    [release-WIP] Theme Recalbox-multi (help needed)
    Themes & Interface
    [release-wip] theme recalbox-multi
    22
    57
    48825
    • supernature2k
      supernature2k last edited by supernature2k
      Hi All,
      I recently made a lot of changes to the recalbox-multi theme and need your help to finalize it.
      The concept of recalbox-multi is that you have 30 54 themes in 1!
      With only one theme, you can easily change the layout and color scheme to have something different:
      • main screen
      main screen
      The same as standard recalbox theme you will say. That's right!
      Imgur
      standard layout / darker colorset
      Imgur
      white & black colorset
      Imgur
      no description layout / white & black colorset
      Imgur
      big picture layout / black & white colorset
      Imgur
      portrait layout / bluechoco colorset
      Imgur
      supernature2k layout / darker colorset
      and the brand new one:
      Imgur
      controls layout / darker colorset
      To change the layout / colorset, you just have to comment/uncomment lines in the config file located in recalbox-multi/data/config.xml :
      Imgur
      You can also "force" a specific layout for a system by doing the same in the theme.xml file of the system (e.g. /recalbox-multi/snes/theme.xml)
      This theme has been tested in several resolutions but I can't test everything, that's why I need help from you, especially for uncommon and low resolutions (640x480, 5/4, 16/10 and so on...)
      Second thing I need is for the new layout, "controls". I was not able to find all the existing standard controls layout, a lot are still missing, see table hereunder:
      Systems Controller layout
      Amstrad cpc missing
      Atari 2600 missing
      Atari 7800 missing
      Atari ST missing
      CaveStory missing
      Favoris N/A
      FDS (Family Computer Disk) missing
      Final Burn Alpha missing
      Final Burn Alpha Libretro missing
      Game & Watch missing
      Game boy color Done
      Game Gear Done
      Gameboy Done
      Gameboy Advance Done
      Image Viewer N/A
      Lutro missing
      Lynx Done
      Mame missing
      Master System Done
      Megadrive Done
      Moonlight missing
      MS X 1-2-2+ missing
      MSX1 missing
      MSX2+ missing
      Neo Geo Done
      Neo Geo Pocket B&W Done
      Neo Geo Pocket Color Done
      Nintendo Done
      Nintendo 64 Done
      Odyssey 2 missing
      PC Engine Done
      PC Engine CD Done
      Playstation Done
      PR Boom missing
      Scumm VM missing
      Sega 32 X Done
      Sega CD Done
      Sega SG 1000 Done
      Super Nintendo Done
      Supergrafx Done
      Vectrex missing
      Virtual Boy Done
      Wonderswan B&W missing
      Wonderswan Color missing
      ZX Spectrum missing
      ZX81 missing
      Amiga 1200 missing
      Amiga 600 missing
      Apple II missing
      Colecovision missing
      Commodor 64 missing
      Dreamcast Done
      Gamecube missing
      Playstation portable Done
      Wii missing
      The theme is available here
      install it in /recalbox/share/system/.emulationstation/themes/
      (sorry for the long post 🙂 )
      EDIT:
      I forgot to say: you are also welcome to create new layouts and colorsets!!! you can easily create new ones starting from an existing one (new colorsets especially would be nice)
      1 Reply Last reply Reply Quote 5
      • DjLeChuck
        DjLeChuck last edited by
        That's a lonnnng description 😮
        Good job. Really nice customizations possibilities!
        supernature2k 1 Reply Last reply Reply Quote 0
        • supernature2k
          supernature2k @DjLeChuck last edited by
          @DjLeChuck thx 🙂
          lot of explanations to give so yeah... pretty long post 😛
          kiki 1 Reply Last reply Reply Quote 0
            rockaddicted last edited by rockaddicted
            Good work dude 😉
            • poumtaq
              poumtaq last edited by
              Hi, thanks for this new theme !
              Could you add a "download" option to your git repo ?
