    Recalbox 18.04.20 is out!
    Announcements
    recalbox 18.04.20 out
    22
    46
    58199
      Substring last edited by abunille
      Hey guys !
      A new update is available, please read the blog for a detailled changelog 🙂
      1 Reply Last reply Reply Quote 4
      • Gaetan
        Gaetan Theme moderator last edited by
        Thank you ! 🙂
        • Bloodsurfer
          Bloodsurfer last edited by
          Yay, great work! Thanks! 🙂
          • Martin Steiner
            Martin Steiner last edited by
            Nice work guys. The only things that keeps me from migration is the lack of videosnaps. I don't understand that... Why?
            rockaddicted Gaetan 2 Replies Last reply Reply Quote 0
              rockaddicted @Martin Steiner last edited by
              @martin-steiner because we are waiting that you add it to the system...
              2Dsx 1 Reply Last reply Reply Quote 1
              • Gaetan
                Gaetan Theme moderator @Martin Steiner last edited by Gaetan
                I can download it now, great ! 🙂
                • goeland
                  goeland last edited by
                  @substring
                  Merci pour votre constant travail. J'ai découvert par hasard Recalbox, il y a quelques semaines, et depuis je me replonge dans les jeux de mes 13ans... formidable machine à remonter le temps.
                  Raspberry Pi3 B+
                  Lenovo Tiny P330
                  Manettes
                  • 8BitDO SN30 Pro
                  • Hori Battle Pad Manette Filaire Type GameCube
                    Version RecalBOX Recalbox 9.1 Pulstar
                  • RustyMG
                    RustyMG last edited by
                    Hi,
                    My post from 5 minutes ago has vanished?
                    I was asking @substring if the fatal memory leak bug was fixed in this release, as it was mentioned last week someone had discovered a fix just after it looked like it might take a while to track down.
                    Cheers!
                    Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
                    • Butch2k
                      Butch2k last edited by
                      Looks like there is a regression with XU4. It boots and works fine until i set up external storage (128GB USB3), then on reboot i get stuck on the boot screen (the one with date on bottom left and small logo at bottom center). I did not have this issue with previous versions.
                      The problem appears both when doing an in place upgrade (in which case it gets stuck after reboot as i had external storage already set up) and with a brand new image (after setting up the storage as external).
                      Butch2k 1 Reply Last reply Reply Quote 0
                        voljega Banned @RustyMG last edited by
                        @rustymg @supernature2k should know 🙂
                        on my side after testing dozens of games on fba_libretro and then mame, I saw the thermometer icon appear indicating the pi was overheating, didn't appear in previous version, but we'll see
                        RustyMG 1 Reply Last reply Reply Quote 0
                        • lackyluuk
                          Great update, really appreciate your work.
                          I have noticed some points 🙂
                          • Pop-Up messages could be visible a little bit longer. They dissapear quite fast
                          • My clock in the main menu is 2h behind. Is it my Raspi which is somehow wrong? Isnt it possible to have the clock on the front view? (Where you see the systems, maybe with the current date)
                          • This is maybe a bug: If I go to advanced settings and i move to the VRAM settings, the cursor just move further, just like I would keep my button pressed. It happens only on the vram entry in both directions. Can somebody confirm this?
                          goeland Substring 2 Replies Last reply Reply Quote 0
                          • goeland
                            goeland @lackyluuk last edited by
                            @lackyluuk
                            yes, the same for me. clock and moving
                            Raspberry Pi3 B+
                            Lenovo Tiny P330
                            Manettes
                            • 8BitDO SN30 Pro
                              Substring @lackyluuk last edited by
                              @lackyluuk only @supernature2k can
                              • nwildner
                                nwildner last edited by
                                Holy f***!
                                Battery status isn't even at the changelog and arrived on this version. You guys rock!!!
                                Thanks for all your hard work with this wonderful project!
                                alt text
                                PT_BR Retrogaming on Telegram
                                  paradadf Staff last edited by paradadf
                                  I‘m not sure this happened on the previous version (probably), but I just noticed you don‘t get the restart, shut down and fast shut down icons when you press START and QUIT, but you see the icons when you just press SELECT.
                                  And my clock is showing a wrong time altough my timezone is properly configured on recalbox.conf.
                                  • Butch2k
                                    Butch2k @Butch2k last edited by
                                    @butch2k I let it run all night long and it finally booted up. Looks like there is some kind of rom scanning or something which takes a hell lot of time.
                                    • VILLAformer
                                      VILLAformer last edited by
                                      I have problem with the last update. I have a problem with the last update. When I change the theme to the classic interface, the raspberry freezes and I have to unplug it as it does not respond. For it to work I have to keep the Next theme.
                                      Eksdad 1 Reply Last reply Reply Quote 1
                                      • RustyMG
                                        RustyMG @voljega last edited by
                                        @voljega Ahhhh, thats right - it was @supernature2k that said "Ah ah clever man knows where to get info 😉 Yes the fix will be included in next release coming anytime soon"
                                        Hope the fix is an undocumented addition to this release 🙂
                                          Substring @RustyMG last edited by
                                          @rustymg some ppl forgot to cireectly amebd the changelog 😮
                                          • nicko
                                            nicko last edited by
                                            Merci pour cette maj
                                            Vous avez déjà des idées d'utilisation des messages popups ?
