it!
          • Kintao
            Kintao last edited by
            Merci beaucoup!
            • lhari84
              lhari84 @mYSt last edited by
              @myst A big THANK YOU for doing this great job!! will install it this evening too 🙂
              Pi 4:
              Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
              Pi Zero 2W:
              GPi Case 2W, Recalbox 9.0
              • lhari84
                Hi @myst, now i did following to optimize both quality and memory consumtion on pi:
                i merged 480p version with just main backgrounds from 720p version (background.jpg, background_legacy.jpg and background_wheel.jpg).
                can't see much difference in gamelist view and so on, but have the beautiful backgrounds in high-res in system overview then.
                if you like my idea, maybe you can use it for a future "pi hq memory saving version"? 😄
                Pi 4:
                Pi Zero 2W:
                • lhari84
                  lhari84 last edited by
                  @myst
                  too be precise, i did vice versa: i used 720p version and changed all files of systems i use to 480p version. - except: background.jpg, background_legacy.jpg and background_wheel.jpg
                  Pi 4:
                  Pi Zero 2W:
                  • abunille
                    abunille @mYSt last edited by
                    @myst
                    Really a fantastic work, thank you for sharing this amazing theme.
                    @OyyoDams
                    It's time for an Themer award 😉
                    1 Reply Last reply Reply Quote 3
                      I tried the 480p theme it's already amazing. Good work ! Only missing a few musics by a former amiga musician lol
                      • mYSt
                        mYSt Theme moderator last edited by mYSt
                        Thx for your feeback guys!
                        @lhari84 said in Next Pixel theme:
                        I must say i was thinking about it since gamelist view images are darker they could have a lower resolution. I need to think more about it to make a decision though, but nice catch!
                        @scavy said in Next Pixel theme:
                        I'm still opened for discussion when you have time 😉
                        Last but not least i forgot to thank @paradadf for all my inital post editing 😉 and his work for console/controller images and of course recalbox team fot his amazing work on recalbox 6.0!
                        • lhari84
                          @mYSt
                          I have one more question about copying one system to another one:
                          in which file are graphics for game rating stored?
                          and is there a special graphic for pcenginecd (related to castlevania?)
                          currently after copying suggested files from manual from pcenginecd to pcengine, i just see hearts as rating graphics. and i guess they come from game bonk (pcengine) and not castlevania (pcenginecd)
                          Thanks
                          Pi 4:
                          Pi Zero 2W:
                          mYSt 1 Reply Last reply Reply Quote 0
                          • mYSt
                            mYSt Theme moderator @lhari84 last edited by
                            @lhari84 rating files are located in system folder along with background images (icon_empty.svg, icon_filled.svg). Pcenginecd game theme has no custom rating files , it uses default "star" image, so it weird you still got heart icon from pcengine. These are 2 problems i can think of:
                            • You have copy data folder from pcenginecd along with files (but you should see wrong logo/console images as well)
                            • You are not using the last theme version since before 1.0 rating images where located in system/data folder
                            lhari84 1 Reply Last reply Reply Quote 0
                            • lhari84
                              @myst I guess it‘s because i just copied backgrounds and sound. did not want to replace too much, as i didn‘t want system pictures, etc. change to pcenginecd. i‘ll try, thanks for info.
                              as these rating files are so small, i’m wondering even more about a weird problem i still have: when i quit an emulator, ONLY these rating graphics are white blocks for a short time sometimes... after not more than one second when left emulator, they are shown properly again. on the other hand no problem with other, big graphics like backgrounds. so can‘t be a memory issue all. maybe an es-thing?
                              it‘s the only disturbing issue left, everything else is fine now, both with theme 1.0 and rb 6.0. maybe @paradadf has an idea?
                              Pi 4:
                              Pi Zero 2W:
                              mYSt paradadf 2 Replies Last reply Reply Quote 0
                              • goroots
                                goroots last edited by
                                Super thème magnifique et avec la résolution 480p c est génial aucun plantage pour l instant sur le pi3b+ overclocké a 1.450. Je ferai quand même des test avec les résolutions 720p et 1080p. On sait jamais hehehehe en tout cas magnifique travail 😍
                                Pi3b+ sd Samsung 32gb + clef sandisk 256gb.
                                Theme next pixel 480p.
                                Xbox 360+adaptateur Microsoft, ds4, xbox one filaire, 8bitdo nes pro+arcade, 2 Wiimot gun avec dolphin bar, Clavier sans fil viboton.
                                • mYSt
                                  I guess quiting game is resource heavy for CPU so it may take time to construct some assets. Can't say much more about it sorry.
                                    paradadf Staff @lhari84 last edited by paradadf
                                    @lhari84 it is still possible that it is a memory issue. You could try reducing the number of available systems. Otherwise, no idea!
                                    • Fab2Ris
                                      Fab2Ris Staff last edited by Fab2Ris
                                      Could be great to think about EDIT EACH FIRST THEME POST to indicate before anything... witch version of Recalbox is compatible with this theme.
                                      Like : TESTED/Works on Recalbox 6.0 RC2 (DATE OF TEST)
                                      And edit the post title, for exemple : THEME : Next Pixel (OK Recalbox 6.0, April 15), or THEME : Next Pixel (Recalbox 18.xx.xx OK, Recalbox 6.0 WIP)
                                      This information must be on the name of the theme + topic, to see if there is update avaiable for theme's users.
                                      And on the other hand, it's very important, to see if there is all systems supported, and not particular problem...
                                      What do you think about ?
                                      Tuto Maker et Community Manager de Recalbox (Facebook/Twitter/Instagram/YouTube...)
                                      • mYSt
                                        mYSt Theme moderator @Fab2Ris last edited by
                                        @fab2ris Hello Fab, nice catch since common questions are " is this theme compatible with...", "are all systems supported...", but this has to be done with mods since we can't edit our own post (which i can understand of course)
                                        Fab2Ris 1 Reply Last reply Reply Quote 0
                                        • Kintao
                                          Hello,
                                          encore merci pour ton thème!
                                          Est il envisageable que tu ajoutes pour Mame et fba libretro, un logo "Arcade" pour éventuellement les renommer manuellement?
                                          Comme les fonds d"écrans supplémentaires que tu proposes pour certaines consoles?
                                          • mYSt
                                            mYSt Theme moderator @Kintao last edited by
                                            @kintao hum je sais pas trop à la limite si tu as un logo arcade sous la main tu peux me l'envoyer en privé je te générerais les 2 logo qu'il faut pour le thème à partir de celui-ci
                                            100.8k
