    No sound over HDMI.
    sound hdmi
    4165
    • abuzaid
      abuzaid last edited by
      I recently installed Recalbox on a USB Memory Card. It is running on a ZBox. I am able to launch games, and sound comes from the Jacks. But there is no Audio when connected to Samsung over HDMI Cable.
      I have looked through earlier posts and tried everything, still no audio.
      When using KODI, I get Audio, when I select HDMI 1.
      When in Recalbox, I don't see HDMI 1, only HDMI 0.
      Any help is appreciated.
      • ian57
        ian57 Staff @abuzaid last edited by
        @abuzaid hi there,
        did you try :
        hdmi_mode=2
        in /boot/config.txt file
        • abuzaid
          I don't have boot/config.txt
          Here is what I see in /boot
          • ian57
            @abuzaid arfff... you are on x86 :), the command is for Raspberry 🙂
            • abuzaid
              Yep. Anything I can try here? I have /recalbox/share/system/recalbox.conf?
              • Dekiste
                Dekiste last edited by
                Hello @abuzaid ,
                try this:
                https://forum.recalbox.com/topic/21453/recalbox-7-plus-de-son-en-hdmi-pc64
                it worked for me.
                Regards.
                abuzaid 2 Replies Last reply Reply Quote 0
                • abuzaid
                  abuzaid @Dekiste last edited by
                  @Dekiste I did try few options earlier from this thread. But I will give it another try but using all the possible combinations of card / device. I will report back next week.
                  • abuzaid
                    @Dekiste Didn't have much luck. Ended up buying cheap speakers and plugged them into Audio Out.
                    • Dekiste
                      @abuzaid what did you do? it worked for me making these steps:
                      -ssh connection (user: root, password: recalboxroot) and type the following:
                      mount -o remount, rw /
                      nano /etc/asound.conf
                      -Inside the file "asound.conf" write the following:
                      pcm.!default {
                      type hw
                      card 0
                      device 3
                      -After that, Ctrl+O to save the file and Ctrl+X to exit
                      If this does not work, try another device numbers, like 1, 2, 5...
                      Regards.
                      abuzaid 1 Reply Last reply Reply Quote 0
                      • abuzaid
                        @Dekiste Correct, I tried different options under Card 0 and 1. Do I need to reboot after each change? I was just saving them and hoping for sound?
                        • Dekiste
                          @abuzaid Yes, you should reboot the system after every change... 😀
                          • abuzaid
                            That didn't go very well. I ended up with no sound at all, so I had to re-installed recalbox to get it back over the Analog port. I am going to leave it, since I already bought speakers. @Dekiste @ian57 thank you for your assistance. My best guess is that the ZBox I have probably has some different NVidia chip, and they drivers probably are not shipped with recalbox to support audio over HDMI.
                            • abuzaid
                              abuzaid @abuzaid last edited by
                              NVIDIA Next Generation ION is the Graphics Chip.
