    Solved Added megadrive roms, emulator doesn't show
    Emulator Arcade/PC/Console
    added megadrive roms doesnt show
    13407
    • CaffeineFiend
      CaffeineFiend last edited by
      I've added a megadrive romset, but the megadrive emulator doesn't show up ? What can I do?
      • cazeysan
        cazeysan last edited by
        You can read this post : https://forum.recalbox.com/topic/3907/rom-s-disappearing
        Viens par là, c'est pareil !
        CaffeineFiend 1 Reply Last reply Reply Quote 0
        • CaffeineFiend
          CaffeineFiend @cazeysan last edited by
          @cazeysan I read that now... I've already tried updating the game list, restarting and still recalbox does not recognize the .gen files.
          • CaffeineFiend
            I've now tried adding a new romset and I still have the same problem. beta5 does not recognize my roms / show the emulator. I have tried updating the game list and restarting.
            • cazeysan
              Can you try to only add 2 or 3 roms before the big romset ?
              • CaffeineFiend
                I've now also roms for the Sega Master System... It doesn't work.
                • cazeysan
                  Where did you add the megadrive roms ?
                  • CaffeineFiend
                    @cazeysan I've added the megadrive .gen files (other romset had .zip files) under root0/recalbox/share_init/roms/megadrive
                    I added the Sega Master System roms (.sms files) under root0/recalbox/share_init/roms/mastersystem next to the two prepackaged roms.
                    • CaffeineFiend
                      Could it have something to do with the filesystem being read only? I've had to open a file manager as root in order to transfer files from my computer to the SD card
                      • cazeysan
                        Linux OS ?
                        • cazeysan
                          Have you read this doc ? https://github.com/recalbox/recalbox-os/wiki/Manual-(EN)#network
                          • CaffeineFiend
                            @cazeysan Yes I'm currently running Ubuntu Mate
                              Path roms is /recalbox/share/roms/megadrive
                              Not share_int.
                              CaffeineFiend 1 Reply Last reply Reply Quote 1
                              • CaffeineFiend
                                CaffeineFiend @acris last edited by
                                @acris said in Added megadrive roms, emulator doesn't show:
                                Not share_int.
                                Hi, I've been without internet for a couple of days. I went to /recalbox/share/ and there was no roms directory. I created the roms/megadrive/ folders and added all the .gen files, then I rebooted the system and updated the game list.... STILL NOTHING.
                                Robsdedude 1 Reply Last reply Reply Quote 0
                                • Robsdedude
                                  Robsdedude last edited by Robsdedude
                                  This post is deleted!
                                  • Robsdedude
                                    Robsdedude @CaffeineFiend last edited by
                                    @CaffeineFiend: Did you put the SD card into your PC and copied the roms there? Because I think that /recalbox/share is a different partition that is being mounted on boot of recalbox. You better copy them via the network if you didn't do so anyway.
                                    CaffeineFiend 2 Replies Last reply Reply Quote 0
                                    • CaffeineFiend
                                      CaffeineFiend @Robsdedude last edited by
                                      @Robsdedude How do I do that? With an ethernet cable?
                                      • CaffeineFiend
                                        @Robsdedude I found this video https://www.youtube.com/watch?v=bcTfOHIDp_c and I'll attempt to make it work. How come it doesn't pick up the files when these are transferred by the method I used? Seems a little silly?
                                        • CaffeineFiend
                                          I finally have it working! Thanks a lot! Next step is to change the looks of the interface
                                          • Robsdedude
                                            @CaffeineFiend: It is actually possible to add the roms directly with the SD card put into your PC but it's not a trivial task. You have to mount the right partition to make it work. Using the browser or the network share in your file browser is the much easier and preferable way to do it.
