    Problem using the On/Off power button option in Recalbox 8
    onoff button option recalbox
    1991
    • ChrisK
      ChrisK last edited by
      Hi,
      Can anyone confirm that the On/Off power button option is working with the latest Recalbox v8 running on a Pi 4?
      I've uncommented the "system.power.switch=PIN56PUSH" line in the recalbox.conf file and rebooted, but grounding the GPIO3 pin has no effect. Also when I list running processes I cannot see the "rpi-pin56-power.py" script; is there something else I need to do to enable the startup of this script during boot?
      Zing renvert 2 Replies Last reply Reply Quote 0
        Zing Global moderator Translator @ChrisK last edited by
        @chrisk See if this helps:
        https://forum.recalbox.com/topic/25548/recalbox-reboot-au-lieu-de-s-arreter
        ChrisK 1 Reply Last reply Reply Quote 0
        • ChrisK
          ChrisK @Zing last edited by
          @zing Thanks, I've read that thread but can't see anything that will help my problem.
          It looks as if the script that monitors the button isn't being launched.
            @chrisk Check that you have followed all instructions correctly:
            https://wiki.recalbox.com/en/tutorials/others/add-on-off-button-to-your-recalbox
            ChrisK 2 Replies Last reply Reply Quote 0
            • ChrisK
              @zing I reinstalled Recalbox 8 on a blank SD card, uncommented the "system.power.switch=PIN56PUSH" line, and rebooted, but the power button still didn't work.
              However, it worked fine when I tried the same with Recalbox 7.
              It does look as if, for some reason, the power button monitoring script isn't getting launched on Recalbox 8.
              • ChrisK
                @zing Also I just SSH'ed into my box and tried running the rpi-pin56-power.py script manually. It gave a syntax error due to missing parentheses in print statements. Is Recalbox 8 set to use python3 while the scripts were written for python2?
                • Pitch64
                  Pitch64 Staff last edited by
                  This is a bug already fixed for the next version 🙂
                  Next release? Soon™
                  • ChrisK
                    ChrisK @Pitch64 last edited by
                    @pitch64 Thanks for confirming it is a bug.
                    • renvert
                      renvert @ChrisK last edited by
                      @chrisk Hi, I had the same problem. Worked perfectly fine until update to 8.0. Seems to be fixed in 8.0.2 now 🙂
