    Recalbox 8.0 on Pi Zero 2 W: black screen
    recalbox 8.0 zero
    3904
    • charger
      charger Banned last edited by
      Hello to all.
      I'm having big problems with the stable version of 8 sil pi zero2w: often the system crashes with a black screen, and needs to be restarted.
      In addition, the wifi must always be turned on manually at each restart and the screen scrapers are not downloaded.
      How is it resolved?
      • charger
        charger Banned last edited by charger
        Now is stuck on loading splash screen...this version has a lot of problems...
        Is really frustrating...I've format and reinstalled everything dozen of times in 2 days...
        • charger
          After anothers 3 hours of reinstallation, I have to resign and use retropie. Recalbox 8 is not working on pi zero 2: too much crash, and in worst case, system doesn't reload at all.
          • Bkg2k
            Bkg2k Staff @charger last edited by
            @charger You're not the only one to use a Raspberry pi zero 2, and if "Recalbox 8 is not working on pi zero 2" was true, we wouldn't have release this version 🙂
            Unfortunately, the Raspberry pi zero 2 has only 512mb of RAM and we must pay attention to some details:
            • Do not use a video output in 1080p. Forcing the 720p in the recalbox-user-config.txt is the best way to keep overall resolution "low"
            • Disable the Webmanager (it takes too much ram for now)
            • Keep the original recalbox theme
            • Keep the number of active system low
            • Do not use fullsets
            You may also try to change your SD card, as they are often the root cause of several crashes and malfunctions.
            charger 1 Reply Last reply Reply Quote 1
            • charger
              charger Banned @Bkg2k last edited by
              @bkg2k
              Thanks for reply.
              I'll try to force 720p, ok. How can I disable webmanager?
              • charger
                ok now seems a way better in 720p and without webmanager...thanks...let's see in advance
                • charger
                  Just a suggestion: you can setup config file in 720p and without webmanager by default. It can help a lot.
                  • Bkg2k
                    @charger It already on our "todo list" 🙂
                    • charger
                      @bkg2k however I’m experiencing lot of crash, again black screen and freeze, and one time I’ve lost completely sd card integrity. Pi zero 2 version is very very very unstable.
                      • link281
                        link281 last edited by
                        I have similar problems, the game starts and runs, I quit the game and start another one, it starts with 1 FPS, recalbox manager is off, display 720p.
                        charger daz 2 Replies Last reply Reply Quote 1
                        • charger
                          charger Banned @link281 last edited by charger
                          @link281 hope they fix as soon as possible; mine lose even wifi config at every reboot, and screenscrapers do not works very often...thanks again to recalbox crew!
                          • daz
                            daz @link281 last edited by
                            @link281 same here must be to do with the memory
                            • charger
                              I’ve to remove everything, even overlays, but no way: on quit games, very ofter black screen appears and need to reboot…very frustrating
                              • link281
                                link281 last edited by link281
                                if rewind and overlay is off it works
                                by DMT 35 : 1280x1024@60
                                charger 1 Reply Last reply Reply Quote 0
                                • charger
                                  @link281 not here
                                  davidb2111 1 Reply Last reply Reply Quote 0
                                  • davidb2111
                                    davidb2111 Staff @charger last edited by davidb2111
                                    Hi @charger and @daz
                                    When the problem occurs could share the file /var/log/messages which can be found in Logs tab of the manager by connecting through SSH?
                                    daz 1 Reply Last reply Reply Quote 0
                                    • daz
                                      daz @davidb2111 last edited by
                                      @davidb2111 ok I'll have to look how to SSH I have Friday off so will look then is there anyway of taken the memory card out to view the log on my pc
                                      • davidb2111
                                        davidb2111 Staff @daz last edited by
                                        @daz said in Recalbox 8.0 on Pi Zero 2 W: black screen:
                                        log files are not stored on disk nor sdcard. The only way to get it is through SSH.
                                        Here is a link to get it to work with WinSCP: https://wiki.recalbox.com/en/tutorials/system/access/network-access-winscp
                                        • link281
                                          Hello, I did a little research on the Internet. I then read that you can set the ram for video. and I did that in the config.txt set gpu_mem=128 to gpu_mem=64.
                                          And lo and behold, it works without settings you deactivate. Have tested SNES and repeatedly without black screen or FPS break-ins. Will do more tests the days and then communicate it. Sorry for my bad English. I hope I can help 🙂
                                          daz 1 Reply Last reply Reply Quote 1
                                          • daz
                                            @link281 thanks i will retry with what you have said over the weekend as mine is being used as a pi hole advert blocker at the min as was sick of it crashing
