    Solved Can't Connect
    cant connect
    11
    47
    26642
    • DannyOcean
      DannyOcean @Substring last edited by DannyOcean
      @Substring always easy 🙂
      Also wanted to say a big THANK YOU to you and your colleagues. Coders, forum admins, translators etc... 🙂
      • DannyOcean
        DannyOcean last edited by
        blog.recalbox.com also not working.
        forum.recalbox.com is fine ... strange
          the blog is dead for months already
          • DannyOcean
            @digitaLumberjack @Substring
            Sorry for double post, but I wanted to let you know that there might be an easy solution to fix the "no connection" problem.
            If your host (gandi.net ?) supports .htaccess there might be an easy solution.
            In ISPconfig the domain has to be "RECALBOX.COM" (without www) and auto-subdomain has to be "www"
            The A records in the DNS setting:
            IP for www.recalbox.com is 163.172.153.70
            IP for recalbox.com is 217.70.184.38
            That is why the update is not working and the recalbox shows "not connected"
            To fix the problem the IP for recalbox.com and www.recalbox.com just have to be the same.
            Check the DNS settings and see the A record for yourself.
            The hoster (gandi.net ?) should be able to fix it.
            You also have to add the following code to your root .htaccess file:
            This redirects all non-www requests to your site to the www version
            RewriteEngine on
            RewriteCond %{HTTP_HOST} !^www.
            RewriteRule ^(.*)$ http://www.%{HTTP_HOST}/$1 [R=301,L]
            The second line means: if the HTTP_HOST does not (!) start with (^) "www.", then put it in memory for the next line. The next line says: from what was captured in the previous line, match everything (.*) from beginning (^) to end ($) and save everything (inside the parenthesis) as $1. Then replace $1 with ""; plus the HTTP_HOST variable.
            And this would redirect all www requests to your site to the non-www version
            RewriteEngine On
            RewriteCond %{HTTP_HOST} !^my-domain.com$ [NC]
            RewriteRule ^(.*)$ http://my-domain.com/$1 [R=301,L]
            I really hope this helps, and everyone will be able to update 🙂
            Cheers
            fegemo 1 Reply Last reply Reply Quote 1
            • fegemo
              fegemo @DannyOcean last edited by
              I am having the exact same issue - emulationstation does not recognize it's connected because the ping to recalbox.com fails. But kodi works fine.
              Any updates on this?
              Thanks!!!
              mazur 1 Reply Last reply Reply Quote 0
              • mazur
                mazur @fegemo last edited by
                @fegemo Not yet.. Waiting for 4.1 version..
                • Mischler81
                  Mischler81 last edited by
                  Ping to recalbox.com does work for me now.
                  • fegemo
                    fegemo last edited by fegemo
                    Hey guys. I did one test here. It is somehow related to my ISP. Whenever I try to reach (ping, traceroute) recalbox.com from my home Internet connection (picture 1), the packets all get lost. But if I try to reach the same address using my 4G connection (picture 2), it works just fine.
                    Do you guys have any idea on the cause of this strange ISP-specific behavior?
                    Picture 1 (using my home connection):
                    Picture 2 (using my 4G connection):
                    • mazur
                      @fegemo I think is really some ISP problem.. because i use GVT/VIVO too.. and i get no connection, but i can connect with 4G like you.
                      I tried today with last RecalBox (Unstable 4.1.0 build 63), same problem again..
                        Substring @mazur last edited by
                        @mazur as we said : dns problem. @digitaLumberjack seems not t have taken care of it yet
                          SOLUTION UNTIL IT IS FIXED UPSTREAM :
                          edit ~/.emulationstation/es_settings.cfg and replace <string name="UpdateServer" value="recalbox.com" /> with <string name="UpdateServer" value="archive.recalbox.com" />
                          rapid fegemo Ares2502 3 Replies Last reply Reply Quote 0
                          • rapid
                            rapid @Substring last edited by
                            @Substring THX to Substring this Solution worked for me 🙂
                              Substring @rapid last edited by
                              @rapid to be honnest, it worked fror me too while i was testing a fiw in EmulationStation and it didn't work lol
                              • mazur
                                mazur @Substring last edited by
                                @Substring For me worked just fine too!
                                • fegemo
                                  fegemo @Substring last edited by
                                  @Substring thanks for the solution. I did something similar, which was to add an entry to the hosts file to make "recalbox.com" point to the IP of www.recalbox.com. To be able to do that, I had to remount the file system as writable. The commands were:
                                  1. ssh root@192.168.X.X and then type the default password for the root user (described in the wiki)
                                  2. mount -o remount,rw /
                                  3. echo "163.172.165.227 recalbox.com" >> /etc/hosts
                                    Substring @fegemo last edited by
                                    @fegemo this is much more complicated and would blow up on update. But glad it worked for you 🙂
                                    • Ares2502
                                      Ares2502 @Substring last edited by
                                      @Substring Did not work for me. 😞 Connection status still shows "not connected" although the Box is cabled and assigned an IP adress.
                                        Substring @Ares2502 last edited by
                                        @Ares2502 can you paste your es_settings.cfg on pastebin please ?
                                        • rapid
                                          rapid last edited by rapid
                                          For all of you who have your games on an USB device or hdd. Then you need to change the settings on /media/usb0/recalbox/system/.emulationstation/es_settings.cfg.
                                          usb0 depends on your system. could also be usb1 ect. just try it out which one fits for you
                                          So for people who have their games on an USB / hdd device try edit
                                          /media/usbXY/recalbox/system/.emulationstation/es_settings.cfg and replace
                                          edit: looks like this not really works. after reboot the es_settings.cfg is back to default for me.
                                            For people who are uneasy at editing the file, juste paste this in SSH : /etc/init.d/S31emulationstation stop && sed -i "s+recalbox\.com+archive\.recalbox\.com+g" ~/.emulationstation/es_settings.cfg && /etc/init.d/S31emulationstation start
                                            Ares2502 1 Reply Last reply Reply Quote 0
                                            100.2k
