    [SOFT] Arcade Manager : install overlays and manage roms in a user-friendly, fast and cross-platform GUI
    Community projects
    arcade manager overlays roms bezel
    18
    49
    32571
    • cosmo0
      cosmo0 last edited by
      New version 5.1
      https://github.com/cosmo0/arcade-manager/releases
      New features
      • Can now convert MAME DAT files to CSV
      • Small help pages improvements
      • Upgrades libraries to latest versions
      Bugfixes
      • Fixes some CSV parsing bugs
      • Make everything work (again?) with latest Recalbox release (7.1)
      Known bugs
      • Overlays installation doesn't seem to be working on Linux. It will require quite a lot of work to fix.
      • Forest Carmel
        Forest Carmel last edited by
        The Information you shared above is great. I have been reading all you shared here. In this you explained everything very well. If i want any further guideline we will contact you here https://forum.recalbox.com/topic/13964/soft-arcade-manager-install-overlays-and-manage-roms-in-a-user-friendly-fast-teatimeresults-and-cross-platform-gui/30?lang=en-GB. I am going to bookmark this thread.
        • paanjii2
          paanjii2 last edited by
          this is really good post, thank you for sharing this information with us
          • paanjii2
            This post is deleted!
            • cosmo0
              New version, converted to .Net and fixes a bunch of bugs: https://github.com/cosmo0/arcade-manager/releases
              • cosmo0
                New version, because the previous one had a breaking bug.
                https://github.com/cosmo0/arcade-manager/releases/tag/v6.2
                Also adds support for roms in .7z format, and adds CSV lists for MAME 2003+ and FBNeo 1.0.0.2
                • cosmo0
                  cosmo0 last edited by cosmo0
                  New version: with a wizard ! It allows you to easily copy a selection of great games in a few clicks.
                  https://github.com/cosmo0/arcade-manager/releases/tag/v7.0-rc1
                  home
                  The app is now translated; for now only in french, let me know if you can help!
                  • cosmo0
                    Update release because the wizard wasn't working anymore (oops)
                    https://github.com/cosmo0/arcade-manager/releases/tag/v7.1
                    • cosmo0
                      After more than two years, I finally found the motivation to work on this project again and improve it.
                      Download: Release ArcadeManager v25.1
                      New features
                      The biggest new feature is the ability to check a romset against a DAT file, and to transform a romset into a non-merged one. Several common DAT files are provided: MAME for the latest Batocera and Recalbox versions, MAME2003 in different flavors, and FBNeo. Merged and split sets are not supported, as they make no sense in the context of this tool.
                      Other new features:
                      • Completely rewrote the "top x" lists in the wizard and added some new selections
                      • Added some new games lists in the wizard (4 buttons, vertical, multiplayer vs/coop)
                      • Before copying files listed in a CSV, the app now lists the missing ones
                      • Added the possibility to help translate using Weblate
                      • New translation in Swedish - please contribute to other languages if you can, it's not hard!
                      • A new console application has been created, in case you want to automate things
                      • In the latest MAME versions some files (other than samples and bioses) are needed, they are now copied along with the roms
                      Fixed bugs
                      • The Windows zip file version launches the debug window upon starting
                      • Crash when a CHD file already exists
                      • 404 link in the help section
                      • Encoding error in some JS error messages
                      • Path with "+" doesn't work
                      100.8k
