    Audio not working in recalbox on PC
    audio recalbox
    6
    12
    3085
    • Ristul
      Ristul last edited by
      Hi, I have installed a fresh install of the 7.0.1 version on a PC, everything seem to work except for the audio in recalbox and also when playing games.
      The sound seem to work in kodi though, and I think it has to do with the driver.
      In kodi, I have an option that is not present in recalbox, the name is "HDA Intel PCH, MEI Panasonic-TV on HDMI". When I pick this option in kodi, sound works within kodi.
      My question is, does anyone know why this option is not available in recalbox and is there a way to force recalbox to use that audio output?
      Thanks
      Zing cookie_monster 2 Replies Last reply Reply Quote 0
        Zing Global moderator Translator @Ristul last edited by
        @Ristul Have you tried opening the Emulationstation menu (pressing Start on the console selection screen) and accessing "audio settings" (or something like that)?
        • https://recalbox.gitbook.io/documentation/basic-manual/getting-started/emulationstation#sound-settings
        • cookie_monster
          cookie_monster @Ristul last edited by
          @Ristul Hi there! Yes, I have the same issue with the audio output. It worked fine with 6.1.1 but I still have no sound through HDMI in 7.0.0 and 7.0.1. All the system sounds and game music is played by Internal PC Speaker or Jack 3,5mm.
          Now, I can't choose any working option. I have only 3 choices: HDA HDMI, HDA Analog and Default option.
          I will try with kodi and check if its related with driver or emulation station.
          • AxelR
            AxelR last edited by
            Same here. No Sound on HDMI output on 7.0 for x86/64.
            Only on the jack/audio of the PC
            Was working great with 6.1
            Ristul 1 Reply Last reply Reply Quote 0
            • Ristul
              Ristul @AxelR last edited by Ristul
              @AxelR Yes, 6.1 worked fine with my PC, I'm starting to regret upgrading to the latest version. And I find no older versions to download.
              I tried changing the audio from recalbox.conf file to the one that worked in kodi, but the settings reset when I boot the system. Very frustrating.
              • ian57
                ian57 Staff @Ristul last edited by
                @Ristul The sound management has been completly rewriten and there is some side effects, in addition, PC world is hell with hardware detection. To try to help you can you run these command lines in a ssh session on your recalbox :
                amixer -c 0 contents
                amixer -c 0 contrôles
                and retry with -c 1 and -c 2 and post the outputs here.
                you can try to select you specific sound output with alsamixer too.
                • Ristul
                  Ristul @ian57 last edited by
                  @ian57 I tried to do what you asked, the first command worked fine, but "contrôles" was not accepted as a valid command.
                  Here is what I got.
                  amixer -c 0 contents:
                  /recalbox/share/system$ amixer -c 0 contents
                  numid=46,iface=CARD,name='Front Headphone Jack'
                    ; type=BOOLEAN,access=r-------,values=1
                    : values=off
                  numid=40,iface=CARD,name='Front Mic Jack'
                    : values=off
                  numid=53,iface=CARD,name='HDMI/DP,pcm=3 Jack'
                    : values=off
                  numid=59,iface=CARD,name='HDMI/DP,pcm=7 Jack'
                    : values=on
                  numid=42,iface=CARD,name='Line Jack'
                    : values=off
                  numid=45,iface=CARD,name='Line Out CLFE Jack'
                    : values=off
                  numid=43,iface=CARD,name='Line Out Front Jack'
                    : values=off
                  numid=44,iface=CARD,name='Line Out Surround Jack'
                    : values=off
                  numid=41,iface=CARD,name='Rear Mic Jack'
                    : values=off
                  numid=47,iface=CARD,name='SPDIF Phantom Jack'
                    : values=on
                  numid=39,iface=MIXER,name='Master Playback Switch'
                    ; type=BOOLEAN,access=rw------,values=1
                    : values=on
                  numid=38,iface=MIXER,name='Master Playback Volume'
                    ; type=INTEGER,access=rw---R--,values=1,min=0,max=87,step=0
                    : values=87
                    | dBscale-min=-65.25dB,step=0.75dB,mute=0
                  numid=10,iface=MIXER,name='Headphone Playback Switch'
                    ; type=BOOLEAN,access=rw------,values=2
                    : values=on,on
