    Unsolved Rom's Disappearing
    roms disappearing
    5979
    • Bradley Cable
      Bradley Cable last edited by
      I Cant Add Any Games!
      I add rom's by devices on the network (I am on Mac OS))
      I click on RECALBOX go to rom's add I add a game to SNES folder
      Then I go to restart the RECALBOX and the rom dose not show up!
      I then check if it was still in the files, but it disappeared out of the SNES folder!
      That mean I cant add any games onto it can you help me out
      Thank You In Advance!
        no need to restart recalbox, just press start > game options > update game list
        Bradley Cable 2 Replies Last reply Reply Quote 0
        • Bradley Cable
          Bradley Cable @Substring last edited by
          @subs ok I will give it a try and get back to you
          • Bradley Cable
            @subs it works but the problem is when I turn it off after I finished using it all the games that I just put on are gone but your method did work till I turned it off!
              there is no reason recalbox would delete anything. The only "forbidden" thing is the .DS_store files from MAC. But there is no reason it would mess up the roms
              Bradley Cable 1 Reply Last reply Reply Quote 0
              • Bradley Cable
                @subs do you know any other way to fix it????
                  i don't even know why your roms disappear ! Do you only have a mac at home ?
                    Do you have transfer roms in /recalbox/share/roms.
                    Not into /recalbox/share_int/roms ?
                    • Rodrigo Rodrigues
                      Rodrigo Rodrigues last edited by
                      @Bradley-Cable I had the same problem, I was using berryboot to boot the system, I installed the direct recalbox on the SD and it worked, if you are using berryboot or another system for multi-boot, try installing directly on the sd card
