    KlassiKo Theme (WiP)
    Themes & Interface
    klassiko theme wip
    12
    38
    24257
    • RetroWilly
      RetroWilly last edited by RetroWilly
      Hi all,
      After my last theme "Blisslight" i wanted to start over and took some other ideas.
      At this moment it is work in progress tho, but i got far today already.
      *New Music added
      *Background overhaul
      *Systems added
      Downloadlink: Not yet available!
      This is as far i got today.
      alt text
      alt text
      alt text
      alt text
      alt text
      alt text
      alt text
      alt text
      alt text
      alt text
      alt text
      Update:
      We're getting somewhere 🙂
      alt text
      alt text
      alt text
      alt text
      Update 4-2
      Nearly there..
      alt text
      alt text
      Not sure about the Genesis yet.
      alt text
      alt text
      What is this little guy doing here?
      alt text
      Hello :)
      voljega 1 Reply Last reply Reply Quote 4
        voljega Banned @RetroWilly last edited by
        @RetroWilly very nice one !
        • makination
          makination last edited by
          Love it! Waiting for final version!
          • lackyluuk
            @RetroWilly Great! I really love the controller images. Where do you have theses from?
            You could use in every screen another perspective of the controller 🙂
            RetroWilly 1 Reply Last reply Reply Quote 0
            • RetroWilly
              RetroWilly @lackyluuk last edited by
              @lackyluuk Thanks, found them through multiple sources on the web. Pretty hard to find some decent images for some systems tho.
              Hello :)
              • lackyluuk
                @RetroWilly there is a guy from retropie forum which creates pictures like this. Maybe it would be an idea to contact him regarding the usage of his images? 🙂
                https://retropie.org.uk/forum/topic/720/background-images-coming-back
                RetroWilly 1 Reply Last reply Reply Quote 1
                • RetroWilly
                  RetroWilly @lackyluuk last edited by RetroWilly
                  @lackyluuk Wow, thanks for that info! Contacted him, he sure has some awesome work i could use!
                  Hello :)
                    paradadf Staff last edited by
                    There is no need to contact him to ask for permission (you are not selling anything). Just don't forget to give him the credits.
                    Tronkyfran has made his work available on GitHub:
                    https://github.com/tronkyfran/tronkyfran-3d-models
                    And this is the retropie theme based on tronkyfran's 3d models:
                    https://github.com/HerbFargus/es-theme-tronkyfran
                    • lackyluuk
                      @paradadf oh, did not see that it is on github 🙂 thanks for the information
                        Hi, nice theme 😃
                        Just an information about ES and his ram management.
                        If you are using full HD background, 1920x1080, be careful.
                        ES loads each background, in raw on his vram. So we are very limited by number of systems that can be activated in the same time in ES.
                        I don't have anymore exact max number in my mind, but it is something like that :
                        • 1080p : about 10
                        • 720p : about 20
                        • 480p : about 40/45
                        Once vram filled, you'll have a WSOD (White Screen Of Death) in ES.
                        That is why the old used theme in recalbox, simplelight, was reworked with 480p backgrounds, and we used some elements tiled and light svg in the new one, recalbox.
                        So until, a cache buffering be implemented in ES, be careful with your background resolution.
                        • RetroWilly
                          RetroWilly @rockaddicted last edited by
                          @rockaddicted @paradadf, Thanks for the info!
                          Hello :)
                          • screech
                            screech last edited by
                            Like I said in a Retropie Post, try to convert your background as png, and compress them with pngquant or optipng... You can have surprise about the size it will be 😉
                            (and maybe solve some WSOD problem 😉 )
                              @screech Nope, ES loads files in raw, so the "size" of your file don't have impact. Only resolution (1920x1080, etc...) have one.
                              • screech
                                seriously ><
                                so a 100Ko png File in 1920x1080 will be as huge as a 10Mo BMP File in memory ?
                                What the hell with you EmulationStation, are you crazy ? ^^
                                • RetroWilly
                                  Post updated, now i'm finally going to do some retrogaming this week 🙂
                                  Hello :)
                                  • maximus37
                                    maximus37 last edited by
                                    @RetroWilly Great work on this "system" theme, real nice 😄 Keep up the good work!
                                    • lackyluuk
                                      @RetroWilly Looks great! I am excited for the final theme. Can you provide the system list which you support in your theme? 🙂
                                      • RetroWilly
                                        @lackyluuk I'm working on all systems currently supported by RecalBox, also 4.1 ready 🙂
                                        Hello :)
                                        • RetroWilly
                                          Post updated 🙂
                                          Hello :)
                                          • lackyluuk
                                            @RetroWilly Do you use other pictures for the gamelists or the same?
                                            What about the gameboy classic picture for gameboy? 🙂 That would br nicr
