    Raspberry Pi 3B+ (Plus) - Compatible?
    59
    230
    269398
      Substring @voljega last edited by
      @voljega hiscores update
      • lhari84
        lhari84 @Substring last edited by
        @substring
        Can you please refine upon "work fine (but psp)"?
        What I want to ask is, if you can see a visible perfmance increase on RP3 B+, for example when emulating N64, PSX (upscaled) and DC? If yes, also without overclocking?
        Still not sure if I should buy the new Pi to replace the good old RP 3 B when new Recalbox version is out.. So this info really would help for a decision.
        Many thanks in advance and as always: Great job!
        Pi 4:
        Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
        Pi Zero 2W:
        GPi Case 2W, Recalbox 9.0
        Substring gkralicek2 2 Replies Last reply Reply Quote 0
          Substring @lhari84 last edited by
          @lhari84 so far only one person made some serious tests in the team and reported better performance. Still, i don't recommend you buy one as it would just sit on a shel for now if you just bought it for recalbox
          lhari84 1 Reply Last reply Reply Quote 0
          • hex12
            hex12 @Substring last edited by hex12
            @substring and as for tinker board? Can you please indicate which systems will be supported? In particular, i wished to know about Amiga, C64, 3DO and Saturn as i think that "based systems" such as SNES, Neo Geo, Megadrive, MAME etc will be supported with this new platform. I am really interested in tinker board because it seems powerful and good tests i could find for PSX and N64, but i wished a more clear look at it before deciding to buy or not, as i should buy it only for RecalBox. Thank you.
            • lhari84
              @substring
              Yeah, but I'm sure you will get it running, so I could buy it to be ready in some weeks or maybe months 😄
              But another thing, is it maybe better to wait for and switch to Tinker Board? I've just read that you are working on a version and it made me curious...
              Will there be any disadvantage in comparison with Pi version?
              Does it emulate much faster than the Pi, maybe with a recent Linux Kernel? (I think the old Kernel is one of the major problems for example on Odroid, if i understood correctly)
              Pi 4:
              Pi Zero 2W:
              • gkralicek2
                gkralicek2 @lhari84 last edited by gkralicek2
                @lhari84 Having tried the latest beta version of retropie as well as a "homemade" patched version of recalbox (lacking network support though), i can say that emulation perf is the same with Pi 3 B+ at stock frequency compared to a pi 3 overclocked @1400 Mhz (provided you got a decent heat cooling on the Pi3). Even when pushed at 1.6Ghz, i haven't noticed any drastic improvement with the Pi3 B+ regarding emulation. DC might gain a few fps but still not running full speed. Same with N64.
                All in all what used to work perfectly with the Pi 3 still do with the new B+ and what used to be so-so still is in the same ballpark :). Status quo... Only real reason to switch from 3 to 3 B+ is the improved heat management and the better network transfer speed.
                  voljega Banned @hex12 last edited by
                  @hex12 amiga won't be on Tinkerboard
                  hex12 1 Reply Last reply Reply Quote 0
                  • hex12
                    hex12 @voljega last edited by hex12
                    @voljega there is not a version of amiberry for this board? It should be a pity...
                      @hex12 I correct myself, found references in their issues that it is now supported, but then it doesn't mean that it will work on Recalbox, we'll have to try (well @substring will have to try 😄 )
                        Yeah, anyway anything new means "subs can you dont ?"...
                          Regarding tinkerboard, i just finished compiling it yesterday, so calm down your horses all, still much to go
                          • hex12
                            @substring but which systems will be supported on tinker board compared to the ones supported in Pi3?
                              Substring @hex12 last edited by
                              @hex12 for now i simply removed advancemame and mame2010. Everything is like pi3 for now. Id on't think i'll include kodi on the first releases, this mostly depends on the perfs.
                              But, just so that you ubderstand that you are being a little too pushy : i couldn't test emulators yet. RA couldn't start in the beginning, nor ES. I got RA launching 2 days ago (didn't even try a game, too early) and could finally get ES to start late this night.
                              This all takes much time, you really don't seem to realize ...
                              • hex12
                                @substring that it takes a lot of time i realize, and your work is really great not only for tinker board, but for all recalbox that as for now is the best platform for me. I only was curious to know about this board which plans you were doing, as the board itself has a big power respect to Pi. I didn't want to put you in a hurry, just to understand the plans or the intentions. If my words brought to give another sensation i ask sorry for that, it was not my intention. I only wished to know if with the board and the emulators that actually are ported on it we could have the opportunity to play systems like 3DO that Pi actually can't play. Sorry again if my intentions appeared in a different way to you.
                                • eightkiller
                                  eightkiller last edited by
                                  @Substring I got a question for you ^^ Did you try to stream moonlight on 1080p 60fps on the new 3B+ (in your internal testing ?), if so, is it still not powerful enough to handle it and we will have to stay in 720p or might we have a good surprise ? 😛
                                    Substring @eightkiller last edited by
                                    @eightkiller errrrr ..... Have you missed the part where i said i don't have a 3b+ yet ? 😉
                                    eightkiller simba51 2 Replies Last reply Reply Quote 1
                                    • eightkiller
                                      eightkiller @Substring last edited by
                                      @substring haha indeed I did ^^ xD
                                      • simba51
                                        simba51 @Substring last edited by
                                        @substring said in Raspberry Pi 3B+ (Plus) - Compatible?:
                                        So, if you do not have a 3b + yet, it means that it will certainly wait, not a few weeks, but rather a few months to have a functional version of recalbox for this new rpi 3 b +? Did I understand your meaning?
                                        Cartes RPi Zéro 2 W - RPi Zéro W - RPi400 - RPi 4/4Gb - RPi 3b - RPi 3b+ - RPi 3 a+
                                        Stockage 16Gb Sandisk, 32Gb Samsung et clé usb 64Gb & 128Gb
                                        2 manettes PS3 Freegun Bluetooth - 2 manettes 8BitDo SF30 Pro Bluetooth
                                          Substring @simba51 last edited by
                                          @simba51 d**n please read the full topic ... I said pi3b+ is working on our side but ppsspp. Supporting the 3b+ is not just a matter of porting recalbox to it as it currently works just fine ! Beside ppsspp, there are other technical matters on the recalbox upgrade level to handle. Unless you want me to brick any upgrading pi or x86 (because this is what would happen for now if I push the work)
                                          • dizeLL
                                            dizeLL last edited by
                                            This post is deleted!
                                            101.0k
