    Pi4 7.2.2 Config for N64 Remap controls not saving ( Dragon arcade sticks )
    Emulator Arcade/PC/Console
    pi4 7.2.2 config remap controls saving dragon arcade sticks
    • Benzitor
      Benzitor last edited by
      HEy everyone, Since the 7.2 update, I cannot remap the Analog to mymy double Drangon arcade stick on N64.
      When i save config, or even do an override, when i quit, and load the games again, the changes disappear.
      HEEEELP it is really frustrating, and coming from Retropie i an real Noob with Retroarch.
      I really want to play MarioKart and GoldenEye on my Arcade, but remap both sticks everytime is super tired.
      Help help
        Zing Global moderator Translator @Benzitor last edited by
        @benzitor Do a Factory reset as I suggested here:
        • https://forum.recalbox.com/topic/24609/7-2-2-freeze-at-start-after-re-burning-the-image/3?_=1624574201667
        Test.
        If it doesn't work, read this:
        • https://forum.recalbox.com/topic/24572/change-hotkeys-for-mupen64plus-standalone
        • https://forum.recalbox.com/topic/24422/no-sound-on-splash-screen-and-gpio-doubt
        Benzitor 1 Reply Last reply Reply Quote 0
        • Benzitor
          Benzitor @Zing last edited by
          @zing Thanks for the answer,
          I will try this as the problem is really annoying. I never had this problem before the 7.2.1... And i use recalbox since 4.3.
          I need this to work instantly for both my Pi3 ( using standard USB Snes controller, and Dragonrise Arcade sticks.... ) to be able to map the Analog on HAt... It works when i do it.. but once save, and reboot, it is not working anymore, and i have to remap again and again.
