    Video switching rca to hdmi and hdmi to rca
    switching rca hdmi
    3721
    • Nokiandrea
      Nokiandrea last edited by
      Hi, i had connected rca and hdmi cables...can i switch video output with a simple switch button?
        voljega Banned @Nokiandrea last edited by
        @Nokiandrea I don't think so
        • ian57
          ian57 Staff last edited by
          @Nokiandrea If your switch button is linked to a script which is modifiing the config.txt file, and reboot the pi... perhaps... I know one guy which did this to rotate the screen ;).
          Need to see if it is possible with the latest firmware.. because we can switch resolution on the fly now!
            Substring @Nokiandrea last edited by
            @Nokiandrea Yesterday i stumbled upon a very interesting article on the Pi documentation, and there may be a light at the end of the tunnel ... But it requires some tweaking.
            The concept is : add a detail saying "if my TV is plugged, then set this hdmi mode" , see the The [EDID=*] filter chapter in https://www.raspberrypi.org/documentation/configuration/config-txt.md
            • ian57
              @Nokiandrea @Substring "When switching between multiple monitors while using a single SD card in your Pi, and where a blank config isn't sufficient to automatically select the desired resolution for each one, this allows specific settings to be chosen based on the monitors' EDID names." very interesting. 2 EDID configs, and a simple reboot to get the right output because " Hotplugging a different monitor after boot will not reselect different settings."
                voljega Banned @ian57 last edited by
                @ian57 cool for portable devices which could in the future also be connected on tv
                • ian57
                  the congrats must be to Substring... not me ;)... but yes it is cool for portable device 🙂
