    [Script] CLCD display on recalbox
    Community projects
    [script] clcd display recalbox
    8
    29
    13516
    • La Vague
      La Vague @paradadf last edited by
      @paradadf
      hello,
      it is not work :
      Using username "root".
      root@recalbox's password:
      sh-4.3# cd /recalbox/scripts/
      sh-4.3# chmod +x ./clcd-install.sh
      chmod: ./clcd-install.sh: Read-only file system
      sh-4.3# ./clcd-install.sh
      ./clcd-install.sh: line 7: syntax error near unexpected token newline' ./clcd-install.sh: line 7: <!DOCTYPE html>'
      sh-4.3#
      thanks
      • La Vague
        La Vague last edited by
        @choum
        bonjour choum,
        désolé pour le retour tardif, j'ai du m'absenter 15 jours.
        login as: root
        i2cdetect -y 1
         0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
        00: -- -- -- -- -- -- -- -- -- -- -- -- --
        10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
        20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
        30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
        40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
        50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
        60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
        70: -- -- -- -- -- -- -- --
        • La Vague
          ls /dev/ :
          il y a bien I2c-1
          La Vague 1 Reply Last reply Reply Quote 0
            paradadf Staff @La Vague last edited by paradadf
            @la-vague make the partition rewritable with:
            mount -o remount,rw / before trying to change permits.
            And it seems to me you haven‘t copied the script properly, but downloaded some html code instead. After you copy the script, open it wirh WinSCP (use it to copy it too!) and see the file matches the code itself.
            • La Vague
              La Vague @La Vague last edited by
              bonjour,
              pb trouver en remplaçant le fichier recalbox.conf avec celui d'origine c'est lui qui était en cause.
              merci a tous
              • Andrei
                Andrei last edited by
                GPIO03 (Pin 5 ) i have it on Power button, what can i do in this case? Can i transfer it on other GPIO pin?
                Choum 1 Reply Last reply Reply Quote 0
                • Choum
                  Choum @Andrei last edited by
                  @andrei
                  I'm not sure you can do that.
                  Why don't you put your power button on the run switch of the board which is normally intended for that ?
                  • Andrei
                    good idea , i will try that
                    • apkdodo2
                      apkdodo2 last edited by
                      Hey thanks for the answers guyz!
                      Thank you so much!
                      100.2k