                  numid=9,iface=MIXER,name='Headphone Playback Volume'
                    ; type=INTEGER,access=rw---R--,values=2,min=0,max=87,step=0
                    : values=87,87
                  numid=67,iface=MIXER,name='PCM Playback Volume'
                    ; type=INTEGER,access=rw---RW-,values=2,min=0,max=255,step=0
                    : values=255,255
                    | dBscale-min=-51.00dB,step=0.20dB,mute=0
                  numid=28,iface=MIXER,name='Front Mic Boost Volume'
                    ; type=INTEGER,access=rw---R--,values=2,min=0,max=3,step=0
                    : values=3,3
                    | dBscale-min=0.00dB,step=10.00dB,mute=0
                  numid=13,iface=MIXER,name='Front Mic Playback Switch'
                    : values=off,off
                  numid=12,iface=MIXER,name='Front Mic Playback Volume'
                    ; type=INTEGER,access=rw---R--,values=2,min=0,max=31,step=0
                    : values=31,31
                    | dBscale-min=-34.50dB,step=1.50dB,mute=0
                  numid=2,iface=MIXER,name='Front Playback Switch'
                    : values=on,on
                  numid=1,iface=MIXER,name='Front Playback Volume'
                    : values=87,87
                  numid=4,iface=MIXER,name='Surround Playback Switch'
                    : values=on,on
                  numid=3,iface=MIXER,name='Surround Playback Volume'
                    : values=87,87
                  numid=7,iface=MIXER,name='Center Playback Switch'
                    : values=on
                  numid=5,iface=MIXER,name='Center Playback Volume'
                    : values=87
                  numid=8,iface=MIXER,name='LFE Playback Switch'
                    : values=on
                  numid=6,iface=MIXER,name='LFE Playback Volume'
                    : values=87
                  numid=30,iface=MIXER,name='Line Boost Volume'
                    : values=3,3
                  numid=17,iface=MIXER,name='Line Playback Switch'
                    : values=off,off
                  numid=16,iface=MIXER,name='Line Playback Volume'
                    : values=31,31
                  numid=23,iface=MIXER,name='Capture Switch'
                    : values=off,off
                  numid=25,iface=MIXER,name='Capture Switch',index=1
                    : values=off,off
                  numid=27,iface=MIXER,name='Capture Switch',index=2
                    : values=off,off
                  numid=22,iface=MIXER,name='Capture Volume'
                    ; type=INTEGER,access=rw---R--,values=2,min=0,max=63,step=0
                    : values=0,0
                    | dBscale-min=-17.25dB,step=0.75dB,mute=0
                  numid=24,iface=MIXER,name='Capture Volume',index=1
                    : values=0,0
                  numid=26,iface=MIXER,name='Capture Volume',index=2
                    : values=0,0
                  numid=11,iface=MIXER,name='Loopback Mixing'
                    ; type=ENUMERATED,access=rw------,values=1,items=2
                    ; Item #0 'Disabled'
                    ; Item #1 'Enabled'
                    : values=0
                  numid=37,iface=MIXER,name='IEC958 Default PCM Playback Switch'
                    : values=on
                  numid=54,iface=MIXER,name='IEC958 Playback Con Mask'
                    ; type=IEC958,access=r-------,values=1
                    : values=[AES0=0x0f AES1=0xff AES2=0x00 AES3=0x00]
                  numid=60,iface=MIXER,name='IEC958 Playback Con Mask',index=1
                  numid=33,iface=MIXER,name='IEC958 Playback Con Mask',index=16
                  numid=55,iface=MIXER,name='IEC958 Playback Pro Mask'
                    : values=[AES0=0x0f AES1=0x00 AES2=0x00 AES3=0x00]
                  numid=61,iface=MIXER,name='IEC958 Playback Pro Mask',index=1
                  numid=34,iface=MIXER,name='IEC958 Playback Pro Mask',index=16
                  numid=56,iface=MIXER,name='IEC958 Playback Default'
                    ; type=IEC958,access=rw------,values=1
                    : values=[AES0=0x04 AES1=0x00 AES2=0x00 AES3=0x00]
                  numid=62,iface=MIXER,name='IEC958 Playback Default',index=1
                  numid=35,iface=MIXER,name='IEC958 Playback Default',index=16
                  numid=57,iface=MIXER,name='IEC958 Playback Switch'
                    : values=on
                  numid=63,iface=MIXER,name='IEC958 Playback Switch',index=1
                    : values=on
                  numid=36,iface=MIXER,name='IEC958 Playback Switch',index=16
                    : values=off
                  numid=18,iface=MIXER,name='Auto-Mute Mode'
                    ; Item #1 'Enabled'
                    : values=1
                  numid=32,iface=MIXER,name='Beep Playback Switch'
