    Recalbox not working on my 5" HDMI LCD Screen
    recalbox waveshare hdmi screen
    • Free
      Free last edited by
      Hi, I'm having a problem with Recalbox, I want to do a Handheld Game Console project and I tried before the SD image and works perfectly with my HDMI monitor, but when I try connecting my Raspberry Pi 3 B to the Waveshare 5" HDMI Screen (Waveshare 5" Screen) the screen turns white with lines moving, impossible to see anything. I changed the config.txt file according to my screen specs (max_usb_current=1 hdmi_group=2 hdmi_mode=87 hdmi_cvt 800 480 60 6 0 0 0 hdmi_drive=1) and it's not working either, and I know it's not screen's fault because it works with Retropie and that config.txt, but I just don't want to use it because Recalbox worked so much better on my big monitor...
      Does anyone know why does this happen? Thank you in advance 🙂
      Recalbox Screen
      • ian57
        ian57 Staff last edited by
        @Free Is Recalboc booting ? this white screen show that it is powered but not supported : a bad configuration?
        see here https://github.com/recalbox/recalbox-os/wiki/TFT5-Screen-HDMI-(EN) check you have the same configuration. I had realy no problem to make it work with Recalbox.
        Free 1 Reply Last reply Reply Quote 0
        • Free
          Free @ian57 last edited by
          @ian57 Hey, thank you for answering, this is my configuration:
          config txt
          It's the same as the one in that link but I used Notepad ++ to edit the config.txt instead of that SSH thing which I don't understand much, is that the problem?
          By default the Recalbox image works perfectly on my 24" Monitor, i don't know what could be the problem...
