    Recalbox 18.06.27 is out!
    Announcements
    recalbox 18.06.27 out
    34
    103
    77871
    • poumtaq
      poumtaq @emuFan last edited by
      @emufan ...hmmm so what are you doing here ?
      Bartop
      -RPI3
      -RB stable sur SD SanDisk MicroSDHC32 Go
      -Dual-Controller Xin-Mo
      -Stockage externe Clé USB 3.0 Sandisk Ultra Fit 128 Go
      -écran VGA + adaptateur HDMI
      -OS pc : LinuxMint 17
      • barbudreadmon
        barbudreadmon @Substring last edited by
        @substring there was a huge refactoring in savestates for netplay cross-platform compatibility between .42 and .43, if the savestates are older than this, i don't think they can be loaded.
        Libretro developper :
        • FBAlpha FBNeo (Arcade)
        • Kronos (Sega Saturn/ST-V)
        • YabaSanshiro (Sega Saturn)
        • CapFuture1975
          CapFuture1975 last edited by CapFuture1975
          Great update! But now, mame do not work anymore, I can not get coins inserted via gamepad and so i can not start any game! But R2 for the mame menu still works! (Raspberry Pi 3)
          mreis 1 Reply Last reply Reply Quote 0
          • slimshady6913
            slimshady6913 @Gabbo last edited by
            @gabbo @kelv @substring
            not sure if this helps
            all was working until update
            I have same Problem with 64 Black screen tried it on 5 different TV's
            I do get sound though
            I USE i5 and intel 4600 Graphics
            50 Sony 4k TV
            24 Sony PS3 TV
            55 Samsung
            Using Displayport to HDMI Cable
            Also Tried another Fresh USB Build no Upgrade and got the same thing..
            Also took another pc that i have fresh build with HDMI and same thing...
            Also installed the fresh build on i3 intel HD laptop and same thing...
            If i go to advanced emulation setting then go to 64 libretto graphics look weak but it does work.... on all TV's and all PC's
            Hope this helps fix issue
            • delt75
              delt75 last edited by
              I just downloaded the update this morning, and I lost all my Mame games. None are saved in my favorites now, and there isn't the "Arcade" category anymore in my menu screen. Will this get fixed?
              Gaetan voljega 2 Replies Last reply Reply Quote -1
              • Gaetan
                Gaetan Theme moderator @delt75 last edited by
                @delt75 arcade categorie is delete after updates, you'll need to reinstal it by yourself.
                If it comes from a non official image there will be no support.
                delt75 1 Reply Last reply Reply Quote 1
                  voljega Banned @delt75 last edited by
                  @delt75 there is no arcade category in official distribution
                  • delt75
                    delt75 @Gaetan last edited by
                    @gaetan Thanks!
                    • delt75
                      @voljega Thanks!
                      • mreis
                        mreis @CapFuture1975 last edited by
                        @capfuture1975 - Se R2 estiver configurado como Hotkey não funciona para inserir moedas.
                        • Michael Muguet 0
                          Michael Muguet 0 last edited by
                          Merci pour la maj!
                          Toujours pas de Kodi17? On commence à s'impatienter 😛
                          Substring 1 Reply Last reply Reply Quote -2
                            Substring @Michael Muguet 0 last edited by
                            @michael-muguet-0 tu n'imagines même pas combien ma patience est proche du néant quand je lis çà
                            Michael Muguet 0 1 Reply Last reply Reply Quote 2
                            • eskobear
                              eskobear last edited by eskobear
                              Salut les zouzs, bravo pour cette mise à jour, hâte de tester le jeu en réseau si mon routeur panique pas trop ! (puis pouvoir jouer sur Daphne, ça doit être cool, à tester)
                              Une remarque : le crédit s'enclenche mal en manette J1 pour les jeux solos ; pour du jeu à crédit imposé pour un joueur pas de soucis (Sunset Riders fonctionne bien, 1 crédit pour chaque joueur) et pour les jeux multi avec crédits partagés pas de problèmes non plus. Par contre, sur les jeux solos, je peux uniquement mettre un crédit grâce à la manette J2 pour l'instant, mais le Hotkey fonctionne toujours bien et je joue bien avec ma manette J1.
                              Des idées ? Je pourrais vous transmettre des fichiers pour vous aider ? Je vois que le problème est déjà mentionné ceci-dit.
                              Bravo pour la maj tout de même, car c'est un souci mineur que je fais remonter ici.
                              EDIT : J'ai vu le problème mentionné dans un autre topic, en anglais, mais pas de réponse, c'est pour cela que je me permets de placer un message ici. SI ça gène, je déplace ailleurs 😉
                              • Michael Muguet 0
                                Michael Muguet 0 @Substring last edited by
                                @substring C'edt pas pour chercher le conflit que je dis ca. Mais on manque d'info et ça fait presque un an qu'on nous dis que c'est presque prêt.
