    Raspberry Pi 3B+ (Plus) - Compatible?
    59
    230
    269382
    • gkralicek2
      gkralicek2 @monero last edited by
      @monero Nope no heatsink. Heat control is very good on the new B+. On the standard Pi 3, even when putting heatsink one could barely let his finger on the CPU without burning himself after a few hours of use. On the current B+, the CPU is hot when touching it but not "burning hot" (even when CPU inner temperature is very high, dissipation is well handled and doesn't give the impression the whole unit is gonna melt :=)
        Substring @Dessy last edited by
        @dessy sadly it won't help as it's a matter of how the kerbel detects the board. You'd need an UART to be helpful as of now
        • GameBoy
          GameBoy last edited by
          https://retropie.org.uk/forum/topic/16307/retropie-4-3-15-stretch-images-for-testing
          In Retro Pi 4.3.15 the Kernel modyfied and work well on New Pi 3 B+. Did this help us for recalbox ?
            Substring @GameBoy last edited by
            @gameboy nope, because we're on kernel 4.4 😛 we'd need to b*mp to 4.9, adapt kernel patches and rebuild. I'm working on it
            Gaetan 1 Reply Last reply Reply Quote 2
            • Gaetan
              Gaetan Theme moderator @Substring last edited by
              @substring Maybe it's a bit early for you to give the answer, but maybe you'd know already.
              Will it be the same Recalbox .img file to burn on both pi3 B and B+ or a different one ?
                Substring @Gaetan last edited by
                @gaetan i think it should be the same, can't be sure yet. It's mainly a dtb change (+ major kernel change concerning recalbox)
                Gaetan 1 Reply Last reply Reply Quote 1
                • Gaetan
                  @substring Thank you for the answer. Specially when I like it 🙂
                  hex12 1 Reply Last reply Reply Quote 0
                  • hex12
                    hex12 @Gaetan last edited by hex12
                    @substring sorry but i am really curious to know if improvements on pi3 b+ will reflect in updated performance on recalbox, in particular in n64 emulation. Except the 200MhZ CPU speed, what i think could be useful is the improvements in termal, which i read should bring to a 1,2GhZ stable speed of Pi3 b+, where normal Pi3 should decrease to less than 1GhZ. For sure, as GPU doesn't change, there won't be a high performance increase on emulators, but maybe framerate could be a little more stable on emulators that requires more system resource and most of all if we user active dissipation (heat sink+fan). If you have some datas on that and can share, it should be good to evaluate differences with the two Pi3 models on our favourite applicaton 🙂
                    Substring joinski 2 Replies Last reply Reply Quote 0
                      Substring @hex12 last edited by
                      @hex12 ain't nuttin' 😞 voljega shared a benchmark showing some interesting improvements. Gralicek2 said they can ve nicely overclocked. So all in all, you could reach 1.5Ghz, maybe 1.6. I can't tell if it's good improvement, and we sadly have no benchmark suit available (tjat's something i'd love to write but we lack devs)
                      • hex12
                        hex12 @Substring last edited by hex12
                        This post is deleted!
                        • joinski
                          joinski @hex12 last edited by
                          @hex12
                          take a look at this little review:
                          https://www.youtube.com/watch?v=CD_dEaRIevo
                          • dizeLL
                            dizeLL last edited by
                            i've received today my new pi3 b+. libreelec and raspbian works. recalbox not.
                            @substring you got your pi3 b+ already? im so hyped to test the new performance on recalbox. 🙂
                              Substring @dizeLL last edited by
                              @dizell we have an internal build working fine on pi3+, needs some fixing here and there, nothing bad. The real problem is that we can't include it in the current build as any kernel update would brick recalbox. Working hard on finding a solution without forcing people to reinstall from scratch
                              noktambule 1 Reply Last reply Reply Quote 2
                              • noktambule
                                noktambule @Substring last edited by
                                @substring said in Raspberry Pi 3B+ (Plus) - Compatible?:
                                Thanks for your amazing work.
                                But don't worry, reinstall from scratch is not a big deal!
                                roman126 1 Reply Last reply Reply Quote 3
                                • roman126
                                  roman126 @noktambule last edited by
                                  @noktambule @substring
                                  Same for me, New Pi 3B+, and new fresh install to go with it! I have this obsession that new installs are always better than upgrades! I have the same thinking when updating my IOS devices 😄
                                  Thanks for all the hard work guys, appreciated
                                    Pi3b+ forces us to switch to kernel 4.9 (we're on 4.4), and in the coming weeks, raspberry should switch for good on 4.14. So we can't always get that late comparing to official kernel releases. That's also forgetting the x86 kernel release cycle is much faster ...
                                    So i'm working on a new update process
                                    1 Reply Last reply Reply Quote 4
                                    • kazki
                                      kazki last edited by
                                      that's a good thing to know that a internal version of recalbox works with R3B+
                                      I'm building a second bartop and I'd like to use the new raspberry pi 3B+
                                      it's quite irrelevant to install recalbox from scratch since you always advised to use usb drive to store roms, of course it takes longer to load but I think it's worth the wait at every boot: I can manage my roms on a usb drive directly (adding and more often deleting titles from a full set, I know I should own the originals and so on)
                                      I tried retropie since the beta is compatible with P3B+ and to my humble opinion although it's really nice to be able to set every thing, I really appreciate the simplicity of recalbox
                                      Thanks for your efforts guys, I'm looking forward to installing recalbox on a new R3B+
                                      roman126 lhari84 2 Replies Last reply Reply Quote 0
                                      • roman126
                                        roman126 @kazki last edited by
                                        @kazki agreed, how much longer does it take to load from USB? Twice as long, 3 times as long?, maybe I should try and find out for myself 😄, yes the very thought of trying to get all the roms off my memory card, to do a new build for 3B+ when it’s available fills me with dread. Time to invest in a decent Nano USB memory stick!
                                        kazki 1 Reply Last reply Reply Quote 0
                                        • kazki
                                          kazki @roman126 last edited by
                                          @roman126
                                          i just chronometered
                                          it took about 1min25sec to boot from usb drive on (i used a USB3.1 64GB Sandisk USB drive Sandisk Ultra fit newest version)
                                          compared to under 30 sec with a Sandisk Ultra micro sd card
                                          It can take a while to transfer roms through ethernet I think it's easier to manage my roms library from usb drive. That's not really the subject here so I won't develop
                                          roman126 1 Reply Last reply Reply Quote 0
                                          • roman126
                                            @kazki true, thanks I’ll give it a whirl
                                            101.0k
