    [SOFT] Universal XML Scraper V2
    Community projects
    [soft] universal xml scraper
    112
    670
    922729
    • screech
      screech last edited by
      Not sure it will work over NFS...
      Can you connect to the share folder on the IP from the PC (with windows explorer) ?
      normally it work well with Samba... but NFS... I can't help you so much 😞
      the main Idea : If windows can navigate to the rom folder normally UXS can... (it use the windows functionnality)...
      NFS have right strategy... Check if yours are ok too...
      • kakoumars
        kakoumars last edited by
        salut a tous et merci pour ce merveilleux logiciel =D
        si j'ai bien compris j'ai le même soucis que @n1md4 =/
        j’utilisais la version antérieur et aucun soucis pour elle (j'ai retesté) (je vais pour le moment rester sur cette version)
        mais lorsque je veux utiliser la nouvelle version jai un message d'erreur
        (le chemin des ROMs n'est pas accessible)
        une idée ?
        • n1md4
          n1md4 last edited by
          @screech I can connect to the Recalbox via Windows 10 explorer. I might try Samba later, if nothing else will work, if only to test.
          I have produced this log file here http://pastebin.com/raw/8LA2z6hq let me know if you see anything useful.
          Maybe @kakoumars has a good point there? Do you have a networked ROM directory too? If so by which service?
          Wish I'd paid attention in school to French lessons!
          • cotedeporc
            cotedeporc last edited by
            screech
            Bon, je n'ai pas réussi à incruster les images de genre.
            J'ai ajouter cet Element en vain:
            <Element>
            <Name>GameGenreTEMP</Name>
            <Source_Type>XML_Value</Source_Type>
            <source_Origin>Genre</source_Origin>
            <Source_Value>Data/genres/genre[id=%IDGENRE%]/medias/media_pictomonochrome</Source_Value>
            <Target_Width>104</Target_Width>
            <Target_Height>104</Target_Height>
            <Target_TopLeftX>%0.024</Target_TopLeftX>
            <Target_TopLeftY>%0.709</Target_TopLeftY>
            </Element>
            Faut ajouter quelque chose dans la balise Root? Ou autre part?
            Merci!
            Thème FoolScreen / Squared
            • kakoumars
              j'ai trouver plusieurs chose 😃 qui pourrons certainement aider @n1md4 😃
              je fait plusieurs test et appartement le problème vient de la configuration lors de l'auto conf javais choisis V4 mix Scummvm (marche pas) en testent juste sur v4 Mix tout remarche =D
              plus de bug de chemin 😃 je pense pas que se soit normal mais le soucis venez de la ^^ voila voila
              @n1md4 Click "launch wizard" then choose V4 mix during your configuration 😃
              • kakoumars
                Autre question qui me tarabuste 😃 est t'il possible que "XML Scraper" ne fasse uniquement les jeux qui n'ont Pas etait scraper ? au lieu de tout refaire a chaque fois que je scrape un dossier (il m’enlève même les scrape qu'il ne trouve pas et que j'avais fait manuellement sur recalbox)
                • n1md4
                  n1md4 last edited by n1md4
                  Yes! I figured that out too when I finally got ScummVM working 😄 Thank you!
                  I then scrapped 600 more ROMs and it took around 2 hours to complete, does that time sound right, and why does it take so long? --or should that be considered quick? 🙂
                  • yrojoue
                    yrojoue last edited by
                    Merci pour l'ajout rapide de la fonction rotation des images, du coup je vient de scrapper mes jeux SNES et N64...
                    Par contre j'aurai bien aimé pourvoir fixer une image en définissant son centre (bien plus pratique pour pouvoir centrer les "wheels"). Est ce une fonction déjà présente? Car je n'ai pas trouvé comment faire.
                    • screech
                      @n1md4 2h for 600 Rom is pretty long... Have you a Screenscraper Account ? try this 😉 (and put your ID/Password in the general option)
                      @kakoumars Il te suffit d'aller dans les options générales et de mettre le mode de scrape sur "update". Il ne scrapera que les roms qui te manque...
                      @cotedeporc normalement, non, pour le genre il n'y a pas besoin d'indiquer le Root du Xpath (déjà présent dans Source_Value, c'est le Data/genres )
                      Par contre, il va falloir que je reteste... Vue que j'ai corrigé le système de fallback après avoir ajouté cette fonction, je l'ai peut être cassé ><
                      Je teste ça et corrige si besoin ce WE 😉 )
                      (Il faut aussi que je vois avec le boss de Screenscraper, pour ajouter les liens directement dans l'API plutôt que dans des listes "à part" ^^ ce sera beaucoup plus simple 😉 )
                      n1md4 1 Reply Last reply Reply Quote 0
                      • Takylmor
                        Takylmor last edited by Takylmor
                        @screech Désolé, tu va dire que je suis chiant, mais comme la version précédente, je n'arrive pas à installer celle ci.