                    : values=off,off
                  numid=31,iface=MIXER,name='Beep Playback Volume'
                    : values=31,31
                  numid=19,iface=MIXER,name='Input Source'
                    ; type=ENUMERATED,access=rw------,values=1,items=3
                    ; Item #0 'Front Mic'
                    ; Item #1 'Rear Mic'
                    ; Item #2 'Line'
                    : values=0
                  numid=20,iface=MIXER,name='Input Source',index=1
                    ; Item #2 'Line'
                    : values=0
                  numid=21,iface=MIXER,name='Input Source',index=2
                    ; Item #2 'Line'
                    : values=0
                  numid=29,iface=MIXER,name='Rear Mic Boost Volume'
                    : values=3,3
                  numid=15,iface=MIXER,name='Rear Mic Playback Switch'
                    : values=off,off
                  numid=14,iface=MIXER,name='Rear Mic Playback Volume'
                    : values=31,31
                  numid=49,iface=PCM,name='Capture Channel Map'
                    ; type=INTEGER,access=r----R--,values=2,min=0,max=36,step=0
                    : values=0,0
                    | container
                      | chmap-fixed=FL,FR
                  numid=48,iface=PCM,name='Playback Channel Map'
                    ; type=INTEGER,access=r----R--,values=6,min=0,max=36,step=0
                    : values=3,4,0,0,0,0
                    | container
                      | chmap-fixed=FL,FR
                      | chmap-fixed=FL,FR,RL,RR
                      | chmap-fixed=FL,FR,RL,RR,FC,LFE
                  numid=50,iface=PCM,name='Playback Channel Map',device=1
                    : values=0,0
                    | container
                      | chmap-fixed=FL,FR
                  numid=51,iface=PCM,name='Capture Channel Map',device=2
                    : values=0,0
                    | container
                      | chmap-fixed=FL,FR
                  numid=52,iface=PCM,name='Capture Channel Map',index=1,device=2
                    : values=0,0
                    | container
                      | chmap-fixed=FL,FR
                  numid=58,iface=PCM,name='ELD',device=3
                    ; type=BYTES,access=r--v----,values=0
                    : values=
                  numid=65,iface=PCM,name='Playback Channel Map',device=3
                    ; type=INTEGER,access=rw---R--,values=8,min=0,max=36,step=0
                    : values=0,0,0,0,0,0,0,0
                    | container
                      | chmap-variable=FL,FR
                  numid=64,iface=PCM,name='ELD',device=7
                    ; type=BYTES,access=r--v----,values=36
                    : values=0x10,0x00,0x08,0x00,0x6c,0x12,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x34,0xa9,0x2c,0xc1,0x50,0x61,0x6e,0x61,0x73,0x6f,0x6e,0x69,0x63,0x2d,0x54,0x56,0x09,0x07,0x01,0x00
                  numid=66,iface=PCM,name='Playback Channel Map',device=7
                    | container
                      | chmap-variable=FL,FR,LFE
                      | chmap-variable=FL,FR,FC
                      | chmap-variable=FL,FR,RC
                      | chmap-variable=FL,FR,RL,RR
                      | chmap-variable=FL,FR,LFE,FC
                      | chmap-variable=FL,FR,LFE,RC
                      | chmap-variable=FL,FR,FC,RC
                      | chmap-variable=FL,FR,FLC,FRC
                      | chmap-variable=FL,FR,LFE,RL,RR
                      | chmap-variable=FL,FR,FC,RL,RR
                      | chmap-variable=FL,FR,LFE,FC,RC
                      | chmap-variable=FL,FR,RL,RR,RC
                      | chmap-variable=FL,FR,LFE,FLC,FRC
                      | chmap-variable=FL,FR,FC,FLC,FRC
                      | chmap-variable=FL,FR,RC,FLC,FRC
                      | chmap-variable=FL,FR,LFE,FC,RL,RR
                      | chmap-variable=FL,FR,LFE,RL,RR,RC
                      | chmap-variable=FL,FR,FC,RL,RR,RC
                      | chmap-variable=FL,FR,RL,RR,RLC,RRC
                      | chmap-variable=FL,FR,LFE,FC,FLC,FRC
                      | chmap-variable=FL,FR,LFE,RC,FLC,FRC
                      | chmap-variable=FL,FR,FC,RC,FLC,FRC
                      | chmap-variable=FL,FR,RL,RR,FLC,FRC
                      | chmap-variable=FL,FR,FC,RL,RR,TFC
                      | chmap-variable=FL,FR,FC,RL,RR,TC
                      | chmap-variable=FL,FR,RL,RR,TFL,TFR
                      | chmap-variable=FL,FR,RL,RR,FLW,FRW
                      | chmap-variable=FL,FR,LFE,FC,RL,RR,RC
                      | chmap-variable=FL,FR,LFE,RL,RR,RLC,RRC
                      | chmap-variable=FL,FR,FC,RL,RR,RLC,RRC
                      | chmap-variable=FL,FR,LFE,FC,RC,FLC,FRC