                                Après je sais que c'est beaucoup de travail un système comme Recalbox et qu'il y a des priorités. Le problème avec Kodi 16 c'est que ça commence à être compliqué avec des extensions qui marchent de moins en moins bien voir qui ne sont plus supportées.
                                Pour connaître quelques personnes sous Recalbox, on est beaucoup à passer beaucoup plus de temps sur Kodi que sur les jeux (j'en lancé même pas un par semaine).
                                Si vous avez pas envie de vous occuper de Kodi c'est pas grave et à moi de me bouger pour passer sur une autre distribution, mais le côté plug and play de Recalbox est vraiment génial et c'est pour ça qu'on est si nombreux dessus.
                                Un version à jour serait une vrai plus value je pense.
                                Voilà c'est que mon avis, je voulais juste des nouvelles, c'est en aucun cas une critique étant donné que je serais bien incapable de créer une distribution ou alors ça me prendrais des années. Faut juste pas se braquer quand on en parle, et si ça te prends la tête qu'on en parle c'est que je dois pas être le seul à demander...
                                Substring 1 Reply Last reply Reply Quote -1
                                • goroots
                                  goroots last edited by
                                  Bon déjà pas de bonjour à tous mais un bonsoir car j'ai 2h de décallage avec vous... je suis là car j'ai envie de passer un gros coup de gueule envers tous les créateurs et participants à Recalbox, franchement yen a marre de votre travail... pfffff 2 mois pour une mise à jour et v'la le travail ............. de oufffff !!!!
                                  Bien sûr je rigole, 2 mois qu'on avait rien eu... et bien c'est tant mieux vu le travail et les choses que vous donnez et partagez avec nous les pauvres noobs juste bon à vous dire mais oulalala vous avez pas fait si où ça... car la c'est du lourd qui tombe dans nos pti doigts et sans rien faire ... alors pour les éternels insatisfaits, si ya pas de pi3b+, vous en achetez normal comme moi, au chaud le temps que ça arrive, et pour kodi 2932 et bien vous faites un double boot libreelec ou autre... car si je l'ai fait c'est pas très compliqué alors !!! Et ya même des pti plugin pour ne même plus voir où basculer sur sur le kodi recalbox ^^
                                  À quand un topic spécial top rageur 😜
                                  En tout cas mille merci pour ce que vous faites pour nous les créateurs, contributeurs et participants car là je rentre dans 2 jours et je n'ai qu'une envie tester tout ça... much love à vous et enjoy 😘
                                  Pi3b+ sd Samsung 32gb + clef sandisk 256gb.
                                  Theme next pixel 480p.
                                  Xbox 360+adaptateur Microsoft, ds4, xbox one filaire, 8bitdo nes pro+arcade, 2 Wiimot gun avec dolphin bar, Clavier sans fil viboton.
                                  Michael Muguet 0 1 Reply Last reply Reply Quote 0
                                  • Michael Muguet 0
                                    Michael Muguet 0 @goroots last edited by
                                    @goroots bah tu vois connaissant mal le raspberry et n'ayant pas le temps de chercher je savais même pas que ça existait merci !
                                    Je viens de faire la maj, le netplay ça a l'air du lourd! Pour le reste je l'utilise pas assez pour juger
                                    goroots 1 Reply Last reply Reply Quote 0
                                    • goroots
                                      goroots @Michael Muguet 0 last edited by goroots
                                      @michael-muguet-0 petit h.s vite fait : regarde sur le forum tout est expliqué.
                                      En synthèse : tu prends noobs, tu mets libreelec et kodi dedans en prenant les 3 sur leur site officiel et Ils s'installent sans prises de tête. Je n'y connaissais rien ... et j'ai appris pti à pti !!!
                                        @michael-muguet-0 kodi 17 ca ira avec le pi3b+. Vu que les évolutions attendues sur l'infra sont ok, je m'y remets. J'espère une beta publique en Aout, je ne promets rien (j'ai mes congés en juillet)
                                        tyn78 Michael Muguet 0 2 Replies Last reply Reply Quote 0
                                        • shaizen
                                          shaizen last edited by
                                          Hello. I have such a problem. With any inscription in the games, skipping, saving, loading, yellow squares, help please0_1530342387219_N30CrGU7lfc.jpg
                                            Substring @shaizen last edited by
                                            @shaizen have you ever customised your retroarch configuration ?
                                            shaizen 1 Reply Last reply Reply Quote 0
                                            100.3k
