    Recalbox 18.06.27 is out!
    Announcements
    recalbox 18.06.27 out
    34
    103
    77886
    • shaizen
      shaizen @Substring last edited by
      @substring
      no, it happened after the power supply was suddenly turned off during the game
        Substring @shaizen last edited by
        @shaizen easy to solve : add video_font_path = /usr/share/fonts/truetype/ubuntu_condensed.ttf to retroarchcustom.cfg and retroarchcustom.cfg.origin in share/system/configs/retroarch
        shaizen 1 Reply Last reply Reply Quote 1
        • shaizen
          @substring Thank you so much
            Knows issues : https://gitlab.com/recalbox/recalbox/issues/491
            • Gaetan
              Gaetan Theme moderator @acris last edited by Gaetan
              @acris at this list you should add on Rpi3 the PSP games are going back to ES after the first one is launch (even with stock theme).
              • tyn78
                tyn78 @Substring last edited by
                @substring Thank you so much for the good news about a rp3b+ beta, can't wait to give it a try... 😍😊😍😍👌... It been a long wait...lol
                Thanks again for all you do for us!!!!!
                  temporary fix for N64 + Rice: add n64.args=--audio /usr/lib/mupen64plus/mupen64plus-audio-omx.so to recalbox.conf (don't forget to remove it once it's officially fixed). This is only for Raspberry, other systems don't use Rice.
                  kelv daniel86 2 Replies Last reply Reply Quote 3
                  • Michael Muguet 0
                    Michael Muguet 0 @Substring last edited by
                    @substring said in Recalbox 18.06.27 is out!:
                    @michael-muguet-0 kodi 17 ca ira avec le pi3b+. Vu que les évolutions attendues sur l'infra sont ok, je m'y remets. J'espère une beta publique en Aout, je ne promets rien (j'ai mes congés en juillet)
                    Cool!
                    Je me demandais un truc par rapport au netplay, si des gens ont pas un format standard pour leur nom de roms ça marche quand même?
                    J'ai essayé de lancer vite fait une partie de super Street fighter 2 en netplay mais la rom à crashée. Bon j'ai pas encore poussé les investigations...
                      Substring @Michael Muguet 0 last edited by
                      @michael-muguet-0 c'est pour ca qu'il faut hasher 😉
                      • raffols
                        raffols last edited by
                        Hi! First of all thanks for the efforts put in the update. Since updating I've seen that the temperature of my RPI 3 (not overclocked) is around 65 C without using it, just with ES loaded. I think it never happened to me before (in other releases temperature were around 45 C I recall well). Is there any log I can send for further investigation? Is anyone else experiencing this? (I've seen the temperature through the monitoring web app). Thanks in advance!
                        jorgemagana docbobo 2 Replies Last reply Reply Quote 0
                        • jorgemagana
                          jorgemagana @raffols last edited by
                          @raffols said in Recalbox 18.06.27 is out!:
                          Same here, noticed since november update
                          Substring Michael Muguet 0 2 Replies Last reply Reply Quote 0
                            Substring @jorgemagana last edited by
                            @jorgemagana 7 months without reporting ? ... 😕
                            jorgemagana 1 Reply Last reply Reply Quote 0
                            • Michael Muguet 0
                              Michael Muguet 0 @jorgemagana last edited by
                              @jorgemagana nous overheat here. Just a little last week but it was hot outside.
                              I bought a new case with fan and a dissipator for the bottom (so 3 dissipators on the rpi3b) and no more problem
                              • mi7chy
                                mi7chy last edited by
                                Updated to the new 18.06.27 release and testing it out. Anyone know where VRAM limit setting moved to? Have an issue with PSP games exiting to menu when launched. Want to see if setting VRAM limit to 80MB will help as it seems to have done with previous versions.
                                • jorgemagana
                                  jorgemagana @Substring last edited by
                                  I thought that it was only my problem because the poor ventilation in my game room. Noticed only en Emulation Station navigation. When using the temperature monitor in web manager, I see that the temperature goes down when you enter a game, and rises up again when you return to Emulation Station. Few months ago I bought a case with fan and problem solved, but fan is too noisy.
                                  • docbobo
                                    docbobo @raffols last edited by
                                    @raffols @substring I can confirm this. When ES is running, one of the cores of the RPI3B is running at full 100% constantly and leads to the "Thermometer" Icon in the upper Right Corner. Switching into a game usually stresses a second core then. Somehow there seems to be a Process running constantly that eats cycles. It's not Netplay, I turned that off (unless it still is running, just not doing anything?). Never had overheat warnings with earlier Recalbox Releases. API is turned off too (Web Manager is on).
                                    Again, just for clarity: Turning on Recalbox, doing Nothing, just keeping it at whatever screen it is when starting (with me, Favourites) will after an hour max lead to temperature warnings and one core is constantly at 100%
                                      Substring @docbobo last edited by
                                      @docbobo it's been explained for ages : there is a bug in the webmanager showing constantly a core running at 100% (which is wrong)
                                      docbobo 1 Reply Last reply Reply Quote 0
                                      • docbobo
                                        docbobo @Substring last edited by
                                        @substring OK, fine - but actually the Recalbox IS running hot when Nothing is Happening in EmulationStation. This is a "new" behaviour. I never saw the temperature Icon on my RasbPis before, even during N64 Emulation. Can we agree that an idling ES on an NOT overclocked RPI3 should not drive the CPU over 75 Degrees Celsius?
                                        Substring paradadf 2 Replies Last reply Reply Quote 1
                                          @docbobo never had the temp warning turning on in this release, nor any other before unless my pi would be in a closed case running PSP.
                                          75°C is indeed much, I agree, but i can't even compare with my pi3 for now
                                            paradadf Staff @docbobo last edited by
                                            @docbobo check that your heatsink is properly attached to the processor... if, for any reason, it isn‘t cleanly sticked it results in bad insulation and that‘s counterproductive.
                                            100.3k
