    Recalbox 8.0 Beta!
    Announcements
    recalbox 8.0 beta
    39
    69
    55680
    • Macepincha09
      Macepincha09 @Bkg2k last edited by
      @bkg2k hello I tried the Beta 1 version with raspberry Pi 3 a + and when leaving or wanting to launch some games, the console freezes with version 7.2.2 I could not exit the games, with this new one I can exit but in some it does not leave me and in others I can not enter the games I do not have any theme installed it is all original.
      • Bkg2k
        Bkg2k Staff last edited by
        ALREADY FIXED:
        • Avoid deadlock (ES not launching) when PulseAudio does not start properly
        • Fix sound volume in Atomik's boot video
        • Fix 2nd HDMI output gamma issue on RPI4
        • Fix XBox & clones pad auto-mapping
        • Add DRM related path for Kodi (amazon prime & netflix)
        • Fix connection to open WIFIs
        • Ninoh-FOX
          Ninoh-FOX last edited by
          Updates in gpi case + rpi zero 2 not works, don't download the update file, fba not works the controls.
            Zing Global moderator Translator @xandi last edited by
            @xandi
            Bom dia eu estou tendo um problema diferente ,coloco a ROMs na pasta certa via rede ,mas o jogo ao atualizar lista de jogos não aparece no sistema e só na pasta ROMs do emulador correto da pasta Share . alguém pode dara sugestão . obrigado
            You are on the international part of the forum, so speak in english, use google translator or deepl if you cannot speak english.
            Your problem doesn't seem to be related to version 8.0 beta, it seems to be just a beginner's doubt, in this case the ideal is to open a new topic, and if you want to speak in Portuguese, use the Portuguese part of the forum:
            https://forum.recalbox.com/category/25/português
            Everything indicates that you are using a ROM in a format that the system does not recognize (.rar for example), check the readme.txt file that is inside each folder of each console to know the correct formats and the need for BIOS (If there is a need).
            Você está na parte internacional do fórum, então fale em inglês, use o google tradutor ou o deepl se você não souber falar inglês.
            Seu problema não parece estar relacionado com a versão 8.0 beta, parece ser apenas uma dúvida de iniciante, neste caso o ideal é abrir um novo tópico, e se quiser falar em português, use a parte em português do fórum:
            Tudo indica que você está usando uma ROM em um formato que o sistema não reconhece (.rar por exemplo), verifique o arquivo readme.txt que está dentro de cada pasta de cada console para saber os formatos corretos e as BIOS necessárias (quando há necessidade de BIOS).
            • tomeczek
              tomeczek last edited by
              RPi Zero 2W: 1. scrapper doesnt work. Even though connected to the network the scrapper finds 0 data.
              1. Kodi not working properly, asking for addons and stuff and freezes in the end.
              • Pitch64
                Pitch64 Staff last edited by
                For all scrap issues, please check with ScreenScraper staff first. This public beta was tested before we made it public and scrap worked fine. They could still have issues following their shutdown for maintenance last week.
                Next release? Soon™
                tomeczek 1 Reply Last reply Reply Quote 1
                • nukapop92
                  nukapop92 Banned last edited by
                  is recalbox beta version is good to use?
                  • tomeczek
                    tomeczek @Pitch64 last edited by
                    @pitch64 ok I‘ll try again
                      Zing Global moderator Translator @nukapop92 last edited by
                      @nukapop92
                      Yes. However, it's not the final version yet, the idea of an open beta is just for users to flag possible bugs, so it's a good version to use, but possibly with some bugs.
                      My opinion: buy another SD card and test it yourself, there's no better way for you to check if you like it than by testing it, and if it's on another SD card it doesn't affect your current setup at all if you don't like it.
                      • scanman717
                        scanman717 last edited by
                        PiBoy DMG with RPi4.
                        Kodi doesn't work, Asks to enable a lot of plug ins, once past all that it seems fine for the first run, will play videos no problem. Second time to run Kodi, get an isntant message "Playback Failed", and none of the buttons or joypad respond. Turning off the power button results in a "Power Options" window popping up then dissapearing, then popping up then disappearing over and over until I pull the battery.
