    No NBA Live Game is working on PSX-Emulator
    Emulator Arcade/PC/Console
    nba live psx-emulator
    8
    14
    9646
    • VanDutch
      VanDutch last edited by
      Hi,
      i downloaded some NBA Live Roms for PSX, NBA Live 2000, 2001, 2003 and 99! None of these Roms are working. After the loading-Bar is complete, it freezes. Is there a solution? Testet on PC with ePSXe, all working fine.
      Thanks!
      • geoone06
        geoone06 last edited by
        Hi,
        Try to launch the game on .cue instead of .bin if you have not already tried
        RPI3 / 4.1unstable
        • VanDutch
          Tried, non of them worked! Hmm..
          • VanDutch
            Is there a way to use an different PSX Emulator? N64 and Snes i can choose one.
            • supernature2k
              supernature2k last edited by
              no, we only have psxrearmed in Recalbox.
              • VanDutch
                OK. Do you plan to integrate other ones?
                  seems to me mednafen is not yet interesting on pi
                  • tonyloco
                    tonyloco Translator last edited by
                    What version is, @VanDutch? Pal or NTSC?
                    Distracted and hyperactive gamer at Distrattivo
                    • Nachtgarm
                      Nachtgarm last edited by
                      @paradadf was so kind and tested NBA Live '96 [NTSC-U] and NBA Live '99 [NTSC-U] and the first one was working just fine and the second one froze after the menu. I will test all NBA Games from 99-03 today.
                      • VanDutch
                        Tested also NBA Live 98, freezes after Menu. Why does it freeze?????? Does not make a difference if it is PAL or NTSC!
                          paradadf Staff last edited by
                          You can create an issue directly to inform the respective developers:
                          https://github.com/libretro/pcsx_rearmed/issues
                          • Nachtgarm
                            Nachtgarm last edited by Nachtgarm
                            Here are the test results (tested on latest RBX Version on a PI3):
                            NBA Live 96 (USA): Working
                            NBA Live 97 (USA): Working
                            NBA Live 98 (USA): Working, BUT controller is not recognized (makes it unplayable | tested in Arcade Cabinet with Xin-Mo)
                            NBA Live 99 (G): Not Working (freezes in first Menu)
                            NBA Live 00 (USA): Not Working (freezes on first loading screen)
                            NBA Live 03 (USA): Not Working (freezes on first Menu)
                            I converted all games to .PBP, before I tested them
                            I already updated my PSX Games Compatibility Sheet
                              Hello
                              may be help for your list : http://psx.silvanthalas.com/psx.html and http://redump.org/
                              and may be add add a column for SLXXXX -xxxxx or SLPSxxxx-xxxxxxx code in sheet.
                              • Nachtgarm
                                Nachtgarm @acris last edited by Nachtgarm
                                HI @acris
                                thanks for the link, but that is a list for the PSX Emulator, right? In that case it won't really help, just like the ePSXe" compatibillity list, because most of the games that are working on a PC with the above mentioned emulators might not run with our build-in emulator on RBX.
                                The SLxxx Codes are not needed, because the Game Names have the Countries already inside.
