    Recalbox 18.06.27 is out!
    Announcements
    recalbox 18.06.27 out
    34
    103
    77871
    • kelv
      kelv @Gabbo last edited by
      @gabbo @Substring Thx Gaboo good to know I'm not alone in the dark
      Raspberry Pi model: RPi 3b+
      Recalbox build : 7.0.1 DragonBlaze
      Hardware: MicroSD UHS 128 GB up to 80 MB, Class 10 and 2.5 A Power Supply.
      Overclocked: 1485 MHZ
      Controller(s): Wired Xbox 360 PAD (working perfectly on any other game/emulator).
      • kelv
        kelv last edited by
        @Substring another issue I have with the update. I'm using a Microsoft Xbox 360 wired pad.
        If somebody could check the file => system/messages log at the support space https://file.ac/dJaeuB5rrBk/
        you will see the error messages cocnerning xpad
        Jun 28 05:56:34 RECALBOX authpriv.info dropbear[2619]: Child connection from 192.168.1.153:65339
        Jun 28 03:56:36 RECALBOX user.debug kernel: [ 553.269273] xpad 1-1.2:1.0: xpad_irq_in - urb shutting down with status: -2
        Jun 28 03:56:39 RECALBOX user.debug kernel: [ 555.609284] xpad 1-1.2:1.0: xpad_irq_in - urb shutting down with status: -2
        Jun 28 03:56:39 RECALBOX user.debug kernel: [ 555.689259] xpad 1-1.2:1.0: xpad_irq_in - urb shutting down with status: -2
        Jun 28 03:56:39 RECALBOX user.debug kernel: [ 555.759355] xpad 1-1.2:1.0: xpad_irq_in - urb shutting down with status: -2
        Jun 28 03:56:39 RECALBOX user.debug kernel: [ 555.859287] xpad 1-1.2:1.0: xpad_irq_in - urb shutting down with status: -2
        Jun 28 03:56:39 RECALBOX user.debug kernel: [ 555.949290] xpad 1-1.2:1.0: xpad_irq_in - urb shutting down with status: -2
        Jun 28 03:56:39 RECALBOX user.debug kernel: [ 556.069334] xpad 1-1.2:1.0: xpad_irq_in - urb shutting down with status: -2
        Jun 28 03:56:39 RECALBOX user.debug kernel: [ 556.149349] xpad 1-1.2:1.0: xpad_irq_in - urb shutting down with status: -2
        Jun 28 03:56:39 RECALBOX user.debug kernel: [ 556.229388] xpad 1-1.2:1.0: xpad_irq_in - urb shutting down with status: -2
        Jun 28 03:56:39 RECALBOX user.debug kernel: [ 556.329311] xpad 1-1.2:1.0: xpad_irq_in - urb shutting down with status: -2
        Jun 28 03:56:40 RECALBOX user.debug kernel: [ 556.409283] xpad 1-1.2:1.0: xpad_irq_in - urb shutting down with status: -2
        Jun 28 03:56:40 RECALBOX user.debug kernel: [ 556.509268] xpad 1-1.2:1.0: xpad_irq_in - urb shutting down with status: -2
        Jun 28 03:56:40 RECALBOX user.debug kernel: [ 556.589246] xpad 1-1.2:1.0: xpad_irq_in - urb shutting down with status: -2
        Jun 28 03:56:40 RECALBOX user.debug kernel: [ 556.709247] xpad 1-1.2:1.0: xpad_irq_in - urb shutting down with status: -2
        Jun 28 03:56:40 RECALBOX user.debug kernel: [ 556.829255] xpad 1-1.2:1.0: xpad_irq_in - urb shutting down with status: -2
        Jun 28 03:56:40 RECALBOX user.debug kernel: [ 556.889247] xpad 1-1.2:1.0: xpad_irq_in - urb shutting down with status: -2
        thx!!
          Substring @kelv last edited by
          @kelv the rice problem is confirmed by ither people. You can meanwhile switch to gliden64
          kelv 1 Reply Last reply Reply Quote 0
            @kelv is there anything wrong happening with your pad beside the.logs (tjat i've always had myself)
            • kelv
              kelv @Substring last edited by
              @substring I found the issue in the logs.
              Go to system/logs/es_launch_stdout.log at https://file.ac/dJaeuB5rrBk/ there is an error message stating ERROR: Failed to get display size
              UI-Console: using Video plugin: 'Mupen64Plus OpenGL Video Plugin by Rice' v2.0.0
              UI-Console: using Audio plugin: 'Mupen64Plus SDL Audio Plugin' v2.5.0
              Input: Using auto-config file at: '/recalbox/share/system/configs/mupen64/InputAutoCfg.ini'
              UI-Console: using Input plugin: 'Mupen64Plus SDL Input Plugin' v2.5.0
              UI-Console: using RSP plugin: 'Hacktarux/Azimer High-Level Emulation RSP Plugin' v2.5.0
              Input: 1 SDL joysticks were found.
