    Recalbox v7.2.1 - Commentaires & issues
    recalbox v7.2.1 commentaires
    30
    83
    38902
      Scavy Global moderator last edited by Pitch64
      La v7.2.1 (tant attendue) est là !
      The (so expected) v7.2.1 is out !
      Retrouvez ci dessous les correctifs de cette version.
      You can find the list of bugfixes here :
      Bring back fan speed setting on Odroid XU4
      Fix loop reboot with non official themes
      Lightgun system is shown by default if any game is detected
      Kodi video playback is back on Rpi 4
      Reicast has been removed from Rpi, PC and XU4 as this emulator does not work anymore with our new kernel and softwares versions. You can now use Flycast as the main emulator for the dreamcast.
      On PSP, with PPSSPP emulator, videos now run full speed
      Raspberry Pi 1,2,3 boot video now run full speed
      Fix arcade view systems missing model3, atomiswave, naomi, naomigd, daphné
      Duckstation has been renamed Swanstation
      Fix Swanstation issues when loading games
      Fix cavestory x86 and x86_64
      Fix House of the dead bios validation
      Add missings game extensions detection for SCV and WII
      Default language is now used when scraping
      Fix gameclip initialization on network shares
      Fix freezes when running a game while playing gameclip
      Using IPv4 in priority when connecting WIFI
      Factory reset now reset case configuration
      Fix rating componant running out of screen
      Fix sound menu & output auto-selection
      Fix Odroid Go Advance V1 gamepad detection
      Fix Super Cassette Vision scraping
      Fix rtl88x2bu Realtek wifi driver
      Fix "Forget all bluetooth devices"
      Fix pixel-perfect settings being incorrectly set in menu
      Fix update popup appearing over Gameclip Screensaver
      Fix hiding a game wipe all its metadata
      Fix theme display after switching theme or editing theme options
      Fix some files referenced in .cue/.gdi/.m3u not being ignored by the scraper
      Force volume of all outputs to 100%
      Fix crash when running a game from the search window
      Ce fil est ouvert afin de recueillir vos remarques, les bugs que vous pourriez encore constater, vos critiques positives ou négatives.
      This post is open to collect your comments, any bugs you may still notice, your positive or negative reviews.
      N'oubliez pas de détailler votre matériel et la façon de reproduire votre bug le cas échéant !
      Do not forget to detail your equipment and how to reproduce your bug !
      Merci 🙂
      Thanks 🙂
      olivierdroid92 Subzero666 Phil66 3 Replies Last reply Reply Quote 6
      • olivierdroid92
        olivierdroid92 Global moderator @Scavy last edited by
        @scavy Super
        TOP
        • DacK
          DacK last edited by DacK
          Pas de fix pour les manettes 8bitdo ?
          Il me semblait l'avoir vu sur le Gitlab, je n'attendais que ça pour migrer. 😄
          Edit : Et bien sur, merci pour le travail accompli !
          • digitaLumberjack
            On a intégré quelques changements pour les 8bitdo mais pas assez pour dire que c’était fixé.
            Tu peux quand meme re-essayer avec ta manette et nous dire si ca passe 😛
            Pac DacK 2 Replies Last reply Reply Quote 0
            • Pac
              Pac @digitaLumberjack last edited by
              Bravo les champions !! Très réactif et content d'apprendre la nouvelle. Je vais pouvoir tester 😉
              Un grand merci pour ce que vous faire. Recalbox est vraiment un chouette projet.
              Recalbox 10.0 on :
              ° Laptop 64bits
              ° Raspberry Pi 5
              • olivierdroid92
                olivierdroid92 Global moderator @DacK last edited by
                @dack Hello
                Quel modèle de manette possedes-tu ?
                DacK 1 Reply Last reply Reply Quote 0
                • DacK
                  DacK @olivierdroid92 last edited by
                  @olivierdroid92 Une SN30 Pro + que j’appaire en mode Switch sur 7.1.1.
                  Je sais déjà qu'il va falloir tester en mode Android/Bluetooth 😛
                  • olivierdroid92
                    @dack
                    Pour le SN30Pro+, il y a une astuce, je te MP
                    • Subzero666
                      Subzero666 @Scavy last edited by
                      @scavy Bonjour/bonsoir.
                      Excellente version, bravo pour le travail fourni🙂
                      Plus de possibilité d'avoir l'écran tft de l'Odroid OGST avec XU4Q (SD 16Gb + SSD 120Gb)?
                      Pitch64 1 Reply Last reply Reply Quote 0
                      • Pitch64
                        Pitch64 Staff @Subzero666 last edited by
                        @subzero666 c'est un bug connu depuis la 7.2.0, on est dessus 🙂
                        Next release? Soon™
                        Subzero666 1 Reply Last reply Reply Quote 1
                        • Subzero666
                          Subzero666 @Pitch64 last edited by
                          @pitch64 ok, merci pour ta réponse🙂
                          • Aldwinn
                            Aldwinn last edited by
                            Bonjour, quelques petits retours,
                            • chez moi (XU4) pas de son des vidéos Splash au démarrage, ni les vidéos intégrées, ni les custom.
                            • Pas d'oubli des manettes bluetooth et pas de possibilité de mettre "aucun" pour un gamepad. Ceux-ci s'accumulent donc dans la liste et les filaires apparaissent en doublons et plus.
