    Recalbox 8 and Odroid XU4 OGST
    recalbox odroid xu4 ogst
    9
    18
    4738
    • tomikitwo
      tomikitwo last edited by
      Hello
      I am a new user of Recalbox. I was using Batocera before. I installed the latest version of Recalbox 8 on my Odroid XU4 and I'm trying to set it to work with external LCD screen (OGST).
      I changed confugure file by removing ";" to unlock OGST screen but it did nothing. The screen remains black.
      Does anyone know how to set the OGST screen in Recalbox 8 to work?
      Zing flaker38 davidb2111 4 Replies Last reply Reply Quote 0
        Zing Global moderator Translator @tomikitwo last edited by
        @tomikitwo
        https://forum.recalbox.com/topic/25465/ecran-ogst-sur-xu4-recalbox-8
        • flaker38
          flaker38 @tomikitwo last edited by
          @tomikitwo Hello
          You have to modify the recalbox.conf file as described in the wiki :
          https://wiki.recalbox.com/en/tutorials/video/tft/second-minitft-or-ogst-for-scraps-and-videos
          Odroid XU4Q + Boitier OGST
          • davidb2111
            davidb2111 Staff last edited by davidb2111
            Hi all,
            EDIT&WARNING: this is not working at the moment! Please do not apply this procedure !!!
            ~~For those who can't enable OGST LCD screen and running on eMMC, here is a little guide to follow:
            1. make sure to enable ogst profile in /boot/config.ini:
            [generic]
            ; Device Tree Overlay
            overlay_resize=16384
            ; uncomment next line to enable Odroid XU4 OGST
            overlay_profile=hktft_cs_ogst
            overlays="spi0 i2c0 i2c1 uart0"
            [overlay_hktft_cs_ogst]
            overlays="hktft-cs-ogst i2c0"
            1. enable minitft in recalbox.conf:
            system.secondminitft.enabled=1
            system.secondminitft.type=overlay
            1. download https://github.com/hardkernel/u-boot/releases/download/travis%2Fodroidxu3-108/u-boot-odroidxu3-108.tar.gz
            2. Execute:
            tar xzvf u-boot-odroidxu3-108.tar.gz
            cd sd_fuse
            1. overwrite sd_fusing.sh with this one:
            # Copyright (C) 2011 Samsung Electronics Co., Ltd.
            #              http://www.samsung.com/
            # This program is free software; you can redistribute it and/or modify
            # it under the terms of the GNU General Public License version 2 as
            # published by the Free Software Foundation.
            set -x
            if [ -z $1 ]
            then
                echo "usage: ./sd_fusing.sh <SD Reader's device file>"
                exit 0
            fi
            if [ -b $1 ]
            then
                echo "$1 reader is identified."
            else
                echo "$1 is NOT identified."
                exit 0
            fi
            if [ -d /sys/block/${1##*/}boot0 ]; then
                echo "$1 is an eMMC card, disabling ${1##*/}boot0 ro"
                if ! echo -n 0 > /sys/block/${1##*/}boot0/force_ro; then
                echo "Enabling r/w for $1boot0 failed"
                exit 1
                fi
                emmc=1
            fi
            # fusing images
            if [ -n "$emmc" ]; then
                signed_bl1_position=0
                bl2_position=30
                uboot_position=62
                tzsw_position=2110
                device=$1boot0
            else
                signed_bl1_position=1
                bl2_position=31
                uboot_position=63
                tzsw_position=2111
                device=$1
            fi
            # Get the U-Boot blob
            if [ -f ./u-boot-dtb.bin ]; then
              uboot="./u-boot-dtb.bin"
            elif [ -f ./u-boot.bin ]; then
              uboot="./u-boot.bin"
            else
              echo "U-Boot blob not found."
              exit
            fi
            #<BL1 fusing>
            echo "BL1 fusing"
            dd if=./bl1.bin.hardkernel of=$device seek=$signed_bl1_position conv=notrunc
            #<BL2 fusing>
            echo "BL2 fusing"
            dd if=./bl2.bin.hardkernel.1mb_uboot of=$device seek=$bl2_position conv=notrunc
            #<u-boot fusing>
            echo "u-boot fusing"
            dd if=$uboot of=$device seek=$uboot_position conv=notrunc
            #<TrustZone S/W fusing>
            echo "TrustZone S/W fusing"
            dd if=./tzsw.bin.hardkernel of=$device seek=$tzsw_position conv=notrunc
            #<Message Display>
            echo "U-boot image is fused successfully."
            echo "Eject $1 and insert it again."
