    N64 mayflash adapter + OEM controller
    GamePad/GPIO/USB encoder
    mayflash adapter oem
    4769
      paradadf Staff last edited by
      Hi! I finally got to test my n64 adapter with my original n64 controllers and couldn´t find what´s wrong, so I need your help 😄 (I plan to write a proper wiki entry about configuring n64 like pads about this!)
      My config:
      Rpi3, recalbox 18.02.09, n64 mayflash controller adapter, original n64 controller connected on port 1
      My problem:
      After plugging the adapter, the controller and configuring it on ES (all buttons but right analog and L3+R3 mapped on ES), no game at all from any system will launch. Unplugging everything doen not revert this behaviour, no game will start.
      What I have for anyone willing to debbug my problem:
      I made support files after every step, meaning:
      1. Only n64 mayflash adapter plugged in
      2. Adapter + 1 controller on port 1
      3. Adapter + controller + configured the controller in ES
      4. After launching some games on different systems
      Download support files here
      Thanks in advance!
        Your es_input.cfg seems giving problems ... Your gamepad name may need to escape some caracters
          paradadf Staff @Substring last edited by
          @substring deleting my controllers entry on es_input.cfg does indeed allow me to start games again. Any suggestion about what I can try to make the controller usable? I tried escaping  in many different combinations, but nothing.
          deviceName="USB GamePad USB GamePad"
          evtest shows me this rectangle :S
          Input device name: "USB GamePad USB GamePad"
          trying it with that symbol, alone or escaped \ does not work either.
            Substring @paradadf last edited by
            @paradadf ES should correctly escame them ... I'm rather thinking about html entities, and convert it to & rather. Anyway, if the name doesn't match, it will look for the GUID, so you can just remove the annoying chars and see if it gets mapped.
              @substring ok, learning about html entities now 😄
              indeed &#24, has already been escaped from ES and that is an unknown character!
              Erasing &#24, from the name in es_input.txt allowed me to use the controller. I need to find out about the custom mapping now by reading the wiki carefully.
              Nb. there is related topic here:
              https://retropie.org.uk/forum/topic/11568/mayflash-n64-adapter-not-working-not-configured
              • lackyluuk
                @paradadf @Substring
                I am using the "raphnet N64 to USB" adapter and it works out of the box with the original controller. For the config I tried today a little bit and came up with this solution for mupen64plus. Its pretty close to the original:
                Actually I think the SELECT is not needed.
                I tried to edit the mupen64plus.cfg and add a button combo (START + Z Trigger (L2)) to exit the emulator:
                # SDL keysym for stopping the emulator
                Kbd Mapping Stop = "J0B3/B2"
                Button 2 and 3 are Z Trigger and Start. But it does not work. I read something about to disable the Hotkey commands for mupen64plus. Is this possible and could be a solution?
                Substring paradadf 2 Replies Last reply Reply Quote 0
                  Substring @lackyluuk last edited by
                  @lackyluuk I don't remember the combo syntax for mupen, it's somewhere in configgen 😮
                  • lackyluuk
                    @Substring np, I will just try & error 😄
                    the hotkeys are currently not working at all, thats why I would like to map them like this and disable it.
                      paradadf Staff @lackyluuk last edited by paradadf
                      @lackyluuk I‘ll try to comment again about this this weekend. But I have a slightly different mapping in mind (made on ES). D-pad and (left) joystick is obvious. I would then map
                      C-down : A
                      A : B
                      C-left : X
                      B : Y
                      L : L1
                      Z : L2
                      R : R1
                      Start : Start
                      C-up : Select
                      C-right : R2
                      C-up -> Hotkey (on top of Select)
                      After that, I would launch a n64 game.
                      Later, I‘d add n64.configfile=dummy to recalbox.conf and would remap the inputautoconfig (or similar) to match my controller exactly. Finally, adjusting the deadzone my be needed... I must find out how to get the exact values for my joystick yet!
                      I was able to exit games by doing HK+Start without modifying anything on the mupen64plus.cfg.
                      With this mapping, even if you don‘t do the specific remap for mupen, I believe the controller is still very much usable for n64 as, for instance, n64‘s A becomes ES‘s B wich was mapped to A, and n64‘s B becomes ES‘s Y wich was mapped to B!
                        paradadf Staff last edited by strodown
                        Not quite finished but this config might be of help for anyone stumbling upon this topic:
                        After adding n64.configfile=dummy to recalbox.conf to avoid configgen to generate the button mapping, you can copy this configuration into /recalbox/share/system/configs/mupen64/InputAutoCfg.ini:
                        [USB GamePad USB GamePad]
                        plugged = True
                        plugin = 2
                        AnalogDeadzone = 2096,2096
                        AnalogPeak = 21912,21912
                        Mempak switch =
                        Rumblepak switch =
                        mouse = False
                        A Button = button(1)
                        B Button = button(2)
                        C Button D = axis(2+)
                        C Button L = axis(3+)
                        C Button R = axis(3-)
                        C Button U = axis(2-)
                        DPad D = hat(0 Down)
                        DPad L = hat(0 Left)
                        DPad R = hat(0 Right)
                        DPad U = hat(0 Up)
                        L Trig = button(6)
                        R Trig = button(7)
                        Start = button(8)
                        Z Trig = button(9)
                        X Axis = axis(0-,0+)
                        Y Axis = axis(1-,1+)
                        I need to dig deeper into the AnalogDeadZone and AnalogPeak to find the best way to get the proper values.
                        Do not forget to delete the garbage characters on /recalbox/share/system/.emulationstation/es_input.cfg
                        (.emulationstation is a hidden directory!)
                        I‘ll share a proper mapping for it as soon as I can.
                        100.9k