                            Merci 😉
                            • Bartop / Odroid XU4
                            • Odroid Go Super
                            • GPi Case
                            • Manettes 8bitdo: SF30 Pro / M30 / N64
                            loli72 1 Reply Last reply Reply Quote 0
                            • loli72
                              loli72 @Aldwinn last edited by
                              @aldwinn Je n'ai pas de soucis de son des vidéos mais je confirme que cette mise à jour ne concerne pas nos XU4. Les pertes de perfs en PSP est ce qui m'inquiète le plus pour les versions futures. En fait la version précédant (7.1.1) n'avaient pas de défaut majeurs sur XU4 comparé à celle ci.
                              Il va falloir patienter encore un peu ou ne plus mettre à jour.
                              • cdtpepette
                                cdtpepette last edited by
                                Bonjour. Un grand merci pour votre super boulot. Je me régale.👍 👏
                                Je suis épaté par la simplicité d'usage du lightgun.
                                Je suis sur pi4 et kodi fonctionne bien en kms mais pas le cec. Avec fkms le cec fonctionne.
                                Pas trop grave, les manettes et l'appli mobile font le taf.
                                Merci😊
                                Raspberry pi 4 2Go,RGBDual, Recalbox 8.1-64bits, share sur NAS nfs Yunohost (raspberry pi 3).
                                Gpi Case Rpi 0 µSD 32Go Recalbox 8.1
                                cdtpepette 1 Reply Last reply Reply Quote 0
                                • Phil66
                                  Phil66 @Scavy last edited by
                                  @scavy
                                  v7.2.1 sur Rpi 4 ; je viens de la mettre est j'ai dessuite fait le " reset factory " pour que ma manette fonctionne sur PSX , résultat ça à marché , rien n'à été perdu en terme de sauvegarde de partie en cour .
                                  • La PSP tourne parfaitement avec : le saut d'image 1 +réso x2 + synchronisation verticale
                                  • Atomis & Naomi = ça tourne mieux , moins de saccade et plus fluide que sur la 7.1.1
                                  • Parallel N64 devient l'émulateur de la n64 et effectivement dans la grande majorité des jeux ça tourne mieux , la définition est clairement au dessus ce qui donne un rendu visuel plus propre sur cette plateforme .
                                  • Le son est impeccable quelque soit la sortie et en enceinte Bluetooth c'est un super kiff !
                                  • il n'y à plus de freeze : ni quand on fait la recherche manuelle des jeux avec le clavier virtuel / ni quand on lance un jeux
                                  • le démarrage de recalbox est toujours aussi rapide , la 7.2.1 beta3 était lente au démarrage mais ce soucis est résolu danscette version finale 7.2.1
                                  • petit soucis avec le thème next pixel 720p , je n'ai pas d'image pour la partie Light gun ( c'est noir ) :
                                    mais cela est logique car c'est une nouvelle fonction ,
                                    donc est-ce que c'est corrigé dans la mise à jour de next pixel pour 7.2.1 ?
                                  voilà moi je suis totalement satisfait pour ma part sur pi4 , après je n'ai pas tout testé bien entendu ,
                                  Un grand bravo à toute l'équipe pour cette belle réactivité !
                                  A+
                                  • rebace
                                    rebace last edited by
                                    sur rpi4 je suis passée de 7.1.1 en 7.2.1 et je pense que ce n'etait pas une bonne idée...
                                    le son saccade dans le menu
                                    le son psp saccade de la meme facon, mais les jeux fonctionne bien.
                                    et sur kodi le fait avec certains avi.
                                    j'ai aussi un doute, il ne me semble pas avoir vu avant la maj un message d'alerte m'annoncant un bios manquant pour un iso psx, ce qui est a present le cas.
                                    j'ai l'impression que le systeme est plus lent.
                                    je pense que tout ceci vient du fait que j'ai mis a jour depuis la 7.1.1
                                    car je ne voulais pas me retaper la conf du sharedevice de mon nas
                                    je recupere les configs qui m'interesse, finalement essentiellement
                                    le recalbox-boot.conf
                                    et le sources dans .kodi userdata
                                    je refait une installation a zero.
                                    rebace 1 Reply Last reply Reply Quote 0
                                    • TATIEU
                                      TATIEU last edited by
                                      Bonjour, sur gpi case il n'y a plus de son, le safe shut down ne fonctionne plus et les jeux GBA rament
                                      • rebace
                                        rebace @rebace last edited by
                                        @rebace avec un reinstallation fraiche sur mon rpi4
                                        j'ai toujours le meme probleme de son. (sortie hdmi)
                                        il saccade (un peu comme s'il etait au ralenti)
                                        dans le menu
                                        dans les jeux psp
                                        dans le menu kodi
                                        ca ne le faisait pas avant sur la 7.1.1
                                          Scavy Global moderator @Phil66 last edited by
                                          @phil66 said in Recalbox v7.2.1 - Commentaires & issues:
                                          il faut demander au themer, c'est @mYSt , mais je pense qu'il est en train de plancher sur sa mise à jour ^^
                                          Pour information, d'autres thèmes font leur apparition et sont déjà compatibles en 7.2.1 !!
                                          Phil66 1 Reply Last reply Reply Quote 1
                                            Scavy Global moderator @rebace last edited by
                                            @rebace salut
                                            nous n'avons pas ces symptomes il est difficile de te répondre. As tu essayé de faire un reset factory ?
                                            fiatou rebace 2 Replies Last reply Reply Quote 0