                        Lorsque je lance le .exe (en tant qu'admin), ça mouline et rien ne se passe.
                        Exactement comme la dernière fois.
                        Bien sur cette fois j'ai désactivé tout antivirus et autres protections.
                        Alors c'est à rien n'y comprendre.
                        Puis-je faire une installe manuel ? (avec tout les fichiers nécessaire)
                        • screech
                          @Takylmor En fait, il n'y a pas d'install, juste de dépendance qui sont recréer au démarrage si besoin.
                          Après, souvent, quand ça plante au démarrage, c'est qu'UXS n'arrive pas à se connecter au server (si tu attends un peu, t'as un message Timeout)
                          Et on a eu un petit problème ce matin avec la BDD de log qui pompé trop de ressource.
                          Normalement c'est réglé 😉 réessaie 😉
                          • johnDoe_1
                            johnDoe_1 Banned last edited by
                            @screech
                            Salut, pas mal l'update avec les mix de @cotedeporc ! (joli boulot !)
                            Il y aurait moyen d'avoir plus de mix dans ce même thème pour les autres consoles mais sans la partie vide de gauche (si on ne souhaite pas utiliser le thème qui va avec le mix) s'il vous plait ?
                            @cotedeporc ça rend vraiment classe avec tes mix, j'approuve !
                            • n1md4
                              @screech Is it possible to have just the game box image?
                              • Takylmor
                                Ça ne fonctionne toujours pas.
                                je vais rester à l'ancienne, car là ça saoule de redémarrer mon pc à chaque test, pur avoir la même finalité.
                                Mais le truc, c'est qu'avec l'ancienne version, quand ça a fini par ce lancer, elle à creer plusieurs fichiers, et maintenant elle fonctionne parfaitement.
                                C'est pour ça que je demandais si y avait moyen de sauter la création de fichier, et les mettre manuellement, est ce que le logiciel se lancera ?
                                Weedfried 1 Reply Last reply Reply Quote 0
                                • kakoumars
                                  @screech merci pour l'info ^^ et pour ce super logiciel =D
                                  • Weedfried
                                    Weedfried @Takylmor last edited by
                                    @Takylmor si ça peux te rassurer tu n'es pas un cas isolé. J'éprouve moi aussi des difficultés à scraper depuis hier. Mais ça marchait bien avant, je vais donc attendre patiemment que tout rentre dans l'ordre.
                                    @screech Bon boulot en tous cas. Jusqu'à présent je scrapais en ssh, mais récemment les résultats de Neo Geo n'étaient plus les même (captures d'écran au lieu de visuels des jaquettes auxquels on m'avait habitué). Pour les autres systèmes rien n'a changé, ça ne concerne que FBA Libretro et Neo Geo. Je vais donc attendre que ton soft soit de nouveau sur pieds.
                                    Ramstatlon 1 Reply Last reply Reply Quote 0
                                    • Takylmor
                                      @Weedfried C'est même pas le fait de scraper qui bloque, c'est l'installation du soft qui plante.
                                      Mais je me doute que je ne suis pas le seul dans ce cas, par contre je suis le seul à venir embêter @screech 😉
                                      • n1md4
                                        n1md4 @screech last edited by
                                        @screech said in [SOFT] Universal XML Scraper V2:
                                        @Screech Just waiting for my submissions to be validated ... 😆
                                        • n1md4
                                          Also, I'm having trouble scraping ScummVM games. I've set the correct <shortname>.scummvm in each folder, but UXS just seems to fail. Can you let me know the setup that works?
                                          Another thing, I've a bunch of SNES titles that are not found, but are present on ScreenScraper. What can I do to fix this?
                                            paradadf Staff @n1md4 last edited by
                                            @n1md4 for ScummVM creating an empty .scummvm file is not enough. You need to add the long name inside. Check this out:
                                            https://forum.recalbox.com/topic/3832/filelist-scrapping-scummvm/
                                            About your SNES roms see:
                                            https://forum.recalbox.com/topic/3842/how-to-screenscraper
                                            (Point 14 is relevant in your case)
