    Raspberry Pi 3B+ (Plus) - Compatible?
    59
    230
    269382
    • Marcos Filipe Pereira
      Marcos Filipe Pereira last edited by Marcos Filipe Pereira
      I just bought my RP 3 B + put the latest Recalbox and did not work( no booting). 😞
      Do you know if there is a way to make it work ?
      Thanks!
        acris @Substring last edited by acris
        @Marcos-Filipe-Pereira
        you need to wait an update major of recalbox. thank you for reading all the answers of this topic
        @substring said in Raspberry Pi 3B+ (Plus) - Compatible?:
        @gkralicek2 it's not a noobs problem, it's a firmware + kernel problem. Recalbox img most probably can't boot for these reasons. And for noobs : we're not yet compatible as we need the new board's id
        • simba51
          simba51 last edited by
          @acris said in Raspberry Pi 3B+ (Plus) - Compatible?:
          Hello, do you have an approximate date a major update to have support for RPi 3 B +?
          Cartes RPi Zéro 2 W - RPi Zéro W - RPi400 - RPi 4/4Gb - RPi 3b - RPi 3b+ - RPi 3 a+
          Stockage 16Gb Sandisk, 32Gb Samsung et clé usb 64Gb & 128Gb
          2 manettes PS3 Freegun Bluetooth - 2 manettes 8BitDo SF30 Pro Bluetooth
          OyyoDams 1 Reply Last reply Reply Quote 4
            OyyoDams Staff @simba51 last edited by
            @simba51 sorry no date will be given.
            • simba51
              Thank you for your reply. I'll be happy then ...
              • Ratte
                Ratte last edited by
                No date? Then it can only be hours..... 😉
                joking
                Did you allready tried to compile a 64 bit version for test purposes?
                BR
                André
                •Raspberry Pi model: Pi ZeroW
                •Raspberry Pi model: Pi 3B @ 1350/500/500 MHz
                •Raspberry Pi model: Pi 3B+ @ 1550/500/500 MHz
                  Substring @Ratte last edited by
                  @ratte said in Raspberry Pi 3B+ (Plus) - Compatible?:
                  On pi ? What for ? They hardly support 64bits
                  • lhari84
                    lhari84 @kazki last edited by
                    @kazki
                    In my point of view it's not really necessary to store ROMs on an external USB drive.
                    I've included whole "share" directory (containing ROMs, BIOS files, etc.) to my backup script. So if I have to reinstall Recalbox, I simply copy back needed files from my backup storage to new Recalbox installation.
                    If my microSD card breaks of any reason, as the same can happen with external USB drive, I can also use this backup. (Good because I've spent days to optimize gamelists, ROMs, etc.)
                    Adding/removing content using network share is also quite comfortable, at least by using LAN connector instead of WiFi. Same with editing gamelist metadata directly by using an editor - here the only annoying thing is having to stop/start emulationstation in shell each time.
                    Pi 4:
                    Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
                    Pi Zero 2W:
                    GPi Case 2W, Recalbox 9.0
                      voljega Banned @lhari84 last edited by
                      @lhari84 said in Raspberry Pi 3B+ (Plus) - Compatible?:
                      No it's not, especially for bigger games like PSX or Dos games
                      lhari84 1 Reply Last reply Reply Quote 0
                      • lhari84
                        lhari84 @voljega last edited by
                        @voljega
                        ~ 30 seconds for moving an average sized PBP-image of PSX game.
                        ~ 50 seconds for an uncompressed CD ISO.
                        That's not too bad... Maybe if your collection is >128 GB, but for mine I'm happy using LAN.
                        Pi 4:
                        Pi Zero 2W:
                        Apoc 1 Reply Last reply Reply Quote 0
                        • Apoc
                          Apoc @lhari84 last edited by
                          @lhari84 I do too. I only use lan to put roms on my recalbox. PSX games included. That's perfect 🙂
                          • Lukree
                            Lukree last edited by
                            D**n. I just ordered a Pi 3B+ from PiHut with controllers and of course - it's not yet supported... Getting only the rainbow screen with the lightning symbol, I guess that's normal?
                            Eagerly anticipating for an update. 😐
                            maxmoro77 1 Reply Last reply Reply Quote 1
                            • maxmoro77
                              maxmoro77 @Lukree last edited by
                              @lukree said in Raspberry Pi 3B+ (Plus) - Compatible?:
                              Even my RPi 3B+ has been waiting for 2 weeks! 😢😢
                                Let me state it clearly : its a matter of several weeks. Although it does work fine (but psp), we can't make a release yet as we can't manage updates yet. It will have to go through some.public testing along with a major system update (including kodi 17). So please don't be impatient 😉
                                maxmoro77 hex12 2 Replies Last reply Reply Quote 1
                                • maxmoro77
                                  maxmoro77 @Substring last edited by
                                  Ok substring, thanks for the clarity! Good job then! 👍
                                  • hex12
                                    hex12 @Substring last edited by hex12
                                    @substring just a question, for my curiosity if you can answer of course. What are the major improvements that you are planning for next Recalbox release? Give us a spoiler on that 🙂
                                      Substring @hex12 last edited by
                                      @hex12 the next release (tomorrow) is only bugfixes. Then, nothing much emulation related for now, mostly technical crap. As for now i'm working on the tinkerboard, i guess it's 80% done
                                      hex12 lhari84 2 Replies Last reply Reply Quote 1
                                      • hex12
                                        @substring newer emulator version are in plan? i am not telling about new platforms (systems) but new version of existing included emulators, like for PSP or Amiga or i don't know... And Thinkerboard will support same platform of Raspberry or also 3DO?
                                          @hex12 regarding emulators update, mame2010 for sure, no idea for others. Probably rollback ppsspp as it gives many errors to people.
                                          The roadmap is not done, this all depends on our free time.
                                          voljega hex12 2 Replies Last reply Reply Quote 0
                                            voljega Banned @Substring last edited by
                                            @substring what is the update for mame2010 ?
                                            101.0k
