    [SOFT] Arcade Manager : install overlays and manage roms in a user-friendly, fast and cross-platform GUI
    Community projects
    arcade manager overlays roms bezel
    18
    49
    32567
    • cosmo0
      cosmo0 @Olliko last edited by
      @olliko said in [SOFT] Arcade Manager : install overlays and manage roms in a user-friendly, fast and cross-platform GUI:
      @cosmo0 i use fba_libretro.
      Well that's what I used too... weird...
      Anyone else had the same problem ?
      • gnubit
        gnubit @cosmo0 last edited by gnubit
        @cosmo0
        Thanks for the app, but I`m having troubles with it also.
        The overlays are downloading to /recalbox/share/system/configs/overlays/fba_libretro (when I tell the app the roms are located at "/recalbox/share/roms/fba_libretro") which is great, but the .cfg files are referring to an incorrect path.
        the *.zip.cfg are located at /recalbox/share/system/configs/overlays/fba_libretro
        As example (3countb.zip.cfg) lists this in the file:
        input_overlay = /recalbox/share/overlays/fba_libretro/arcade-artwork/3countb.cfg
        input_overlay_enable = true
        input_overlay_opacity = 0.900000
        input_overlay_scale = 1.000000
        ie: not referring to "/recalbox/share/system/configs/overlays/fba_libretro/arcade-artwork" where the artwork is located
        I have tried in the configs setup in the app to use "/recalbox/share/system/configs" and
        "/recalbox/share/system/configs/retroarch/overlays" (where another overlay path is used, for example zover4recalbox `s overlay) with the same result.
        I am currently using pack01-clean-1080 from zover4recalbox for my libretro cores which work. Is there a conflict with them, or just the *.zip.cfg are referring the wrong path?, or perhaps I`m just doing it wrong and need a little guidance.
        Thanks in advance.
        cosmo0 1 Reply Last reply Reply Quote 0
          Stupid question as i was really lazy to read the whole topic and test the software : can it check roms against dat files ?
          • cosmo0
            cosmo0 @gnubit last edited by
            @gnubit said in [SOFT] Arcade Manager : install overlays and manage roms in a user-friendly, fast and cross-platform GUI:
            @cosmo0
            Thanks in advance.
            Hello
            The overlays should actually be downloaded to /recalbox/share/overlays/fba_libretro/.
            Are you telling the software to download to /recalbox/share/system/configs/, or is it doing that automatically?
            @substring said in [SOFT] Arcade Manager : install overlays and manage roms in a user-friendly, fast and cross-platform GUI:
            Nope 🙂 it doesn't rebuild romsets.
            gnubit Substring 2 Replies Last reply Reply Quote 0
            • gnubit
              @cosmo0
              Thanks for the reply. It looks like it may be doing it automatically.
              I tried again with these inputs:
              Roms folders
              /run/user/1000/gvfs/sftp:host=XXX.XXX.X.XXX/recalbox/share/roms/fba_libretro
              Config share
              /run/user/1000/gvfs/sftp:host=XXX.XXX.X.XXX/recalbox/share/system
              with the same result. 0_1526081918778_Screenshot from 2018-05-12 09-05-06.png
                Substring @cosmo0 last edited by
                @cosmo0 i dont mean "rebuild", i mean simply check if the rom is valid
                • cosmo0
                  Config share
                  Config share should be just recalbox/share, not /system 🙂 Let me know if it fixes it 🙂
                  And sorry, I didn't test my program with Linux 😞 every distro seems to have a different method for accessing , and apparently even the same distro can change the path to access Samba share from version to version... 😕 I've made things automagical for Windows and MacOS but Linux looks too hard 😞
                  gnubit 1 Reply Last reply Reply Quote 0
                  • cosmo0
                    cosmo0 @Substring last edited by
                    No, sorry.
                    First, because CLR Mame Pro already does that, and it works under all platforms (using Wine for Mac/Linux). Despite the... complicated interface, I'm not a fan of doing things that have already been done.
                    And second, because this tool was designed for Retropie at the beginning, and this feature wouldn't make sense in Retropie, between the "arcade" folder, the multiple MAME versions, etc. As you're probably aware, Retropie is... complicated 😄
                    I might do it in a later version, though, it's not really complicated (open a zip file, checksum the files inside, check against data in an XML...).
                      @cosmo0 said in [SOFT] Arcade Manager : install overlays and manage roms in a user-friendly, fast and cross-platform GUI:
                      Indeed 😉 hence my suggestion 😄
                      • gnubit
                        @cosmo0
                        Yippie! it works with the config share as /recalbox/share
                        You may want to mention the config share path in the help section for linux on your next release.
                        Many thanks 🙂
                        • cosmo0
                          @cosmo0
                          Glad to hear that 🙂
                          Yep, will do 🙂
                          • mathieum
                            mathieum last edited by
                            Hi ! Nice app.
                            But i sée on net something quite interressing : the bezel project. But for retropie. Maybe You Can use it to update your app.
                            https://github.com/thebezelproject
                            • cosmo0
                              cosmo0 @mathieum last edited by
                              @mathieum hey !
                              Thanks but I already saw it. They don't have as many overlays as I do 🙂 They do have a few more but they're not 16:9.
                              The big difference is that they have copied all overlays for the clones, and they have generic ones when no one exists. So it looks like they have 6000 overlays but on reality there are less than 1000, and I have more than 1200 unique ones.
                              Cirion toniosj 2 Replies Last reply Reply Quote 0
                              • kooper
                                kooper Banned last edited by
                                Thank you very much for the good program you have done. It's good work.
                                • kooper
                                  This post is deleted!
                                  • Cirion
                                    Cirion @cosmo0 last edited by
                                    @cosmo0 This Arcademanager is GREAT! Pretty cool stuff! Now, I do agree that you should look into "The Bezel Project". They have a lot of individual bezels for a lot of systems! Because of you and your Arcademanager I was able to use them manually 🙂 I had no way of making it work, and the Recalbox wiki is plain wrong. It does not work. But the way you did it with a subfolder for the config + image, and use a config file to point to that work great. I now am able to manually add bezels fom "The Bezel Project". Add those bezels to your manager and make it easy for every system available 🙂
                                    paradadf 1 Reply Last reply Reply Quote 1
                                      paradadf Staff @Cirion last edited by
                                      @cirion the wiki is editable by anyone, so you can help the community by correcting it ;).
                                      Cirion 1 Reply Last reply Reply Quote 0
                                      • Cirion
                                        Cirion @paradadf last edited by
                                        @paradadf I have done it... But I suck at getting it to look right, feel free to clean up my info. Look at the bottom:
                                        https://github.com/recalbox/recalbox-os/wiki/Retroarch-setup-overlays-(EN)
                                        • A Former User
                                          A Former User last edited by
                                          Hi! I use this software a lot and I would appreciate an update for Recalbox 6. Thanks 🙂
                                          • toniosj
                                            toniosj Spanish moderator @cosmo0 last edited by
                                            @cosmo0 We miss you!!
                                            The best software to download overlays for our Recalbox.
                                            Hopefully one day you can get an updated version.
                                            Thanks for your work!
                                            100.8k
