    SCUMMVM on RPI4 - how to map mouse axis to Dpads ???
    Emulator Arcade/PC/Console
    scummvm rpi4 map mouse axis dpads
    • clkgames
      clkgames last edited by
      Hi there, I am using a generic SNES controler which has no analogue sticks, only digital pads.
      On previous versions of recalbox I was able to move the mouse cursor with the dpads. I can't do it on 7.1.1 though.
      I had edited the file scummvm.ini at /recalbox/share/system/.config/scummvm and I followed instructions from scummvm website however no matter what I try, the mouse cursos stays stuck at the top left corner of screen and I cannot move the mouse at all, unless I install an USB mouse and move it, but having a mouse is not in plans.
      So, is there a way to do it?
      Regards,
      John
        Zing Global moderator Translator @clkgames last edited by
        @clkgames Read this:
        https://forum.recalbox.com/topic/21886/scummvm-pi-4-laggy-animations
