    Solved Can't Connect
    cant connect
    11
    47
    26648
    • Ares2502
      Ares2502 @Substring last edited by
      @Substring said in Can't Connect:
      /etc/init.d/S31emulationstation stop && sed -i "s+recalbox.com+archive.recalbox.com+g" ~/.emulationstation/es_settings.cfg && /etc/init.d/S31emulationstation start
      Thanks for your help! this actually worked. After editing the cfg with vi it was changed back to default after a reboot. Your comand line parameter actually worked!
        Substring @Ares2502 last edited by Substring
        @Ares2502 That's because ES rewrites the values, so we need to shut it down before modifying the file 🙂
        Ares2502 xtreemsurf 2 Replies Last reply Reply Quote 0
        • Ares2502
          @Substring Thanks again! Makes perfectly sense, when explained this way!
          • xtreemsurf
            xtreemsurf @Substring last edited by
            How do you shut it down before modifying this file from the "share" folder...connecting from a PC? Thanks for your help on this...
              Substring @xtreemsurf last edited by
              @xtreemsurf just run my big command
              • digitaLumberjack
                It should be ok now.
                xtreemsurf 1 Reply Last reply Reply Quote 0
                • xtreemsurf
                  xtreemsurf @digitaLumberjack last edited by
                  @digitaLumberjack
                  It's working now...thanks so much!
                  100.2k
