    ScummVM controls in GPI Case
    GamePad/GPIO/USB encoder
    scummvm controls gpi case
    6
    7
    2712
    • Juan Daniel
      Juan Daniel last edited by
      Hi,
      is there a way to configure ScummVM to use the GPI Case buttons as a mouse? I tested Monkey Island and seems starts fine, but the pointer doesn´t work with the pad.
      Kind regards.
      paradadf ajeoae 2 Replies Last reply Reply Quote 0
        paradadf Staff @Juan Daniel last edited by
        @juan-daniel please wait for the next release. It should work then.
        • Juan Daniel
          Thanks @paradadf ! I will wait 🙂
          • ajeoae
            ajeoae @Juan Daniel last edited by
            @juan-daniel Here's how I got it to work with the D-Pad. There is a hidden feature on the GPi which allows you to change the D-Pad mode. So here are the steps:
            • Go into the emulationstation menu to configure your controller
            • Map Up, Down, Left, Right like normal, and your regular buttons. Most importantly also map Select and Start (this will allow you to do the mode change)
            • Now move up to Joystick1 using your D-Pad and hold down Start and Left for about 5-10 seconds, you'll see the power LED flash purple briefly. You can now map Joystick1 (skip Joystick2).
            To change the D-Pad back to its default mode, hold down Start and Up. Also if you're on an older GPi model use Select instead of Start.
            The only other thing I did was add joystick_num=0 to the scummvm.ini file but I'm not sure if that is necessary.
            Hope that helps!
            • krnr
              krnr last edited by
              I simply replaced the controllersConfig.py from the upcoming 6.1.1 version:
              https://gitlab.com/recalbox/recalbox-configgen/raw/master/configgen/controllersConfig.py?inline=false
              That solved the problem for me. 😎
              Nicolas Jacquemin 1 Reply Last reply Reply Quote 1
              • Nicolas Jacquemin
                Nicolas Jacquemin @krnr last edited by
                @krnr Yes, i confirm the problem in 6.1.1 with GPI Case.
                You need to replace this file at /usr/lib/python2.7/site-packages/configgen/
                • fleafunk
                  fleafunk last edited by
                  @krnr this file did not work for me, the game always crash, I made a modify and now it works for me in the GPi Case with Recalbox 6.1.1 and also works in Recalbox 6.0 with the SUPERPi CASE.
                  Here is the link: https://www.mediafire.com/folder/6rvp64hivvkc9/
                  just replace at /usr/lib/python2.7/site-packages/configgen/
