    [SOFT] Universal XML Scraper V2
    Community projects
    [soft] universal xml scraper
    112
    670
    922749
    • n1md4
      n1md4 @paradadf last edited by
      @paradadf
      for ScummVM creating an empty .scummvm file is not enough. You need to add the long name inside. Check this out:
      https://forum.recalbox.com/topic/3832/filelist-scrapping-scummvm/
      Yes, I've done that, sorry. Like this longname/shortname.scummvm I've used the built-in scraper, and it works - so that's something, but I would like it to work with UXS too, to give a uniform look.
      About your SNES roms see:
      https://forum.recalbox.com/topic/3842/how-to-screenscraper
      (Point 14 is relevant in your case)
      Ah ha, was going to ask what to do with all the "missing_rom" files I've created 😉
      Thanks!
      Wish I'd paid attention in school to French lessons!
        paradadf Staff @n1md4 last edited by paradadf
        @n1md4 read the link about ScummVM again. You didn't get what I wrote. The longname must be written in plain text inside the shortname.scummvm file. All those files can be downloaded from that link, so you don't need to bother.
        • n1md4
          Aaaaah! Thanks for your persistence 😉
          • n1md4
            Still not working, here is exactly what I've done:
            ScummVM setup:
            i) created a directory for each title
            ii) copy game data into each accordingly
            iii) create a file with the shortname and .scummvm extension
            iv) the content of each .scummvm file has the longname as content
            UXS setup:
            i) create a profile for Recalbox v4 ScummVM MIX
            ii) ensure SSH is set, and ROM paths are correct
            iii) choose 1 game or all to scrape
            Still this is failing, log creation has failed so can't read that either.
            Also, upon a successful scrape, where should there be gamelist.xml and download_pictures ?
              @n1md4 can you give me an example? Just to test, I'm scraping the whole batch of .scummvm files from the link I posted before and they are scraping perfectly. Isn't your game on that list? If so, you can compare its content with whatever you have been trying to use. If it isn't there... check the database to see if you game exist.
              The gamelist.xml and download_images folder will be inside your scummvm folder.
              • n1md4
                @paradadf
                cat /recalbox/share/roms/scummvm/Beneath\ a\ Steel\ Sky/sky.scummvm
                Beneath a Steel Sky
                cat /recalbox/share/roms/scummvm/Beneath\ a\ Steel\ Sky/_ScummVM_missing.txt
                Beneath a Steel Sky 12:26.00 2016-08-27
                  @n1md4 there is a bug with that profile. If you use the Recalboxv4(Mix), it will get scraped.
                  • Ramstatlon
                    Ramstatlon @Weedfried last edited by
                    @Weedfried said in [SOFT] Universal XML Scraper V2:
                    @Takylmor si ça peux te rassurer tu n'es pas un cas isolé. J'éprouve moi aussi des difficultés à scraper depuis hier. Mais ça marchait bien avant, je vais donc attendre patiemment que tout rentre dans l'ordre.
                    Tu as toujours ces meme problemes? Impossible de lancer UXML ce week end, la ca marche mais la plupart des img reviennent toutes noires avec la plupart des mix. Pas mieux sur le digimirror.
                    Ca marche mieux avec les mix plus simple comme le 2img
                    recalboxOS 4.0.0-beta6
                    Raspberry pi 3
                    manettes 8Bitdo SCF30 & NES30 Pro
                    Weedfried 1 Reply Last reply Reply Quote 0
                    • screech
                      screech last edited by
                      Hi, the new 2.1.0.5 just come out.
                      A lot's of change :
                      • Corrected :
                      ° Better stability on downloaded images (Some never download :S and miss in the MIX)
                      • Added :
                      ° Dynamique Handle to API server, now I can force the server to ask (for the futur when we have a fallback server 😉 or country based server )
                      ° Lot's of new Picto media (Nb of player, Notes, Classification, Editor, Developer, Genre) -> Beta it can change soon.
