    keybinding
    GamePad/GPIO/USB encoder
    keybinding
    3741
    • Xenoxia
      Xenoxia last edited by
      hey guys
      sorry for my bad english.
      I would like to delete and reset hotkeys. I can not find a suitable guide.
      Buffalo Classic USB Gamepad this controller I used.
        paradadf Staff last edited by
        Just reconfigure your pad accordingly and the HK will be reset.
        • Xenoxia
          and how?
          I do not find the corresponding file in the system
          \RECALBOX\share\system\configs\retroarch\inputs\DEFAULT
            Substring @Xenoxia last edited by
            @Xenoxia reconfigure your pad in ES, you don't have to edit any config file
            • Xenoxia
              Could you tell me how this works?
              I know how to change the hotkey but not the key binding
              • Xenoxia
                Does not anyone have an idea?
                  On EmulationStation, just enter the menu and configure your map (again). What do you not understand?
                  • lackyluuk
                    @Xenoxia do you want to change the Hotkey combinations or your controller mapping?
                    Xenoxia 1 Reply Last reply Reply Quote 0
                    • Xenoxia
                      Xenoxia @lackyluuk last edited by
                      @lackyluuk correct. But I find there no explanation for.
                      Hotkey + Y → Save State
                      Hotkey + X → Load State
                      Hotkey + Up → Select Save Slot -1
                      Hotkey + Down → Select Save Slot +1
                      etc.
                      this is the normal comb. i want all delet. the only this i need is:
                      Hotkey + Start → Retroarch Menu
                      • Xenoxia
                        Seems to be impossible. -.-
