    how to disable the screenshot feature
    disable screenshot feature
    7334
    • mc9625
      mc9625 last edited by
      I would like to disable the screenshot keys combo, and also remove the screenshot menu item. How can I do that?
      Thanks
        Depends on the emulator. But I think it's a retroarch feature that can't be changed. Maybe there is a config option to disable it
          paradadf Staff last edited by paradadf
          Delete the screenshots and the menu will not appear anymore. Press Select on one screenshot, edit and delete.
          As far as I know, you can't easily disable just one combo.
          @Substring you were faster 😉
            Substring @paradadf last edited by
            @paradadf but I answered half of the question 😮
            • mc9625
              I see. Actually I think that I took all that screenshot by mistake, pressing some weird key combo. Probably the only way could be to remap this combo to other keys in order to make it "impossible" to make it by mistake (for instance by pressing the UP and DOWN on the stick, or something like this). Unfortunately it's not very easy to find documentation on such feature.
              Thanks for your advice, I will keep looking.
                The screenshots are taken by pressing HK+L1... it is very unlikely that you press that by mistake.
                mc9625 1 Reply Last reply Reply Quote 0
                • mc9625
                  mc9625 @paradadf last edited by
                  @paradadf HK means?
                    paradadf Staff @mc9625 last edited by
                    @mc9625 please, read the wiki.
                    https://github.com/recalbox/recalbox-os/wiki/Manual-(EN)#duringgame-special
