    Duplicated SNES games, not scraping, Gamelist.xml empty
    duplicated snes scraping gamelist.xml empty
    6400
    • krantz
      krantz last edited by krantz
      I'm having a problem setting up the SNES roms. When I load them, they appear as a duplicated list:
      http://imgur.com/ID9gYuk
      The games do work if I select them. The scraper doesn't recognize the roms. If i try to delete a duplicate, the game stop to work. The gamelist.xml in the SNES rom folders appears to be empty. The other system seems to work fine. I'm on Recalbox 4.0beta4, Raspberry pi3.
        paradadf Staff @krantz last edited by
        @krantz Which scraper doesn't recognize the roms? Have you only upload the roms to your sd card without touching anything else? Did you touch gamelist.xml?
        • krantz
          I uploaded the roms directly with an SD card reader, without touching anything else. I opened the gamelist but haven't tried to modify it. Yes, now I can scape using gamesDB.
            @krantz Sorry but I don't understand you very well. Why don't you delete every snes rom from the folder (gamelist.xml is empty by default) and copy your roms again. There is no reason why a single game should appear twice.
            • krantz
              I tried to delete and copy the roms again many times, but this doesn't seem to resolve the problem.
                Hello
                you need to kill emulationstation process to delete gamelist.
                in ssh : killall emulationstation
                delete gamelist.xml
                /recalbox/share/roms/snes/
                and reboot your raspberry with command line : reboot
