    Solved No Sound throught HDMI
    sound throught hdmi
    14394
    • levendis32
      levendis32 Translator Banned last edited by
      At first there was sound but after a restart I have done sound completely gone.
      Yes I have change output from AUTO to HDMI but didnt work and volume is at 100.
      Any thoughts so we can make this problem SOLVED?
        Substring @levendis32 last edited by
        @levendis32 maybe you just turned it off ?
        What recalbox cersion do you have ? What board ?
          paradadf Staff last edited by
          I'd let it on AUTO. I've met some users which had audio issues because they specified HDMI. Maybe important... which controller you have? Ps4 pads have an integrated sound card which blocks HDMI audio.
          levendis32 1 Reply Last reply Reply Quote 1
          • levendis32
            SOLVED ...PS4 Controller conficts with sound from HDMI.So the only thing you have to do is to unplug the controller and restart Raspberry.
            • levendis32
              levendis32 Translator Banned @paradadf last edited by
              @paradadf you are so right bro. Thanx
              • ian57
                ian57 Staff last edited by
                @levendis32 @paradadf The best way is to blacklist the usb sound module see https://forum.recalbox.com/topic/5423/no-sound-recalbox-with-new-ps4-controller/5
                  I'd need a guinea pig to test forced sound devices order. Just need to pass 4 commands then reboot 🙂
                  • levendis32
                    levendis32 Translator Banned @ian57 last edited by
                    @ian57 kindly thank you for the reply but i dont know how to
                    mount -o remount, rw / , vi /etc/modprobe.d/blacklist.conf ,
                    add blacklist snd-usb-audio ,  reboot .
                    Where can I do all this ? : /
                    • ian57
                      @levendis32 you need to make this through SSH or on the console after quitting EmulationStation with the F4 key. See https://github.com/recalbox/recalbox-os/wiki/Root-access-on-terminal-(EN) to know how to do this. After that just make the command :
                      to be able to modify the file in the ReadOnly filesystem
                      nano /etc/modprobe.d/blacklist.conf
                      to edit the right file
                      add the following line in the file :
                      save and reboot. That's all
                        Substring @ian57 last edited by
                        @ian57 could you try forcing bcm2835 as index=0 rather than modifying snd-usb ?
                        • ian57
                          @Substring I made that last friday... you did not see my results? Works like a charm 😉
                          juste put :
                          options snd slots=snd_bcm2835
                          in /etc/modprobe.d/alsa.conf, reboot and the first audio device will always be the one from the Raspberry Pi 🙂
                          Substring 1 Reply Last reply Reply Quote 1
                            @ian57 i love it. I remember index=-2 for snd-usb, but that is great news. Should make it by default in recalbox
