    [Recalbox 9] Theme Next Pixel
    Themes & Interface
    theme recalbox 9
    148
    783
    1180164
    • mYSt
      mYSt Theme moderator @mYSt last edited by
      @Kintao forgot what i said i'll add something for next release... 😉
      • Kintao
        Kintao last edited by
        @mYSt , top merci, j'avais pas eu le temps de voir ta réponse plus haut 🙂
        • Fab2Ris
          Fab2Ris Staff @mYSt last edited by
          @myst said in Next Pixel theme:
          ice catch since common questions are " is this theme compatible with...", "are all systems supported...", but this has to be done with mods since we can't edit our own post (whi
          J'ai fait remonter l'info/idée, pour plus de clarté ça serait important je pense.
          Tuto Maker et Community Manager de Recalbox (Facebook/Twitter/Instagram/YouTube...)
          • lhari84
            lhari84 @mYSt last edited by lhari84
            @lhari84 said in Next Pixel theme:
            when i quit an emulator, ONLY these rating graphics are white blocks for a short time sometimes... after not more than one second when left emulator, they are shown properly again.
            I guess quiting game is resource heavy for CPU so it may take time to construct some assets. Can't say much more about it sorry.
            Maybe I'm kind of too perfectionist, but I want better disable whole rating bar, as I can't get rid of this issue 😄
            Is there a way to just hide it? tried already some code modifications but always crashed the theme/es...
            Pi 4:
            Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
            Pi Zero 2W:
            GPi Case 2W, Recalbox 9.0
            mYSt 1 Reply Last reply Reply Quote 0
            • mYSt
              mYSt Theme moderator @lhari84 last edited by
              @lhari84 Sure from this file
              replace
              <rating name="md_rating">
              <origin>1 .5</origin>
              <size>0 .037</size>
              <pos>.718 .29</pos>
              </rating>
              with
              <pos>2 2</pos>
              </rating>
              • lhari84
                lhari84 last edited by lhari84
                @mYSt as always, works fine! thx 🙂
                Pi 4:
                Pi Zero 2W:
                • DINHO
                  DINHO last edited by
                  Recalbox 6.0 crash theme?
                  • Kharr
                    Kharr last edited by
                    Very nice theme thank you !
                    • M3ph1st0
                      M3ph1st0 last edited by
                      Merci beaucoup pour ce super theme, magnifique et tres simple à modifier, à part pour les logos de la roue, vraiment excellent, j'adore 😉
                      Par contre petite question sans rapport direct, mais tu pourrais me dire quel mix tu utilises pour scrapper tes jeux ? J'adore le design avec l'ecran de console différent pour chaque systeme, mais je ne l'ai pas trouvé ^^
                      mYSt 1 Reply Last reply Reply Quote 1
                      • greatxerox
                        greatxerox last edited by
                        salut !
                        j'ai actuellement le thème Alekfull1 qui est très bien
                        a propos de Next Pixel theme, j'aimerais savoir s'il ne pose pas de problème pour Recalbox v6-dragonblaze.
                        j'ai un écran 16/10.
                        voilà 🙂
                        merci
                        Raspberry Pi 3B
                          Scavy Global moderator @greatxerox last edited by Scavy
                          @greatxerox Non je l'utilise chez moi, aucun bug avec la version 6.0. Excellent thème.
                          1 Reply Last reply Reply Quote 3
                          • DINHO
                            is running on version 6.0 of the recalbox? Are all systems ok?
                              Scavy Global moderator @DINHO last edited by
                              @dinho Theme is installed at home, totally stable on V6.0 OS
                                @mYSt
                                je me suis décidé à tester ton thème sur :
                                • rpi3b+
                                • samsung tv 4k
                                • mode hdmi et configuré en mode gaming.
                                • microsd 16 Go
                                • alimentation 5V 2.5A
                                J'ai choisi le thème 720p, par défaut il est sur mode carroussel, je l'ai mis en mode horizontal.
                                Et j'ai un truc étrange sur les logos
                                certains sont petits (N64) et d'autres sont hyper gros (neogeo)....
                                Est ce normal ? c'est un bug ?
                                as tu besoin de capture d'écran ?
                                edit @mYSt
                                voici des captures d'écran
                                • makination
                                  makination last edited by
                                  I LOVE THAT THEME. Many thanks! More pixeled images to choose in each system would be GREAT!
                                  • mYSt
                                    mYSt Theme moderator @acris last edited by
                                    @acris C'est normal il n'est pas vraiment plus gros il est plus large, tous les logos font exactement la même hauteur seule la largeur est variable
                                    • mYSt
                                      mYSt Theme moderator @M3ph1st0 last edited by
                                      @m3ph1st0 J'utilise Skraper
                                        @mYSt
                                        Hmmm ouep ça me gène dommage, du coup tant pis je reste avec un autre theme.
                                        • mYSt
                                          @acris Si jamais tu as des versions "larges" de certain logo pour la wheel (de tête y'a le n64 et playstation et surement d'autres), suffit de renplacer le logo par le logo_right dans le dossier data du dossier système
                                          Manoot 1 Reply Last reply Reply Quote 1
                                          • Manoot
                                            Manoot @mYSt last edited by
                                            @myst super thème merci beaucoup. Petite question, j'ai vu que tu utilisais skraper, mais comment fais tu pour scraper le genre du jeu, par exemple plate-forme, aventure, etc. Avec xml univeral c'est bon, mais skraper il ne me mets rien ce qui fait que dans la ligne ou le genre devrait apparaître je n'ai rien...
                                            Seconde question, aurais-tu un dossier arcade ? Quelque chose d'un peu plus brut. En fait mes jeux fba libreto sont que des jeux de combats et j'aimerais avoir quelque chose de plus fight plutôt que donkey Kong (qui est très bien). J'ai déjà la musique et comme je n'ai pas ta base photoshop je ne peux pas vraiment créer d'image moi-même ou alors sans respecter la ligne de conduite de ton thème. Merci beaucoup.
                                            goroots mYSt 2 Replies Last reply Reply Quote 1
                                            100.8k
