    Video Snaps transition effects: turn them off
    snaps transition effects turn
    7
    17
    3903
    • clkgames
      clkgames last edited by
      Hello,
      is it possible to turn off the video snaps transition effect?
      Another issue I'd like to point out is, if you set the video snap start delay to zero and scroll very quickly throughout your game list, Emulationstation loads again and you are sent back to Main Screen.
      Regards,
      John
      • RustyMG
        RustyMG last edited by
        Not sure about being able to switch them off, but if you change the delay to something like 10 or 20 seconds, its effectively the same thing - they will never get a chance to play.
        emulationstation.videosnaps.delay=10000
        Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
        clkgames 1 Reply Last reply Reply Quote 1
          @clkgames I think you already know, but, the options that can be changed are in the recalbox.conf file (you must remove the semicolon from the beginning of the line for the configuration to work):
          ## Videosnaps
          ### Delay before videosnaps start, in millisecond. Default: 2s
          ;emulationstation.videosnaps.delay=2000
          ### Video loop times. 0 = no video. 1 or more = the video loops x times before fading out
          ;emulationstation.videosnaps.loop=1
          ### Enable videosnap sound/music
          ;emulationstation.videosnaps.sound=1
          I wouldn't call it an issue, it happens due to a hardware limitation, you are overloading the system, and forcing it to restart the Emulationstation, if it didn't, you would have to shut down forcibly (and manually).
          The videos take up more storage space, and are heavier for the system to play. It is understood that whoever uses the videos uses it so that they can see an example of the game, that is, they will not scroll very quickly.
          Considering that the problem is hardware limitation (and that, I believe that it is not feasible to change the hardware because of this detail), and that, you want to use snap videos, but sometimes you want to go quickly to a specific title, I recommend that you use shortcuts:
          In the console selection list:
          • R1: search function (https://recalbox.gitbook.io/documentation/v/francais/usage-basique/fonctionnalites/fonction-de-recherche)
          In the games list:
          • L or R: page up / page down
          • Start-> JUMP TO LETTER
          • clkgames
            clkgames @RustyMG last edited by clkgames
            @RustyMG said in Video Snaps transition effects: turn them off:
            But I do want to play the video snaps, I was just wondering if it's possible to turn off the transition effect (fade in, whirling etc)
            @Zing thanks, yeah I was aware of the video snap options. BTW, does enabling emulationstation.videosnaps.sound=1 change anything on version 7.1.1?
            As for the "issue" thing; my apologies, wrong choice of words. It is clearly a hardware limitation as I am running Recalbox on a RPI4 with 2Gb of RAM.
              Zing Global moderator Translator @clkgames last edited by
              @clkgames
              An Rpi4 with 2Gb of RAM is enough to run practically all possible games in Recalbox, it is the most cost-effective Hardware today, but video snaps overload the system, it is definitely not worth changing hardware, it is better to configure the system otherwise, or, use the shortcuts I mentioned.
              • LapinFou
                LapinFou last edited by
                Oh. So, it does mean the ES reboot issue will never be fixed on RPI4 ? 😥
                • airdream
                  I haven't encountered this issue on RPI3 (less ram).
                  So i tough it was an optimisation problem with RPI4, no?
                    Zing Global moderator Translator @airdream last edited by Zing
                    @airdream Did you set the video snap start delay to zero?
                    If you have the same configuration and it doesn't happen in Rpi3, then I'm wrong (and you're right).
                    Can you please test with the delay set to zero?
                    clkgames 1 Reply Last reply Reply Quote 0
                    • clkgames
                      clkgames @Zing last edited by
                      @Zing as for videosnap sounds: turns out setting it to either 0 or 1 makes no difference as no sound is played at all during videosnap playback.
                        @clkgames
                        • clkgames
                          @Zing sorry about that example, that line does not reflect how my recalbox.conf looks like, which is :
                          ## Videosnaps
                          emulationstation.videosnaps.loop=100
                          Again no matter if you set it to 0 or 1, no difference - no sound in either way.
                          John
                            @clkgames I don't use videosnaps, and I can't test it now, does anyone else have this problem?
                            I saw that it was previously reported:
                            https://forum.recalbox.com/topic/20111/sound-and-videosnaps
                            But I saw no other report than that.
                            • domzest
                              domzest last edited by
                              I also have this problem, deleted the dot and comma the sound doesn't start
                                Please wait for the next version, there will be many improvements and maybe this is one of them.
                                clkgames Zemus 2 Replies Last reply Reply Quote 1
                                • clkgames
                                  @Zing thanks!
                                  • Zemus
                                    Zemus @Zing last edited by
                                    @zing
                                    Hi!
                                    With Version 7.2.2, is there a way now to control the video effects? I want to just blend in the video in a TV-Frame without the rotation-animation.
                                    Zing 1 Reply Last reply Reply Quote 2
                                      Zing Global moderator Translator @Zemus last edited by
                                      @zemus Sorry, but there are no new options for this.
                                      You can view the changelog here to check out the new features:
                                      https://gitlab.com/recalbox/recalbox/blob/master/CHANGELOG.md
                                      And it is possible to open an issues requesting this type of Resource:
                                      https://gitlab.com/recalbox/recalbox/-/issues
