    [4.1-Unstable] Bug reports
    4.1 bugs
    46
    349
    420085
    • kelv
      kelv last edited by
      Hello Everybody. I burned a new image a week and a half ago using the root file and the boot files in RP3 and unstable 4.1. My question is: before with previous untable builds every 2 days there were an update available however so far I didn't received any new updates. Is it expected? THX
      Raspberry Pi model: RPi 3b+
      Recalbox build : 7.0.1 DragonBlaze
      Hardware: MicroSD UHS 128 GB up to 80 MB, Class 10 and 2.5 A Power Supply.
      Overclocked: 1485 MHZ
      Controller(s): Wired Xbox 360 PAD (working perfectly on any other game/emulator).
        Substring @kelv last edited by
        @kelv are we allowed to spend our free time on something​ else than recalbox ?
        • kelv
          kelv last edited by
          @Substring jeje, so I guess is expected. I don't as at the beginning every two days we have updates. I wanted only to check 🙂 . Pls, No hard feelings 🙂
          • lackyluuk
            @substring not sure if this is 4.1 related: I have added two psx roms (.bin extension, it worked before updating to 4.1) but the system does not show up in ES. I updated the gamelist, did a reboot etc. I cannot even access the psx folder from the Web Manager (it is loading 100 of years and nothing happens). Any idea about this?
              paradadf Staff @lackyluuk last edited by
              @lackyluuk bin extension for psx games have been deleted from recognized ones. You need to launch ghe game with its cue file. You can easily create them if you miss them. Google for tutorials 😉
              https://forum.recalbox.com/topic/4501/remove-bin-extention-for-psx
              • lackyluuk
                @paradadf doh'..I should habe known this -.- thanks mate.
                Maybe the _readme can be updated accordingly.
                  @lackyluuk it has 😛
                  https://github.com/recalbox/recalbox-buildroot/pull/669/commits/c84ed0a2a44e12920ed1a47623d167e3f2f3341a
                  • lackyluuk
                    @paradadf lol, forget everything I said today
                    • toniosj
                      toniosj Spanish moderator last edited by
                      With the last version of 4.1, my roms patched of SNES dont working now. I have a rom patched of Zelda Link to the Past (spanish traduction), that it was working very well in recalbox 4.0.
                      Whats happening?
                      • qwesup
                        qwesup last edited by qwesup
                        Regarding the issue with the retroarch squares for HUD messages, I have removed ~/configs/retroarch/retroarchcustom.cfg , yet the problem continues. What is the value that changed in this file so I can add it manually?
                        I am on the 3/5 build of 4.1 unstable, which was upgraded from 4.0.2.
                        EDIT:
                        Was able to figure this out by comparing to a fresh build. In the retroarchcustom.cfg file, change :
                        video_font_path = ""
                        to:
                        video_font_path = /recalbox/share_init/system/.emulationstation/themes/recalbox/data/ubuntu_condensed.ttf
                          Substring @qwesup last edited by
                          @qwesup dunno if you updated to the latest unstable, but i think this was solved and available for users. I added an automatc umdate of this parameter when updating
                            Substring @toniosj last edited by
                            @toniosj cores have been updated, but i doubt such a feature was lost. I guess you're talking about an ips patch ?
                            toniosj 2 Replies Last reply Reply Quote 0
                            • toniosj
                              toniosj Spanish moderator @Substring last edited by
                              @Substring Yes, IPS patch.
                              • Raphael Bueno Hatencia
                                Raphael Bueno Hatencia last edited by
                                Not sure if is a bug, but no matter what slot you are saving when using save state, the text always show that you saved on slot 0, even when you are on slot 1,2, or 3 or soo on.
                                But everything saved correctly, just display incorrect.
                                • toniosj
                                  @Substring said in [4.1-Unstable] Bug reports:
                                  Have you try if the problem exists?
                                  • jsianes
                                    jsianes last edited by
                                    This afternoon I detected an issue using unstable 4.1 version. The message when writing and reading save-states always said the slot was #0 despite the slot you are really using. The save/load state seems to work correctly it seems an issue with the displayed message when reading/writing. I noticed playing Final Fight CD from MegaCD, but I think the issue is reproducible using any libretro core. Please, take a look.
                                      Substring @jsianes last edited by
                                      @jsianes that's a retroarch bug, would probably require a b*mp of retroarch. No idea if this will happen in 4.1
                                        I managed to get wifi working again. No recalbox problem, it was my SSID hidden. Recalbox can't connect to hidden wifi? That would be nice.
                                        • Edvis
                                          Edvis last edited by
                                          Hello, when using the hotkey, the bottom of the screen shows no letters, but squares, how to fix it? So it became after the system update v.4.1
                                          jsianes Substring azvarel 3 Replies Last reply Reply Quote 0
                                          • jsianes
                                            jsianes @Edvis last edited by
                                            @Эдвис-Фатходинов make sure you are using the latest unstable version. That happened to me first time I moved from 4.0 stable to unstable. Right after the first update, it came another a couple of days after that fixed that issue.
                                            Edvis 2 Replies Last reply Reply Quote 0
