    No option for onscreen keyboard
    option onscreen keyboard
    3289
    • DJAndrom3da
      DJAndrom3da last edited by
      According to this video: https://www.youtube.com/watch?v=LeWHVSflngU there should be an option under UI Settings to turn on the onscreen keyboard for those of us who only use a controller with Recalbox, but I can't find it. Why is that, and is there a way to fix this or edit the configuration file to enable it?
        paradadf Staff last edited by
        Please, read www.blog.recalbox.com for further information.
        OSK is only available on 4.1 unstable.
        DJAndrom3da 1 Reply Last reply Reply Quote 0
        • DJAndrom3da
          DJAndrom3da @paradadf last edited by
          @paradadf So I'll have to downgrade to 4.1?
          • lackyluuk
            @DJAndrom3da it's rather an upgrade than a downgrade 😉
            What version do you have currently?
            • DJAndrom3da
              DJAndrom3da @lackyluuk last edited by
              @lackyluuk 4.0.2
              • lackyluuk
                @DJAndrom3da then you have to set the update type to unstable in the recalbox.conf. after this you will get notified about the 4.1 unstable.
                But be aware: unstable means unstable and is not recommended for daily use now. But it works quite well actually 🙂
                DJAndrom3da 2 Replies Last reply Reply Quote 0
                • DJAndrom3da
                  DJAndrom3da @lackyluuk last edited by DJAndrom3da
                  @lackyluuk alright I changed it to unstable, now how can I get it back to 4.0.1?
                    paradadf Staff @DJAndrom3da last edited by
                    @DJAndrom3da you can't downgrade.
                    • DJAndrom3da
                      @lackyluuk That did it. Thank you so much for your help!
                      • lackyluuk
                        @DJAndrom3da glad it works 🙂 its not 4.0.1 its 4.1 😉