                      ° Added 3 news MIX Template for Bigshot Theme with these new picto (1 is directly on local, the 2 other are on the repository, you can download them directly from UXS)
                      • WARNING Added things that can "broke" you existing MIX Template
                      ° You need to put the full Xpath to the Source_Value node (exemple : Game need to start by 'Data/jeu/' and System by 'Data/systeme [id="%IDSYSTEM%"]')
                      ° The CENTER/LEFT/RIGHT/UP/DOWN function in Target_TopLeftX, Target_TopLeftY (and other) now take the "origin" point of the picture (default are TopLeft corner of the Picture)
                      ° You can now use Target_OriginPicX and Target_OriginPicY to fixe the origin point of the picture. So now to center a picture you need to put :
                      • <Target_TopLeftX>CENTER</Target_TopLeftX>
                      • <Target_OriginPicX>CENTER</Target_OriginPicX>
                      • <Target_TopLeftY>CENTER</Target_TopLeftY>
                      • <Target_OriginPicY>CENTER</Target_OriginPicY>
                      (The Origin point of the picture will be the center, and we center this origin point to the final picture)
                      This is exemple of the New MIX for BigShot Template :
                      text alternatif
                      text alternatif
                      text alternatif
                      • Weedfried
                        Weedfried @Ramstatlon last edited by
                        @Ramstatlon bonjour. J'ai du essayer vendredi dernier. Pas de soucis avec FBA Libretro, pas plus qu'avec la N64 mais toujours rien avec la GBA. Je testerais la mise a jour en fin de semaine.
                        • cotedeporc
                          cotedeporc last edited by
                          @screech
                          Est-il possible de modifier la couleur des logos?
                          Thème FoolScreen / Squared
                          • screech
                            c'est à dire ?
                            Le fond bleu ?
                            bien sur ^^ regarde dans le mix, tu as un fichier bluesquare.png 😉
                            Les picto sont monochrome sur fond transparent 😉
                            (bientot, quand on aura trouvé un graphiste ^^ on fera des picto couleurs ^^)
                            cotedeporc 1 Reply Last reply Reply Quote 0
                            • cotedeporc
                              cotedeporc @screech last edited by
                              Ce n'est pas le fond, mais plutôt ce qui est en noir.
                              Comment pourrais-je faire pour afficher le logo du développeur en blanc?
                              L'API ScreenScraper le permet-il?
                              • screech
                                En blanc non 😞 ce n'est pas possible...
                                Actuellement sont récupérable 2 types de logos :
                                Monochrome :
                                text alternatif
                                Couleur :
                                text alternatif
                                à voir si un jour j'ajoute une fonction de "matrice" pour modifier les couleurs à la volée ><
                                • azvarel
                                  azvarel last edited by
                                  @screech
                                  I would like to understand why UXS does not save the screenshots correctly in some roms, example image.
                                  alt text
                                  The name of the roms is identical to the screenscraper.fr, after many attempts the image of the game The Immortal appeared, but the others I could not
                                  My roms are named on no-intro.org which in turn are identical to the relation of screenscraper.fr
                                  Any solution?
                                  Zodian Theme | #SNESProject
                                  • screech
                                    Unfortunatly it's not a "rom" problem... It's a download problem we are trying to fix with the database Big Boss 😉
                                    We have some clue... And working on it 😉
                                    • azvarel
                                      Is there a possibility to choose mirror / server?
                                      • screech
                                        Not yet... And when it's become possible, it will be automatic...
                                        • stamstamstam
                                          stamstamstam last edited by
                                          Bonjour, est-ce que quelqu'un pourrait ajouter ces jeux dans la base de donnée?
                                          http://pastebin.com/ExHxEfWY
                                          Ce sont tous des jeux PS1.
                                          Merci d'avance.
                                          • yrojoue
                                            yrojoue last edited by
                                            @screech
                                            Je suis en train de créer les mix en lien avec mon thème mais je n'arrive pas à "télécharger" les photos systèmes, j'utilise la ligne de code suivante: Data/systeme/medias/media_photos/media_photo_%COUNTRY% (comme indiqué sur le wiki).
                                            J'ai cru comprendre qu'il y a des problèmes avec la base de screenscraper. Est ce que ceci explique cela?
                                            merci.
