    Does Recalbox work with the 7" Raspi Screen ?
    does recalbox raspi
    3765
    • Fudoh
      Fudoh last edited by
      without any config chages ?
      And if so, is it possible to switch between the HDMI output and the 7" screen ? Which output has priority when booting Recalbox ?
      Thanks!
      • ian57
        ian57 Staff last edited by
        No you can't. The 7" screen (as the 5") needs specifc configuration in config.txt file since it does not embed a scaler chip. You need to fix the resolution in the config.txt file to make it work.
        So if you do that, you will have the same resolution on your TV screen.
          the official 7" screen works ... there is even a video from digi showing it
          • ian57
            official does not need resolution configuration? so it embeds a scaler chip 😉
              Substring @ian57 last edited by
              @ian57 no idea. I just said it works, no idea about configuration details. But you probably need to edit the config.txt and recalbox.conf to set to the native resolution of the screen
              • ian57
                @Substring ... anyway ... it is too expensive ;)... for me
                  @ian57 well it's just half the prize of a second hand PS3 + a few games 🙂
                  • Fudoh
                    Thanks guys! I'll give it a try. Just ordered the screen and we'll see what's neccessary in terms of config adjustments.
                    • DxPepper
                      DxPepper last edited by
                      and? does it works?
