    Recalbox won't save any setting like favorites or emulator parameter for a ROM
    recalbox wont setting favorites parameter
    5348
    • stamstamstam
      stamstamstam last edited by
      Hello,
      I made different searches in different languages before asking here and haven't found anything.
      My problem is very simple: recalbox won't save any setting like favorites or emulator parameter for a ROM.
      I have downloaded pre-scrapped compilations of roms for each emulators, I don't know if it's connected. Those compilations came up with a pre-defined list of favorites.
      It seems like after tweaking favorites and rom parameters, it won't save. When I restart recalbox, it's back to the previous state.
      Any idea?
      Thanks.
        Substring @stamstamstam last edited by
        @stamstamstam corrupted gmelist.xml files ?
        stamstamstam 1 Reply Last reply Reply Quote 0
        • stamstamstam
          stamstamstam @Substring last edited by
          @Substring <how can I make sure it's the problem?
          I can open the files without any error from my computer.
            paradadf Staff @stamstamstam last edited by
            @stamstamstam you can use a tool like this one to verify your gamelists:
            https://www.xmlvalidation.com/
            But I'll asume, it is more related to an incompatible (not well adapted) theme, than something with the gamelists. Try turning back to the official one.
            • stamstamstam
              I never changed the theme, I dont even know how to do that 🙂
              Just in case, where can I check this?
              I checked xml file, no error was found.
                paradadf Staff last edited by
                Under menu, UI settings, themes.
                Did you make a clean install of recalbox yourself (I'm not talking about the system, not the roms)?
                • stamstamstam
                  Just checked: I only have the base theme installed (recalbox).
                  As explained in the OP, I downloaded packs for 4.0 version of recalbox, everything works fine except this.
                    I would delete all scraped data and do it again. No idea what else you can try.