            1. execute:
            bash sd_fusing.sh /dev/mmcblk0
            sync
            reboot
            PS: I will not be held responsible for any damages~~
            cedric-debuiselle 1 Reply Last reply Reply Quote 0
            • cedric-debuiselle
              cedric-debuiselle @davidb2111 last edited by
              @davidb2111 said in Recalbox 8 and Odroid XU4 OGST:
              Hi all,
              [generic]
              2. Execute:
              cd sd_fuse
              set -x
              if [ -z $1 ]
              then
                  exit 0
              fi
              if [ -b $1 ]
              then
              else
                  exit 0
              fi
                  exit 1
                  fi
                  emmc=1
              fi
              # fusing images
                  bl2_position=30
                  uboot_position=62
                  tzsw_position=2110
                  device=$1boot0
              else
                  bl2_position=31
                  uboot_position=63
                  tzsw_position=2111
                  device=$1
              fi
              else
                exit
              fi
              #<BL1 fusing>
              echo "BL1 fusing"
              #<BL2 fusing>
              echo "BL2 fusing"
              #<u-boot fusing>
              #<Message Display>
              1. execute:
              sync
              reboot
              question un peu bête à faire directement sur pc pc avec linux ou il faut avoir les deux carte sur le xu4 et faire ça a distance?
              • davidb2111
                Hello
                Alors, on me prévient que ça ne marche pas. Pour l'instant, merci de ne rien faire, cela risquerait de ne plus faire booter le xu4.
                cedric-debuiselle 2 Replies Last reply Reply Quote 1
                • cedric-debuiselle
                  Hello
                  Merci pour l'avertissement bien fait d'avoir attendu
                  Alvin cedric-debuiselle 2 Replies Last reply Reply Quote 0
                  • Alvin
                    Alvin Banned @cedric-debuiselle last edited by
                    @cedric-debuiselle
                    @davidb2111
                    This is he ENGLISH Part of the Board and the Thread started in ENGLISH.
                    So if you have something to say here, please post in ENGLISH !
                    • Bkg2k
                      Bkg2k Staff @Alvin last edited by
                      @alvin Hey calm down a bit please.
                      Something like "This is an english board, could you please write in english" or even "Could you please rewrite your response in english so that everyone could understand" would be A LOT MORE appreciated than "So if you have something to say here, please post in ENGLISH !".
                      • cedric-debuiselle
                        cedric-debuiselle @cedric-debuiselle last edited by
                        @cedric-debuiselle said in Recalbox 8 and Odroid XU4 OGST:
                        linux
                        Hi all,
                        [generic]
                        2. Execute:
                        cd sd_fuse
                        set -x
                        if [ -z $1 ]
                        then
                            exit 0
                        fi
                        if [ -b $1 ]
                        then
                        else
                            exit 0
                        fi
                            exit 1
                            fi
                            emmc=1
                        fi
                        # fusing images
                            bl2_position=30
                            uboot_position=62
                            tzsw_position=2110
                            device=$1boot0
                        else
                            bl2_position=31
                            uboot_position=63
                            tzsw_position=2111
                            device=$1
                        fi
                        else
                          exit
                        fi
                        #<BL1 fusing>
                        echo "BL1 fusing"
                        #<BL2 fusing>
                        echo "BL2 fusing"
                        #<u-boot fusing>
                        #<Message Display>
                        1. execute:
                        sync
                        reboot
                        I couldn't figure out how to edit my post.