                      | chmap-variable=FL,FR,LFE,RL,RR,FLC,FRC
                      | chmap-variable=FL,FR,FC,RL,RR,FLC,FRC
                      | chmap-variable=FL,FR,LFE,FC,RL,RR,TFC
                      | chmap-variable=FL,FR,LFE,FC,RL,RR,TC
                      | chmap-variable=FL,FR,LFE,RL,RR,TFL,TFR
                      | chmap-variable=FL,FR,LFE,RL,RR,FLW,FRW
                      | chmap-variable=FL,FR,FC,RL,RR,RC,TC
                      | chmap-variable=FL,FR,FC,RL,RR,RC,TFC
                      | chmap-variable=FL,FR,FC,RL,RR,TFC,TC
                      | chmap-variable=FL,FR,FC,RL,RR,TFL,TFR
                      | chmap-variable=FL,FR,FC,RL,RR,FLW,FRW
                      | chmap-variable=FL,FR,LFE,FC,RL,RR,RLC,RRC
                      | chmap-variable=FL,FR,LFE,FC,RL,RR,FLC,FRC
                      | chmap-variable=FL,FR,LFE,FC,RL,RR,RC,TC
                      | chmap-variable=FL,FR,LFE,FC,RL,RR,RC,TFC
                      | chmap-variable=FL,FR,LFE,FC,RL,RR,TFC,TC
                      | chmap-variable=FL,FR,LFE,FC,RL,RR,TFL,TFR
                      | chmap-variable=FL,FR,LFE,FC,RL,RR,FLW,FRW
                  amixer -c 1 contents:
                  /recalbox/share/system$ amixer -c 1 contents
                  Invalid card number.
                  Usage: amixer <options> [command]
                  Available options:
                    -h,--help       this help
                    -c,--card N     select the card
                    -D,--device N   select the device, default 'default'
                    -d,--debug      debug mode
                    -n,--nocheck    do not perform range checking
                    -v,--version    print version of this program
                    -q,--quiet      be quiet
                    -i,--inactive   show also inactive controls
                    -a,--abstract L select abstraction level (none or basic)
                    -s,--stdin      Read and execute commands from stdin sequentially
                    -R,--raw-volume Use the raw value (default)
                    -M,--mapped-volume Use the mapped volume
                  Available commands:
                    scontrols       show all mixer simple controls
                    scontents	  show contents of all mixer simple controls (default command)
                    sset sID P      set contents for one mixer simple control
                    sget sID        get contents for one mixer simple control
                    controls        show all controls for given card
                    contents        show contents of all controls for given card
                    cset cID P      set control contents for one control
                    cget cID        get control contents for one control
                  amixer -c 2 contents:
                  /recalbox/share/system$ amixer -c 2 contents
                  Available options:
                    -h,--help       this help
                    -q,--quiet      be quiet
                  Available commands:
                  • ian57
                    @Ristul sorry of course it is "controls" in english 🙂
                    • Ristul
                      @ian57 Oh, haha, yes of course 😜
                      So I got these results.
                      amixer -c 0 controls:
                      /recalbox/share/system$ amixer -c 0 controls
                      amixer -c 1 controls:
                      /recalbox/share/system$ amixer -c 1 controls
                      Available options:
                        -h,--help       this help
                        -q,--quiet      be quiet
                      Available commands:
                      amixer -c 2 controls:
                      /recalbox/share/system$ amixer -c 2 controls
                      Available options:
                        -h,--help       this help
                        -q,--quiet      be quiet
                      Available commands:
                      Sadly I have no programming experience so this is all mumbo jumbo to me.
                      • Ristul
                        Ristul @Ristul last edited by
                        @Ristul I gave up and installed recalbox 6.1.1, now the sound works again.
                        • AxelR
                          Hello @ian57 any update on this issue ?
                          Any way to 'force' the audio output to HDMI ?
                          Thanks !
                          • Dekiste
                            Dekiste last edited by
                            Hello,
                            to all the people with the same problem, it worked for me:
                            https://forum.recalbox.com/topic/21453/recalbox-7-plus-de-son-en-hdmi-pc64
                            Regards.
