    Raspberry Pi 3B+ (Plus) - Compatible?
    59
    230
    269380
    • Dragu
      Dragu Banned last edited by
      @Substring
      D'accord, mais pour Recalbox cela représente du travail pour vous, de nouvelles versions qui ne vont pas forcément apporter des avantages sensibles au niveau des jeux. Et avec tous ces intermédiaires, combien de versions différentes de Recalbox y aura t'il en 1923 ? Et à un certain moment il faudra obligatoirement prendre la décision quelle platforme encore maintenir. 🙂
      • barbudreadmon
        barbudreadmon @SkullGrin last edited by
        @skullgrin said in Raspberry Pi 3B+ (Plus) - Compatible?:
        having played around in overclocking Pi 3 to 1.37Ghz in Recalbox, i saw very little improvement. 200Mhz just isn't a substantial change.
        Is there any announcement about the fact rpi3b can't be overclocked ? Going from 1.37 to 1.4 is certainly not a big deal for most game, going from 1.37 to 1.57 is a big deal though.
        Btw, pi2 to pi3 was only 100Mhz improvement, 64bits was useless for emulation, and a lot of people have issues with onboard bt/wifi (which is no big deal either for emulation).
        Libretro developper :
        • FBAlpha FBNeo (Arcade)
        • Kronos (Sega Saturn/ST-V)
        • YabaSanshiro (Sega Saturn)
          voljega Banned @barbudreadmon last edited by
          @barbudreadmon I read someone wondering if pi3b+ weren't just stabilized pi3 with overclocking activated by default...
          • barbudreadmon
            barbudreadmon @voljega last edited by
            @voljega Perhaps @gkralicek2 could confirm if this new version accept OC ?
            gkralicek2 1 Reply Last reply Reply Quote 0
            • gkralicek2
              gkralicek2 @barbudreadmon last edited by
              @barbudreadmon Overclock works fine with new pi 3 B+ (i tested it briefly this afternoon with raspbian). I managed to achieve a 200 Mhz b*mp (from stock 1.4 Ghz to 1.6Ghz) without any problem on all of the 10 unit we got for test in the lab where i work. Idle temperature at 1.4Ghz is somewhere around 56-58 celsius and it climbs up to 68-70 once overclocked @1.6Ghz (which turns out to be closer to 78 degrees once a few stress tests are executed). Much better than the results i got with the original Pi 3 with copper heatsink when overclocked from 1.2 to 1.5 (which was slightly above 80 Celsius at times hence provoking random freezes).
              I'll try to do some more tests if i got spare time during the next few days trying to get close to 1.7 Ghz if possible (but as far as 1.6 gets me close to 80 degrees i'm afraid pushing more will end up in random freezes)
              ProfMielPops kelv Dark_Néo 3 Replies Last reply Reply Quote 3
              • ProfMielPops
                ProfMielPops @gkralicek2 last edited by
                @gkralicek2 Thank you, it's interesting
                • kelv
                  kelv @gkralicek2 last edited by
                  @gkralicek2 It's very good news. My previous rpi3 was frozen with 1340 MHZ. If this b*mp can make reach at least 1500 MHZ for me it's a success :). I ordered it soem days ago yet so let's wait for Recalbox to support it.
                  Raspberry Pi model: RPi 3b+
                  Recalbox build : 7.0.1 DragonBlaze
                  Hardware: MicroSD UHS 128 GB up to 80 MB, Class 10 and 2.5 A Power Supply.
                  Overclocked: 1485 MHZ
                  Controller(s): Wired Xbox 360 PAD (working perfectly on any other game/emulator).
                    voljega Banned last edited by
                    full test https://medium.com/@ghalfacree/benchmarking-the-raspberry-pi-3-b-plus-44122cf3d806
                    • Dark_Néo
                      Dark_Néo @gkralicek2 last edited by
                      @gkralicek2 Can you give me the values you used to get to that please
                      • mickaelm
                        mickaelm last edited by
                        Hi,
                        I received my first Pi 3B+ at the moment.
                        I tested with Recalbox 18.02.09, and I have a small icon "yellow sign electric" in the upper right corner of my screen, that's all.
                        I tested with raspbian 2018-03-13, and there my raspberry works, so it is not defective.
                        I think a new file is needed to support the new processor model...
                        Substring SkullGrin 2 Replies Last reply Reply Quote 0
                          Substring @mickaelm last edited by
                          @mickaelm i've been saying numerous times we are not yet compatible with it
                          Dessy 1 Reply Last reply Reply Quote 0
                          • SkullGrin
                            SkullGrin @mickaelm last edited by
                            @mickaelm Pi3B+ only came out a few days ago. Give it time.
                            • gkralicek2
                              gkralicek2 @Dark_Néo last edited by
                              @dark_néo
                              arm_freq=1600
                              gpu_freq=500
                              core_freq=500
                              sdram_freq=500
                              sdram_schmoo=0x02000020
                              over_voltage=4
                              sdram_over_voltage=2
                              With these, temp is very close to 80 degrees when running emulators like reicast for a while. But so far it held up well without freezing on most of the cards i tried.
                              Ratte 1 Reply Last reply Reply Quote 1
                              • Dessy
                                Dessy @Substring last edited by
                                @substring is there a way to edit the files to get it to work while it gets updated? as retropie works but wifi dodgy, keep up the good work its appreciated 🙂
                                  Substring @Dessy last edited by
                                  @dessy i'm not sure, i don't have a 3b+ myself. If it's just a dtb, give a go, it's a costless effort
                                  • Dessy
                                    @substring no probs might have a fiddle then 😄
                                      @dessy yeah but i don't think it's enough. I'm working on a big system update may b*mp all this myself and hope a 3b+ will arrive soon 😮
                                      • monero
                                        monero last edited by monero
                                        @gkralicek2 did you use any heatsink or cooling soultion to get 1,6 ghz on the new pi3 b+?
                                        @substring recalbox is the only OS i would like to use on the new pi3 b+. so hopefully an compatible update will come soon.
                                        Substring gkralicek2 2 Replies Last reply Reply Quote 0
                                          Substring @monero last edited by
                                          @monero i need a 3+ first !
                                          • Dessy
                                            @substring if you need any log files etc submitting let me know if it'll help
                                            101.0k