                        A bit stupid question to do directly on pc pc with linux or you have to have both cards on the xu4 and do it remotely?
                        • cedric-debuiselle
                          voir attendu
                          Thanks for the warning, I did well to wait
                          • cedric-debuiselle
                            @davidb2111 Write
                            So, I am told that it does not work. For now, please don't do anything, it might stop the xu4 from booting.
                            davidb2111 1 Reply Last reply Reply Quote 0
                            • davidb2111
                              davidb2111 Staff @cedric-debuiselle last edited by
                              @cedric-debuiselle
                              Sorry for the issue. However, we have found that the emmc is shipped with an older uboot that does not support overlays.
                              So the trick is to upgrade emmc uboot which is located on /dev/mmcblk0boot0.
                              A user kindly accepted to make some tests. We were able to flash (an apparent) newer uboot over the older one and it seemed to boot, but he forget to set the switch to emmc boot and booted on sd instead. He reported to mistake few days later...
                              However, he's ok to send me his emmc so that I can understand how to update the emmc uboot. So stay tuned!
                              • davidb2111
                                davidb2111 Staff @tomikitwo last edited by
                                Hi all
                                I've just tested to flash 8.1 (beta) on an eMMC. After flashing with RPI Imager, I've started the XU4 with the eMMC only.
                                Then, I've done the regular configuration as explained here:
                                • https://wiki.recalbox.com/en/tutorials/video/tft/second-minitft-or-ogst-for-scraps-and-videos#odroid-game-station-turbo-ogst-xu4 (EN)
                                • https://wiki.recalbox.com/fr/tutorials/video/tft/second-minitft-or-ogst-for-scraps-and-videos#odroid-game-station-turbo-ogst-xu4 (FR)
                                and rebooted. The display was functional.
                                I post here the SSH commands:
                                mount -o remount,rw /boot
                                cp /boot/boot.ini.sample /boot/boot.ini
                                cp /boot/config.ini.sample /boot/config.ini
                                sed -i '/overlay_profile=hktft_cs_ogst/s/^;//' /boot/config.ini
                                cd
                                sed -i -E 's/;?(system.secondminitft.enabled)=.*/\1=1/' recalbox.conf
                                sed -i -E 's/;?(system.secondminitft.type)=.*/\1=overlay/' recalbox.conf
                                sed -i -E 's/;?(system.secondminitft.resolution)=.*/\1=240p/' recalbox.conf
                                sed -i -E 's/;?(system.secondminitft.imagestretchenabled)=.*/\1=1/' recalbox.conf
                                sed -i -E 's/;?(system.secondminitft.imageenlargeenabled)=.*/\1=0/' recalbox.conf
                                sed -i -E 's/;?(system.secondminitft.imagealphaenabled)=.*/\1=1/' recalbox.conf
                                sed -i -E 's/;?(system.secondminitft.imageignoreaspectenabled)=.*/\1=1/' recalbox.conf
                                reboot
                                karl0ss 1 Reply Last reply Reply Quote 1
                                • karl0ss
                                  karl0ss @davidb2111 last edited by
                                  @davidb2111 AMAZING david!
                                  • khaneki239
                                    khaneki239 last edited by
                                    https://get-vidmateapp.com/
                                    https://get-mobdroapk.com
                                    davidb2111 1 Reply Last reply Reply Quote 1
                                    • davidb2111
                                      davidb2111 Staff @khaneki239 last edited by
                                      Hello @khaneki239
                                      Tu peux détailler, stp ?
                                      • davidb2111
                                        Great news all!
                                        We were able to make it work finally. So, when using eMMC, the XU4 boot from a "hidden" partition which is not overwritten when flashing a Recalbox image nor upgrading.
                                        You must flash data to that partition manually.
                                        Here are the commands to do that : https://wiki.recalbox.com/en/tutorials/video/tft/second-minitft-or-ogst-for-scraps-and-videos
                                        Thanks to @karl0ss who sent me his eMMC and @cedric-debuiselle for testing.
