    GPICASE 2W - PI zero 2W - Screen glitch
    gpicase2w pi zero 2w recalbox9.1 screen glichs
    13
    22
    7769
    • fr4nc3sc0
      fr4nc3sc0 last edited by fr4nc3sc0
      Hello my retrogamers Affectionatos,
      my recalbox is a
      -Retroflag GPI Case 2w
      -Raspberry Pi zero 2w
      -Recalbox 9.1
      My problem is that after playing few games a screen glitch appears, the screen shift to the right
      The worst thing is that somethimes the screem freezes also and I have to reboot
      I did I clean install using the official image
      https://www.recalbox.com/it/download/stable/rpi/rpizero2gpicase2w/
      The only customizzations were
      • Language (IT)
        -Theme Realbox-240p
        -Enable Arcade to see only one group for mame and neogeo roms
      I already did a re-install flasing my ssd
      dmesg log
      https://justpaste.it/2e02j
      recalbox.log
      https://justpaste.it/7jvc4
      Thanks
      Fr4ncesco
      • vithouse82
        vithouse82 last edited by
        Francesco ho una serie di problemi pure io con lo stesso hardware, questo forum è completamente inutile, non trovo risposte a nessuna delle mie domande...bah
        • polinkuer12
          polinkuer12 last edited by polinkuer12
          @fr4nc3sc0 I'm also learning about this issue! Is it a broken screen?
          • Pitch64
            Pitch64 Staff last edited by Pitch64
            Hello, this is a known issue without any real way to fix it right now. Try to use the provided theme recalbox-goa2.
            Nothing is broken, it's sort of incompability without any reason.
            Next release? Soon™
            gunbird warpedpipe 2 Replies Last reply Reply Quote 0
            • gunbird
              gunbird @Pitch64 last edited by gunbird
              @Pitch64 could you be more specific.
              What is incompatible with what in this particular case ?
              I am also impacted with this issue.
              Thanks
              • warpedpipe
                warpedpipe @Pitch64 last edited by
                @Pitch64 Im having the same issue. Offset screen, freezing screen and needing to reset. It also affects other themes too.
                zipino82 1 Reply Last reply Reply Quote 0
                • Pitch64
                  All I can say for now is we are working on it 🙂
                  Next release? Soon™
                  • zipino82
                    zipino82 @warpedpipe last edited by
                    @warpedpipe Hi, I'm having the same problem too but isn't there a solution to solve this problem? I have a Gpi case2w
                    • zipino82
                      zipino82 @Pitch64 last edited by
                      @Pitch64 said in GPICASE 2W - PI zero 2W - Screen glitch:
                      All I can say for now is we are working on it 🙂 hi sorry to bother you, I have a Pi02w and I have the same problem, is there a solution for that screen problem? thanks
                      • Aldébaran
                        Aldébaran last edited by
                        Toujours le même souci @Pitch64 besoin de logs ?
                        davidb2111 1 Reply Last reply Reply Quote 0
                        • beudbeud
                          beudbeud last edited by
                          for now my best way for not get this issue, it's use my mister theme
                          https://github.com/beudbeud/recalbox-mister
                          SilverGreen93 1 Reply Last reply Reply Quote 2
                          • davidb2111
                            davidb2111 Staff @Aldébaran last edited by
                            Salut @Aldébaran
                            Pas besoin, c'est un problème qui se retrouve sur un tas d'autres distribs.
                            La fondation et les gens qui gèrent la stack graphique sont au courant.
                            Par contre, je ne vous cache pas qu'il y a peu de chance qu'on ait un fix à ce problème...
                            • Pitch64
                              Si on a un fix à cette issue, ça sera bien un miracle...
                              Next release? Soon™
                              • Aldébaran
                                Recalbox étant dépendant de la bonne volonté de la fondation Raspberry pour la résolution de cette issue, et puisque vous semblez peu optimistes quant à sa résolution, pouvez-vous exceptionnellement fournir la version 9.1 de l'image GPi CASE 2W + Pi Zero 2w ?
                                Ce problème était aussi présent sur la 9.1 mais il se manifestait beaucoup moins fréquemment. Là, c'est vraiment gênant.
                                • Referenced by  Aldébaran Aldébaran
                                • SilverGreen93
                                  SilverGreen93 last edited by
                                  I had this problem from day 1 on installing Recalbox 9.1 on my GPI case 2W.
                                  I now have upgraded to 9.2 but still the same problem persists.
                                  I also ordered a new screen and replaced it, but sufferes from the same issue. So it is a software timing issue of some sort that needs to be looked into.
                                  Maybe it is related to the hdmi_timings? Can anyone point out if there is any kind of delay or something that can be changed there?
                                  For me, this issue occurs only when exiting an emulator (i.e. gameboy advanced) and returning to the main screen.
                                  To make the screen go normal again, I need to fully shut down the unit. Restart fixes the screen, but makes all the controls not working, so only a full shut down fixes it.
                                  • SilverGreen93
                                    SilverGreen93 @beudbeud last edited by
                                    @beudbeud said in GPICASE 2W - PI zero 2W - Screen glitch:
                                    I tried this theme, seems that the glitch it not there anymore, but the theme is too simple, no game info or images. Can you make another theme to include the game details and images?
                                    Magaki 1 Reply Last reply Reply Quote 0
                                    • Magaki
                                      Magaki @SilverGreen93 last edited by
                                      @SilverGreen93
                                      Recalbox is open-source, feel free 🙂
                                      SilverGreen93 1 Reply Last reply Reply Quote 0
                                      • SilverGreen93
                                        SilverGreen93 @Magaki last edited by
                                        @Magaki I really want to, but have no idea about what is the issue here. The only thing I want to find out is if it is a timing issue related to hdmi_timings.
                                        • Pitch64
                                          The issue is https://github.com/raspberrypi/linux/issues/5780
                                          Next release? Soon™
                                          • davidb2111
                                            davidb2111 Staff last edited by
                                            Geatings all!
                                            We have a working workaround that will be made available in the fore-coming 9.2.2.
                                            David.