              Input: N64 Controller #1: Using auto-config with SDL joystick 0 ('Microsoft X-Box 360 pad')
              Input: 1 controller(s) found, 1 plugged in and usable in the emulator
              Input: Rumble activated on N64 joystick #1
              Input Warning: Couldn't open rumble support for joystick #2
              Input Warning: Couldn't open rumble support for joystick #3
              Input Warning: Couldn't open rumble support for joystick #4
              Input: Mupen64Plus SDL Input Plugin version 2.5.0 initialized.
              Video: Disabled SSE processing.
              Video: ROM (CRC 1fa83dd4191e1e02-45) not found in INI file
              Video: Enabled hacks for game: 'THE LEGEND OF ZELDA'
              Video: Initializing OpenGL Device Context.
              Core: Setting 16-bit video mode: 0x0
              Video Warning: Failed to set GL_SWAP_CONTROL to 0. (it's 16)
              Video Warning: Failed to set GL_DEPTH_SIZE to 16. (it's 24)
              Video: Using OpenGL: Broadcom - VideoCore IV HW : OpenGL ES 2.0
              Audio: Initializing SDL audio subsystem...
              • kelv
                @substring I may say that I'm noticing a bit of input lag like.
                  @kelv thank you very much for this feedback ! I'll dig this once back home 🙂
                  • MilesCW
                    MilesCW last edited by
                    Guys, don't be stingy with the change log and add more details to the blog please.
                    Just found out that the Daphne Emulator has been added. Nice!
                    Substring 1 Reply Last reply Reply Quote -1
                    • lmerckx
                      lmerckx last edited by
                      More information about Daphne can be found on Wiki:
                      https://github.com/recalbox/recalbox-os/wiki/Daphne-(EN)
                      Recalbox 9.1 on RPI 4, SSD 250Gb, 2 Logitech F710, Nespi4case
                      Contributions for DosBox, ScummVM, ResidualVM, Daphne (Hypseus)
                        Substring @MilesCW last edited by
                        @milescw daphne is listed in both changelog and blog
                        Sebastien Brossard 1 Reply Last reply Reply Quote 1
                          voljega Banned @lmerckx last edited by voljega
                          @lmerckx said in Recalbox 18.06.27 is out!:
                          Excellent !
                          For now I wasn't able to find any romset in the right format but Dahpne romsets seems hard to get and to exist in a variety of format...
                          Here is the list of suported games by Daphne's :
                          https://www.daphne-emu.com:9443/mediawiki/index.php/Main_Page#Games_that_you_can_play_using_Daphne
                          • emuFan
                            emuFan last edited by
                            3 monthes that every new rasperry pi buyer can't even launch your project and the next update change everything but this problem...
                            Have you some words for those who can't share your enthusiasm with this update ?
                            Substring voljega poumtaq 3 Replies Last reply Reply Quote -5
                              Substring @emuFan last edited by
                              @emufan I hardly have any patience when I read such encouragements ... So I'd better not answer
                              1 Reply Last reply Reply Quote 4
                                voljega Banned @emuFan last edited by
                                @emufan yeah what is your participation to recalbox project again ?
                                • berurier01
                                  berurier01 last edited by
                                  Question bête, j'ai logiquement trouvé un romset fba en 0.2.97.43, mais quand je lance un jeu écran noir et reviens au menu. Est ce qu'il faut trouver un bios à jour aussi?
                                  Et j'ai lu plus haut que la version mame n'avais pas changer par rapport à avant, mais quand je lance un jeu mame pareil ça ne le lance pas
                                  • Sebastien Brossard
                                    Sebastien Brossard @Substring last edited by
                                    @substring Hello, I couldn't find the folder /rom/Daphne or /rom/Hypseus . I managed to create it manually, is it the right process ?
                                    Thx
                                      OyyoDams Staff @berurier01 last edited by
                                      @berurier01 lis la doc arcade dans le wiki, ça ne s'improvise pas.
                                      @Sebastien-Brossard please read the wiki page about Daphne.
                                      Sebastien Brossard 1 Reply Last reply Reply Quote 0
                                        Sebastien Brossard @OyyoDams last edited by
                                        @oyyodams Sure 😉 si j'ai posé la question ce n'est pas pour rien 😉
                                        probleme de synchro entre winscp et putty qui n'affiche pas la même chose va savoir pourquoi.
                                        merci du retour
                                          @substring ok, but my old saves could be used with the new core ? At the moment, they can't be loaded,
                                            @barbudreadmon are savestates compatible from .42 to .43 ?
                                            100.3k