                        SCUMMVM - Joypad movement unpredictable, and buttons don't seem to interact with the menus at all
                        • scanman717
                          Retroflag GPI Case
                          No Response from DPAD. Buttons and select and start appear to work fine, just can't navigate
                          scanman717 1 Reply Last reply Reply Quote 0
                          • scanman717
                            This post is deleted!
                            • Tincho113
                              Tincho113 last edited by
                              Hi, I bought two generic PS3 joysticks and I can't pair them with the Raspberry Pi3 model B (which has recalbox latest Beta version 8.0). I've tried connecting them using an USB cable for 10 seconds and then holding the PS button with no luck. I can navigate the EmulationStation menu but they don't work inside the games. I've also tried with the bluez, official and shanwan configurations. According to the joystick's lights it's always the 5th controller even though it's the only one connected.
                              I used Putty to find out which clone they were, this is the result:
                              [ 7.472441] usb 1-1.3: New USB device found, idVendor=054c, idProduct=0268, b cdDevice= 5.72
                              [ 7.472460] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber =0
                              [ 7.472467] usb 1-1.3: Product: PS3 Controller
                              [ 7.512109] input: PS3 Controller Motion Sensors as /devices/platform/soc/3f9 80000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:054C:0268.0001/input/input3
                              [ 7.574679] input: PS3 Controller as /devices/platform/soc/3f980000.usb/usb1/ 1-1/1-1.3/1-1.3:1.0/0003:054C:0268.0001/input/input2
                              [ 7.575355] sony 0003:054C:0268.0001: input,hiddev96,hidraw0: USB HID v81.11 Joystick [PS3 Controller] on usb-3f980000.usb-1.3/input0
                              • scanman717
                                scanman717 @scanman717 last edited by
                                Found the answer... Start + Dpad up for 10 seconds solved this issue. Been so long since I setup an image for this case, I forgot about this.
                                • eldontyrell
                                  eldontyrell last edited by eldontyrell
                                  Hi Recalbox team !
                                  First, thanks for the great update.
                                  I'm here to repport an issue on the gpi case version (for the raspberry pi zero 2).
                                  The zx spectrum emulator is working fine, however saving/loading states is just not working.
                                  It crashes the emulator, and it quits to the roms list.
                                  Second issue : the Kempston joystick emulation is not working at all. I tried with 2 games (attic attac & head over heels) and none is working with Kempston joystick.
                                  Also, the amiga emulator (uae4arm libretro) has issues with sound, I think. Either one of the channels is missing or very low so that the music sounds really strange. With earphones, sound is normal and both channels can be heard very clearly.
                                  When restarting recalbox from the menu, it freezes on the favorites screen and I have to switch the gpi case off and restart it.
                                  Stéphane
                                  • Bkg2k
                                    Bkg2k Staff @eldontyrell last edited by
                                    @eldontyrell Thanks for your feedback. Libretro-fuse has been updated to fix the issue. The core si now based on FUSE 1.6.0.
                                    • Paulska
                                      Paulska last edited by
                                      sometimes when unplugging a controller and plugging it back, it doesn't work.
                                      Once this happens, any new controller plugged in will not work and you have to restart.
                                      This issue also persists sometimes when the bluetooth controller gets disconnected for a second.
                                      second issue.
                                      Dreamcast no longer runs off the joystick, you have to use the D-pad. playing marvel vs capcom is unbearable for my kids.
                                      I did an update from 7.2.2 to 8.0 beta
                                      • SkullGrin
                                        SkullGrin last edited by SkullGrin
                                        @bkg2k said in Recalbox 8.0 Beta!:
                                        PC owners can now enjoy Playstation 2 games. We're providing you with the very latest version of the PCSX2 emulator, with full support of CHD and a global compatibility of more than 98%, thanks to the hard work of PCSX2's developers.
                                        ^^ YESSSSS!!!! Playstation 2 on PC Recalbox. FINALLY! 😁
                                        Recalbox > Most other All-in-one gaming Operating systems out there.
                                        • sergioad
                                          sergioad last edited by
                                          Hello, is it possible to ad the PPSSPP Libretro core in Raspberry pi?
                                          • Bkg2k
                                            Bkg2k Staff @Paulska last edited by
                                            @paulska Fixed in the final release 🙂
                                            Paulska 1 Reply Last reply Reply Quote 1
                                            101.0k