              Bartop
              -RPI3
              -RB stable sur SD SanDisk MicroSDHC32 Go
              -Dual-Controller Xin-Mo
              -Stockage externe Clé USB 3.0 Sandisk Ultra Fit 128 Go
              -écran VGA + adaptateur HDMI
              -OS pc : LinuxMint 17
              DjLeChuck supernature2k 2 Replies Last reply Reply Quote 0
              • DjLeChuck
                DjLeChuck @poumtaq last edited by
                @poumtaq There is an option: https://github.com/recalbox/recalbox-themes/archive/master.zip But it downloads ALL the repo.
                poumtaq 1 Reply Last reply Reply Quote 0
                • supernature2k
                  supernature2k @poumtaq last edited by
                  @poumtaq unfortunately I can't 😕
                  @rockaddicted would it be possible to make a release like Eudora & simplelight?
                  • poumtaq
                    poumtaq @DjLeChuck last edited by
                    @DjLeChuck yep nickel merci, pas grave je prends tout et ferai le tri !
                    Bartop
                    -RPI3
                      rockaddicted @supernature2k last edited by
                      @supernature2k of course.
                      • azvarel
                        azvarel last edited by
                        Nice job @supernature2k you have made many possibilities =D
                        alt text
                        Zodian Theme | #SNESProject
                        • supernature2k
                          dowload link updated, thx to @rockaddicted
                          • idarius
                            idarius last edited by
                            Alors testé en 480i sur CRT :
                            Big Picture :
                            alt text
                            Big Picture Blue :
                            alt text
                            Standard - Landscape :
                            alt text
                            NoDesc :
                            alt text
                            Supernature2K :
                            alt text
                            Controls :
                            alt text
                            Je testerai en 240p pour que t'es une idée 🙂
                            Mais en tout cas c'est parfait, le decalage que l'on voit c'est l'overscan de mon écran qui est réglé pour la résolution 240p en jeu. (EmulationStation tourne en 480i)
                            • cotedeporc
                              cotedeporc last edited by
                              Beau boulot!
                              Thème FoolScreen / Squared
                              • lackyluuk
                                @supernature2k I use your new theme with my 7" display: https://www.adafruit.com/products/2300 (1024x600)
                                aaaand it works great 🙂 I have tested:
                                • no description layout / white & black colorset:
                                • supernature2k layout / white & black colorset
                                  This is not very suitable for small screens like this. Too many information on the screen.
                                • big picture layout / white & black colorset
                                  This is my absolute favourite layout for this size of screens. Only as much information as needed. Big pictures. This gives a nice overview 🙂
                                Thanks for your work 🙂
                                supernature2k Substring 2 Replies Last reply Reply Quote 0
                                • supernature2k
                                  supernature2k @lackyluuk last edited by
                                  @lackyluuk thx very much for the feedback!
                                  what about system info? is it readable?
                                  • lackyluuk
                                    @supernature2k It is readable although it is a small font size. What about using the whole space below the system logo instead of having all the information in the middle at small font size?
                                    Is it maybe also possible to increase the game names a little bit in the detailed view? Currently we see 17 games on one page. On small screens the number could be decreased to 10 - 14 or something like this?
                                    • supernature2k
                                      @lackyluuk
                                      thx very much!
                                      For the system info, I just let it as it is in recalbox theme. Let's see what @reivax and @Global-Moderators think
                                      For number of items in gamelist there is no other solution than creating a specific layout for small screens
                                        /me thinks there is soooooo much space unsused. But i really do not care that much about the visual part of the project 😉 Except this multi idea is awesome !
                                          Substring @lackyluuk last edited by
                                          @lackyluuk the problem with big scraped images is the resolution ... I think we fixed it at 350^x wide, something like that. So strzetching it on a 1080p screen can be ... errr .. ugly 😄
                                            rockaddicted @Substring last edited by
                                            @Substring everyone can choose the scrape size by editing es_settings.cfg file (why not export this setting in ES in the futur)
